05-15-2019, 03:52 PM | #1 |
Rep 73
Blown Engine/Piston (M2 modded with catted DP & BM3 tune) - Suggestions ?
Hi all,
Went on a track day car and went into limp mode twice with no engine light or warnings and at last session car suddenly starting blowing white smoke from exhaust. Went back in to check and engine oil had splattered all over the engine bay. Initially thought it was an issue with the turbo as it couldn't spook properly. Painfully towed it back to my mechanic. After checking on the car with my mechanic it seems one piston is broken (missing a chunk) and one is scratched. Boost leaked through and pushed oil through the valve cover likely destroying the PCV module along with it. Engine mods: VRSF catted DP and charge pipe K&N filter AA intercooler BM3 Any suggests on next steps? New engine? revert back to stock and try to fight for warranty? Rebuild? |
05-15-2019, 05:17 PM | #5 |
Rep 73
It would definitely make it a hard fight. but then again, legally they also need to prove the aftermarket part or tune caused the failure directly if they want to deny me officially. I think BM3 tunes are fairly well tested and conservative enough to not push the engine that hard. I only ran one session with stage 2 as I forgot the change it back. I haven't seen much posts/people report engine issues on M2 motor. This situation is leaving me dumbfounded. It's not a race car but it should at least hold for a few track days.
05-15-2019, 05:38 PM | #6 | |
Rep 923
I would try an search a used engine from a crashed M2 or get yours rebuild (if possible). New engine will be utterly expensive. Sorry to hear you experienced this. These stories are exactly the reason I never mod the engine of my cars.
05-15-2019, 05:56 PM | #7 |
Rep 3,006
Everyone aways references the Magnuson-Moss Warranty Act and Aftermarket Parts.
https://automotiveaftermarket.org/ma...-warranty-act/ I'm not a lawyer but I believe the "intent" the act was to say you don't have buy a BMW oil filter instead of a Fram. The tune reprogrammed the car. It's not a "part" so not sure how that will work out. Also not sure if this law applies in CA? Good luck, let us know how it goes. |
nioh_lbbm21716.50 eatingpizzainthef87rules253.00 |
05-15-2019, 06:34 PM | #8 |
Rep 73
In Canada our equivalent to it is Consumer Protection Acts.
Also not a legal expert, but to my understanding that the product needs to perform as intended for reasonable amount of time and for aftermarket parts it needs to be proven that it caused the damage or malfunction. But looking at it from the worst side, does anyone now if its possible to order a new M2 engine? and if a swap needs any coding and such? |
05-15-2019, 06:45 PM | #10 | |
Rep 220
As far as I know, this is the first blown engine in these parts. Super sorry to hear, OP. If you're comfortable sharing, would love to get more details about how it went down, track temps, distance run and how hard on stage 2 tune, etc. It does sound like the car gave you some feedback with the limp modes, did you happen to throw a code reader on it? I'd love to know any data you got before the final meltdown so the rest of the community could be aware of what to look out for. Again, condolences. |
05-15-2019, 07:03 PM | #11 | ||
Rep 3,006
All said, I would definitely take it to the dealer, you have nothing to loose. Quote:
You can buy used... https://www.usedbmwengines.us/engine...m-352659744999 or new... https://parts.bmwnorthwest.com/p/BMW...SABEgIk8vD_BwE or maybe an opportunity to upgrade... https://www.ebay.com/itm/2018-BMW-M4...4AAOSwtXtbA2~b Last edited by omasou; 05-15-2019 at 07:13 PM.. |
acl2637.00 |
05-15-2019, 07:17 PM | #12 | |
Rep 303
How abusive has the 10,000 miles been in general ? Lots of modded N55s have endured many years / miles of abuse without similar issue. If you had to hazard a guess...what do think your issue is ? Hint...It’s not the OTS BM3. |
05-15-2019, 07:29 PM | #13 |
Rep 73
I don't have access to the car right now so I can't check if the logs for the day made it through.
