10-24-2019, 05:21 PM | #1 |
4496
Rep 1,862
Drives: powered by bootmod3
*** bootmod3 - MaxCool Mode + N55 Startup Roar - New Features ***
Announcing a couple of new bootmod3 features just released
First one is ‘MaxCool mode’ - this will reduce your water coolant targets by 10 degrees Celsius and applies to ALL engines and software (ROM) versions! Moreover, for the B series engines this enables the intercooler pump to be active at all times to lower intake air temperatures! We also added GTS startup roar for the N55 EWG and PWG172X! Use the standard ‘config’ menu on each map to toggle these features on any map including custom, stock and OTS.
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
10-24-2019, 05:47 PM | #2 |
Rep 303
Great news.
Can you provide details on how the lower target coolant temps are achieved (ie revised coolant pump and / or thermostat set points, etc ) Are the lower targets...in addition to.....the lower targets already associated with Sport and Sport + mode ? Is the lower target the same in each mode (comfort, sport, etc), or does it vary mode to mode ? . Last edited by M2C AW; 10-24-2019 at 06:48 PM.. |
10-25-2019, 10:25 AM | #4 |
24203
Rep 190,807
10-25-2019, 10:40 AM | #6 |
Rep 6,637
Probably sounds like when the car is slightly warm like it was run for a few minutes but still cool enough it does a cold start anyway.
When I start the start the car and go get gas 3 blocks away then start the car again sometimes it really roars! |
10-25-2019, 10:43 AM | #7 |
Rep 1,899
10-25-2019, 11:51 AM | #8 |
756
Rep 2,149
10-25-2019, 11:55 AM | #9 | |
Rep 1,899
Think of it as two "phases" The initial ignition start And then the idle rpm after all cylinders are ignited. The ignition itself is set to briefly hit a higher rpm and "roar" and then drop to the idle rpm The initial ignition start is what is being modified here. If you've noticed on stock then, when the engine is cold the ignition isn't very loud but the idle RPM is pretty high and loud When the car is warm, you usually hear a much more thunderous ignition whereas the idle rpm is much lower and the car is quiet while idling |
D CHOI581.00 |
10-25-2019, 12:30 PM | #10 |
Rep 523
hey guys proTUNING Freaks on a side note I am having trouble with creating the image on an SD card for the wifi obd agent box. every time i download it, let it unzip and then use balenaetcher i get an error saying it's corrupt. can you please advise
love the new options btw!
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2 Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe |
10-27-2019, 09:40 PM | #12 |
Rep 463
How does max cooling mode effect the cars ability to come up to temp. Will it take longer for the oil to come up to temp be the standard mode?
Spartan King79.50 D CHOI581.00 |
10-30-2019, 03:38 AM | #13 |
Rep 243
10-30-2019, 07:56 AM | #14 | |
Rep 4,516
Try driving yr car from a cold start in sport+ mode and you'll see it takes longer for WGDC to get 100% due longer lead-time to reach oil temp threshold.
Current '22 X3M LCI.. |
JTO245276.00 |
12-13-2019, 12:36 PM | #16 |
Rep 14
Just got bootmod3 and will be flashing ACN stage 1 over the weekend. I live in California so it gets pretty hot. I'm assuming it's a good idea to flash with maxcool mode right? I daily the car and go on canyon runs, but I haven't tracked it yet (hopefully soon though ).
12-13-2019, 12:46 PM | #17 | |
Rep 1,899
12-13-2019, 02:12 PM | #19 | ||
Rep 844
"Max cooling is a feature we’ve added lately that is designed for the coolant temperature to be 10 degrees lower. No down side to it. We’ve had many people use this feature without any issues." I do notice it takes the car longer to warm up and now I'm thinking of using it only during the vegas heat during summer time. But it does make sense for track use. Good to know it's fine if off. |
12-16-2019, 03:40 AM | #20 |
Rep 4,516
Makes sense.
Tags |
bm3, bootmod3, maxcool |
