M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > NEW Wagner Tuning S55 Radiator +89% Front Volume ** +94% Side Volume
      05-09-2019, 04:37 PM   #1
mike@x-ph.com
mike@x-ph.com's Avatar
Talking NEW Wagner Tuning S55 Radiator +89% Front Volume ** +94% Side Volume
Competition Radiator Kit for the BMW F80-82-83 M3/M4
The 3.0 Liter S55B30 turbo engine for BMW M3/M4 models is equipped with an indirect charge-air cooling circuit. So the cooling of the charged air is not realized by the ambient air as cooling medium (as usual), but made with its own cooling water circuit. A reduction of the temperature of the cooling water is directly equated with an improved cooling performance of the charged air. This is exactly where the advantages of the WAGNERTUNING upgrade water cooler comes into play.
The new developed competition racing cores of the WAGNERTUNING high performance water coolers increase the radiator volume of the OEM water coolers by 89% for front mounted and 94% for side mounted. The calculated ratio between the inner and outer cooling surface generates a maximum heat transfer and allows at the same time enough air flow for the surrounding components (for example the engine water cooler) for its own heat exchange. The water coolers are equipped with a heat-conductive anti corrosion coating to ensure a lasting cooling effect. The plug & play installation of the system is simple and easy to perform (an installation instruction is included as well).
Dimensions OEM front mounted radiator:
590 mm x 308 mm x 25 mm / 23,2Inch x 12,1Inch x 1,0Inch
V = 4,5 Liter
A = 1817 cm² / 280,7Inch²
Dimensions WT front mounted radiator:
568 mm x 468,4 mm x 32 mm / 22,4Inch x 18,4Inch x 1,26Inch
V = 8,5 Liter (+89%)
A = 2660,5 cm² / 412,2Inch² (+46,4%)
Dimensions OEM side mounted radiator:
250 mm x 165 mm x 40 mm / 9,8Inch x 6,5Inch x 1,6Inch
V = 1,65 Liter
A = 412,5 cm² / 63,7Inch²
Dimensions WT side mounted radiator:
252 mm x 188 mm x 68 mm / 9,9Inch x 7,4Inch x 2,7Inch
V = 3,2 Liter (+94%)
A = 473,8 cm² / 73,3Inch² (+14,9%)
Kit comes with:
1x front mounted radiator (low-temperature circuit)
1x side mounted radiator (low-temperature circuit)
1x carbon air shroud for side mounted radiator
1x mounting material
1x installation instruction
https://x-ph.com/sale/
Phone number 725-221-5267
      05-09-2019, 05:48 PM   #2
Project_F87
Project_F87's Avatar
Drives: 2020 M2C LBB 6MT
Installed pics? Need a donor car? I'm local
Instagram: @Project_F87
      05-09-2019, 06:47 PM   #3
GerardzM
If you are, I may have seen your Mineral Grey vehicle when you had it lol
      05-10-2019, 06:04 AM   #4
Winterstorm
Winterstorm's Avatar
67
Drives: BMW M2 Competition (04/2019)
Also usable for M2 Competition ?
Thanks.
      05-10-2019, 10:28 AM   #5
Greg75
Greg75's Avatar
Drives: BMW M2C LBB DCT
Thanks.
+1
      05-10-2019, 12:12 PM   #6
mike@x-ph.com
Thanks.
Originally Posted by Greg75 View Post
+1
It should be the same part number for both M2 Comp and M3
      05-15-2019, 04:01 PM   #7
Project_F87
You live in the antelope valley?
      05-19-2019, 01:20 PM   #8
GerardzM
I did live in Lancaster for a bit...but I think I'm mistaken now.
I though you were out in Vegas.
      12-22-2019, 08:37 AM   #9
QuickOne
Drives: 2015 M5
If this fits the 2019 M2 Competition, I would like to run this setup (along with the inter cooler) on my track car. Do you have this in stock?
      12-22-2019, 11:20 AM   #10
mike@x-ph.com
In stock
      12-22-2019, 03:12 PM   #11
QuickOne
Drives: 2015 M5
Could you PM me a price on this and the inter cooler (black, no logo) shipped to 06902 for a 2019 M2C?
      12-24-2019, 10:31 AM   #12
mike@x-ph.com
Congrats
