E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Side Mirrors
Reply
      10-23-2019, 11:56 AM   #1
andrewc30
Drives: 2010 328i Xdrive E91
Side Mirrors
Hey all,
Bought some wide-angle, heated mirrors for my E91 LCI (2010)
yes, they dip, that function works fine, but i'm not concerned about dimming, just heating to get the moisture off this winter.
OEM glass that i pulled off, have a 4wire clip-to-strip connector (Red-Purple-black-brown image "borrowed")
And so the mirrors i look at either have a 2 or 4 pin heat connection, so i got an adapter (4 wire green-yellow).
Any idea about connection for the green&yellow if i go with the 4 pin? the green/yellow each have a small and large pair that match the pins, but no other indications.
I don't really want to trial and error this, by ripping the glass off and testing in cold temps every time (seeing as the heat function can't be turned on manually, and i foolishly already cracked one mirror).
THX
      09-17-2020, 06:09 PM   #2
rod.bearings
rod.bearings's Avatar
124
Drives: E92 M3
2009 BMW 135i  [0.00]
Did you figure it out? Was it the two short or the two long?
Reply
e90post
