M2 Technical Topics > Cosmetic Modifications > M2C IND Red M1/M2 Buttons Install
      05-11-2019, 01:31 AM   #1
HKMP7
Drives: 2016 M4
Hello All,
Here is a DIY on how I installed the Red M1/M2 Buttons. I did this for the F8x M3/M4 and I fiqured it may help some of you M2C guys and gals.
Its pretty simple just need some patience with the button tabs.
Here are the tools I used
16 mm socket
Torx T20 socket
Impact gun
Electronics phillips screwdriver
Electronics flat head or tiny pick
I'm assuming you know how to remove the airbag
If you dont watch this.
Now Remove the 16 mm bolt with a impact or ratchet.
Then the two connectors.
Pay attention to the position of this alignment indicator for re installation
Original thread here https://f80.bimmerpost.com/forums/sh....php?t=1493828
      05-11-2019, 01:31 AM   #2
HKMP7
Drives: 2016 M4
Now we are going to remove the trim piece its 3 T20 torx bolts
      05-11-2019, 01:32 AM   #3
HKMP7
Drives: 2016 M4
Once you remove the trim it will give you access to this T20 torx bolt. This one removes the left paddle.
After removing the paddle you will have access to this T20 torx bolt. This is the bolt that holds on the button pod.
      05-11-2019, 01:34 AM   #4
HKMP7
Drives: 2016 M4
Now flip over the button pod and remove the 3 tiny phillips head screws.
      05-11-2019, 01:37 AM   #5
HKMP7
Drives: 2016 M4
Here are the Red buttons vs the factory ones
To remove the buttons you need to pry the tabs outward over the notch and then the button will come out
      05-11-2019, 01:43 AM   #6
HKMP7
Drives: 2016 M4
Putting the new ones in is as easy lining it up and pushing it in until you hear the click.
When putting mine in I noticed it was a bit tight so I took a nail file and filed off a bit of the red paint near the tabs then it was perfect.
P.S. I had some of the first run of these buttons the ones made now shouldn't have this issue.
DazC905.00
wavyyyy1045.50
      07-06-2019, 08:22 AM   #7
Mike_OGm2
Mike_OGm2's Avatar
Drives: '17 340i & '18 M2
  [0.00]
M1/M2 buttons also fit on the OG M2, although they are functionless but do depress and pop back. No lights exist behind the buttons. Couldn't stand the blanks anymore.
      06-27-2020, 01:59 PM   #8
ssabripo
HALA MADRID!
ssabripo's Avatar
Drives: camels & donkeys
do the IND red buttons maintain the light functionality on the M2C?
F87 M2 Competition, Sunset Orange, Exc, DCT.
**SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015
**SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED.
      06-27-2020, 02:11 PM   #9
Mike_OGm2
Mike_OGm2's Avatar
  [0.00]
No idea. I would assume so. Though I don't have an m2c.
      06-29-2020, 08:11 AM   #10
BlacMacJac
Drives: AW '20 M2C
yes. but it's simply a matter of transparency, letting the bulb's light somewhat come thru the plastic.
      06-29-2020, 03:06 PM   #11
ssabripo
HALA MADRID!
ssabripo's Avatar
yeah, IND just informed they do, because the issue is the OG M2 doesn't have the buttons thus the lighting functionality. On the M2C, it works fine just like in the M3/M4v
I ordered them
      03-19-2021, 02:24 PM   #12
Ft_Laud_M2c
Drives: BMW M2 Competition Subaru WRX
Did the RedM Buttons and exterior matched sunset orange trim on the steering wheel. Both easy to do and came out great. But I managed to lose a tiny but important part in the process.
I lost one of the two small vertical white plastic pieces -- anyone have any thoughts on how to obtain these or am I going to end up needing to get an entire donor piece to get another one??
Sorry I borrowed the picture--Ignore the arrows, trying to find one of the small white vertical pieces shown
