08-07-2019, 03:35 PM | #1 |
Rep 1,262
Harmon Kardon Out, Eton & JL Audio in!
Car forums such as this one are awesome tools to mod cars the right way.
After researching 4 or 5 threads on both Speaker & Amp mods I decided to go the speaker route. The Match 7 amp looks great but for just over $400 I was able to purchase the Eton B100W's for the doors, the Eton B100 XCN center speaker and the JL Audio C2-400x's for the rear. The Eton's are all drop in speakers (PNP). The JL's just need a washer to secure the 3rd screw. I did the doors first and it took about 3 hrs taking my time. I added some Dynamat behind the midranges. I ran out of time and will report on the center and rear speaker installs later this week. The sound is drastically better. ~100hz to midrange is now much deeper with depth, and has great clarity. The tweeters also have much sharper sound. It now takes less volume to drive the speakers as well. I can't believe how much this simple mod has transformed the sound in the cockpit. Looking forward to finishing up.. Best, HAZMAT
08-08-2019, 01:28 PM | #3 |
Rep 780
No offense but the HK amp is tuned for the HK speakers so just putting in speakers will not give you much improvement in dynamic range. Spend the $750 on the amp and you will understand. With the amp you can up the bass with the sws 2ohm subs.
Just saying... |
08-20-2019, 12:57 PM | #5 | |
Rep 1,262
Although the amp certainly helps as per many posters on the board, I can always add the Match 7 Amp in later. IMHO the speakers brought in a huge change in bass in the unassisted sub range (100+ hz). The high end was also much truer. An Amp alone is still driving those HK speakers. Kind alike putting lipstick on a pig...
08-21-2019, 10:24 AM | #6 | ||||
Rep 66
I too noticed theres a big drop off on the sound quality comparing to my E90 335i with the Logic 7 surround sound. Kinda disappointed so looking for options to upgrade, i'm by no means an audiophile. |
08-21-2019, 11:59 AM | #7 | |
Rep 1,262
The door speakers do come with tweeters for the "sails". I decided to save a little cash when I bought the rears. I paid $105 for the JL's vs what a pair of ETON's would have run me. After reading all the posts I realized the rears are not where you need to spend your money. Just the front ETON's make a huge difference. You can either disconnect the center OEM speaker or add the ETON unit like I did. Its $ well spent IMO
nis270r33.00 |
08-22-2019, 07:53 AM | #9 |
Rep 1,262
ETON Compatibility chart:
https://www.eton-gmbh.com/fileadmin/...st_bmw_web.pdf JL Audio c2-400's: https://www.jlaudio.com/c2-400x-car-...-systems-99612 If you don't mind spending a couple hundred more I'd do the ETON's in the rear also. If you read all the posts on upgrading the 2 series you will find the rears are not that important. The Match Up 7 Amp combined with the front's a outstanding system. The Match Up 7 is a PNP solution and others have just swapped out the amp. https://www.ebay.com/itm/MATCH-UP-7B...cAAOSwlxddIjcb HTH, HAZMAT
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 Last edited by SEAT TIME RULES; 08-22-2019 at 08:18 AM.. |
08-24-2019, 04:21 PM | #11 | |
Rep 8
Front: https://www.extremeaudio.de/eton-b10...n-b-100-w.html Rear: https://www.extremeaudio.de/eton-etu-b100xn.html They're actually going for less now than when I bought them last year. |
08-25-2019, 09:42 PM | #12 | |
Rep 1,262
For me the amp is the next step, primarily to be able to play with the sound stage and set it up properly.
08-31-2019, 01:23 PM | #14 | |
Mr Wonderful
58
Rep 780
Subs are "decent" it's the mid range/high that lacks. I coded out my ASD
09-05-2019, 02:00 PM | #15 | |
Chuggin' Along
333
Rep 588
10-28-2019, 12:50 PM | #17 |
Rep 1,262