The car ran fine power and power was present till final run. When the car went into limp mode it was sudden and with acceleration only, wasn't even near redline either. Didn't check coolant temps but I doubt it would have been anything crazy as I didn't notice any power loss and I skipped a session as well. Shut off the car and it went away. Limp mode occurred when I was near half a tank so I thought it was a similar limp mode due to LPFP issue. Second time limp mode went to check actual messages through BM3 and it show super knocking and fuel injectors shut off. I couldn't see anything online to those codes so I thought it wasn't anything serious but here we are now. then again, on stage 1 91, I ran WA 92 gas with Lucas octane booster. No idea where this crazy knocking came from. Shelton, WA that day didn't have super hot weather either. Even at the last session the motor seemed fine. I only stopped as there was huge white smoke coming from exhausts. Funny thing is that no limp mode came on the session right before it or any messages. I am so perplexed at this incident. Either way, even if its mods or engine defect can I even trust this motor to do occasional track days anymore? or anyone else for the matter. |
05-15-2019, 07:36 PM | #14 | |
Rep 73
This is the 5th track day for the car and 1st day this year. I don't abuse the car regularly, I don't even know are to launch it. If you are implying its a money shift, I can tell you I wouldn't waste time making a post for it like this. In any case, how can you be so sure it cannot be BM3? (not accusing anyone) But how long as v5.7 been out for? Has it had enough track testing? But I honestly don't believe it is the tune either. |
05-15-2019, 08:43 PM | #15 |
Rep 303
Well...I take a couple of logs each run / session...and the data has always looked good. Recently I have opted for OTS Stage 2 91 vs 93, as I spotted some knock indications. I wasn’t certain they were an issue, but didn’t want to push my luck.
I heard of 3 engine failures at a recent DE event that were traced back to a pump gas issue....water I believe. May be something worth checking. |
05-15-2019, 09:03 PM | #16 |
Luxury at the redline :)
9105
Rep 7,563
The DP alone will sink you with a warranty claim.. Tampering with a Federally mandated emission control device is a easy win if you try to sue them, you'll lose just on sheer principle.
I love how naive and spry folks are in believing that the dealer has to abide by any MMA requirements or what ever empty threat you throw at them would actually sway their decision; if they have any reasonable suspicion that the vehicle was abused, modded, or tuned for more power that was allowed stock, they'll be happy to tell you to go kick rocks.. What you going to do then? There is no financial recourse except unsuccessfully suing them, which could drag on for years.. I'm pretty sure BM3 leaves a shadow code in ROM regardless if you flash it back to stock, which they would be able to retrieve. Best bet is beg for the mercy of a goodwill repair. |
05-15-2019, 10:08 PM | #17 |
Rep 753
05-16-2019, 12:36 AM | #18 |
Rep 390
Honestly......there shouldn't even be tunes available for 91 octane...that's not even sufficient for the stock car.
It's just plain bad. Please keep us informed OP. We all wish you the best |
05-16-2019, 07:45 AM | #20 |
Rep 699
This will end up being what should have been a legitimate warranty covered failure that BMW will get out of paying due to mods that didn't cause the failure.
bluescoupe57.00 bngcruiser277.00 |
05-16-2019, 08:31 AM | #21 |
Rep 115
Have you checked the crankbolt? While not as common as the S55 spun hub, it does happen with the N55 on occasion as well. I have heard of a couple of instances in the Chicago area. In both of them, the spun hub messed up the timing, caused something to break inside the engine and became an oil pump. This causes an oil leak soon after and then the engine seizes. Both cars were tracked heavily.
2020 BMW M2 Competition (ED - May 20th )
2017 Ferrari 488 GTB 2016 Porsche Cayman S 2015 Mercedes E63 S AMG |
05-16-2019, 08:47 AM | #22 |
Rep 115
This statement is somewhat misguided and perhaps biased as well. Anytime someone modifies the engine, you are introducing additional stress beyond the original intended level determined by BMW to be safe. Yes, there has been many prior cases where the same mods have shown to be problem free, but every car is subjected to different usage. To make a definitive statement that the mods did not cause the failure is being naive.
The best bet for the owner is to approach the dealership for a good will repair at a reduced rate. But the better question is will the owner trust the car on track anymore with the same mods?
Artemis29419.00 eatingpizzainthef87rules253.00 |
