03-15-2019, 11:08 PM | #67 | |
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 6.5s X4M #HCP
03-15-2019, 11:23 PM | #68 | |
Rep 3,695
The IATs look way too high in the 5.7 logs, and it’s not even a 2H map. I don’t think that’s a symptom of 5.7, just that I need to change the DP and then decide if I need to change the IC, as well. |
03-16-2019, 01:48 AM | #69 |
Rep 2,577
DP will help a little bit ignition timing under high IAT, but doesn't change the high IAT.
Let's face reality. The intercool is no good. It doesn't even prevent IAT from climbing on your first pull. Good intercooler would decrease the IAT at first few runs. In repeated 3-4 gear runs, the IAT is stable at 60F over ambient temp, either with your custom map (40F ambient) or OTS V5.7 (70F ambient). Unacceptable for the map you're using.
Lemania 2320
03-16-2019, 07:38 AM | #70 | |
Rep 3,695
I want to do this a part at a time to see the differences in the logs, so I’ll go Wagner Evo Comp II first, log, then DP, then log. |
04-18-2019, 07:27 PM | #71 |
Rep 3,695
Alright, I've got an update for you guys.
First, I changed the Dinan IC to a Wagner Evo 2 Comp. When driving at higher speeds, in medium traffic, or stop & go it's keeping the delta b/n ambient and IAT 10-25F lower than the Dinan, so that's good. I also added the do88 larger remote radiator to go with my CSF radiator, oil cooler, and DCT cooler. As for the outcome, I have mixed feelings. You'll see that I gave the car a workout to try to emulate hot summer track days. The Wagner is definitely helping, but higher than 93 octane will be a must. Even with that, I'm not sure how much more I could really push on track with the Stage 2 93 5.7 map. Stage 2 93 5.7 with Wagner - Ambient 78F I had already completed a few pulls before I remembered to start logging, so temps are already up in this log. IATs were at 94F before starting the initial pulls. http://www.bootmod3.net/log?id=5cb90b36ae729b44f4273e3b Stage 2 93 5.7 with Dinan - Ambient 70F http://www.bootmod3.net/log?id=5c8c421dae729b3511ea8fd1 Stage 2H 93 5.5 with Dinan - Ambient 40F http://www.bootmod3.net/log?id=5c2c9014ae729b51747a4b72 As for general drivability, 5.7 is smoother around town and has more power in the low/mid-range. Altho, my Stage 2H 5.5 map feels stronger up top. And, the last possible upgrade item would the switching the stock DP out. Not sure how much that would improve what we're seeing here. Any feedback is appreciated! Last edited by ZM2; 04-18-2019 at 10:36 PM.. |
04-18-2019, 08:44 PM | #72 |
Rep 303
Im not qualified to critique your logs, but I can offer-up for comparison a log I captured during some open lapping this past weekend. My car has Evo2 comp IC, and the BM3 Stg 2 93 V5.7 tune, so there are some simularities. Big differences are my car has a 300 cell DP, stock turbo, and all stock coolers. Ambients were at 73 F. Shell V-Power 93. DCT auto upshifting at 6800 to 6900 rpm typically.
My untrained eye doesn't spot any red-flags on my logs. Car ran great for more than 7 hours total of hot lapping over 2 days. I’m impressed how the coolant, engine oil (Motul 5w40), and IATs hold-up despite the abuse. I am tho apprehensive of how temps will hold up as ambients climb this summer. When that happens, I’ll likely try the Stg 2 91 OTS tune and take some more logs. http://www.bootmod3.net/log?id=5cb3a419ae729b051b0448af Last edited by M2C AW; 04-18-2019 at 09:37 PM.. |
ZM22810.50 |
04-18-2019, 10:03 PM | #73 | |
Rep 3,695
I’m assuming I’m generating more heat bc of more power from the Dinan turbo, but I’m not sure that’s how the tune adjusts/works. It would be great if all I need to do is change the DP! |
04-19-2019, 02:28 AM | #74 | |
Rep 415
On the only real WOT part of this log you have 4 knock events in a single 4th gear pull. You’ll either need more octane to run this map or drop down to the 91 ots. The American fuel quality for its advertised octane is lower than other parts of the world, that is obvious from the multiple logs we have seen. I’ve personally ran the race fuel map with much cleaner logs on my pump 99 ron which should translate to 93/94 octane. |
ZM22810.50 |
04-19-2019, 07:46 AM | #75 | |
Rep 3,695
Other than that, M2MGM your logs look pretty good to my inexperienced eye. It looks like I’m definitely taxing the car more with the back to back full 3-4 gear pulls. Heck, I almost had my front tires up to track temp with no lateral loads (was at 155F), just from all the heat under load, low airflow from the decels and my APs getting warm! http://www.bootmod3.net/log?id=5cb90b36ae729b44f4273e3b Halim isn’t satisfied with what he’s seeing, so we’re going to try a couple things to figure out if changing octane, the stock DP, or map tweaking helps. Last edited by ZM2; 04-19-2019 at 08:10 AM.. |
04-19-2019, 10:10 AM | #76 | |
Rep 303
Thanks for your comments. |
ZM22810.50 |
04-19-2019, 10:20 AM | #77 | |
Rep 303
ZM22810.50 |
04-19-2019, 10:43 AM | #78 |
Rep 3,695
Think I’ll add some octane booster to my tank and will redo the logs to see how that impacts things. Will post up when I have them.
04-22-2019, 07:33 PM | #79 |
Rep 3,695
Here’s a Stg 2 93 5.7 log with octane booster. Octane should be equivalent to US 98: http://www.bootmod3.net/log?id=5cbe507cae729b40cb5a8b25
I didn’t get to push as hard with the 98 octane pulls, but the car felt better than when I logged 5.7 with 93 octane: http://www.bootmod3.net/log?id=5cb90b36ae729b44f4273e3b That said, it still isn't as smooth up top as my Stg 2H 93 5.5 map on 93 octane: http://www.bootmod3.net/log?id=5c2c9014ae729b51747a4b72 At this point everyone will say it’s the stock DP that’s holding the car back, but I’m curious how the logs agree/disagree? Thanks guys. Last edited by ZM2; 04-22-2019 at 10:18 PM.. |
05-27-2019, 07:39 PM | #80 |
Rep 3,695
Alright, here are some E25 runs on the E30 map: http://www.bootmod3.net/log?id=5cec6f8ac090c61270ad0b22
The logging messed up a bit and I had completed 3 pulls before these and went on for about 5 more, driving the IATs all the way up to 135F, even with the Wagner Evo 2 Comp... I started at E25 just to make sure I wouldn't have any issues with the HPFP. HPFP looks good, along with timing and everything else. No earth shattering changes on the power side (feels like 5-10hp more?), but I will say the car felt smoother thru the rev range and a lot better on the top end, especially as IATs rose. With the Stg 2 93 map and 93 octane, you can feel the timing start to crack up after just a few pulls. Octane booster helps, but you still feel it as IATs get above 125F. With the E25 on the E30 map, no feeling of timing pull even when I drove IATs >130F. There was reduced power, but it wasn't rough feeling like Stg 2 93. Overall, the car feels good and I'll bump the fuel up to E30 next time. And, I should finally get my DP installed next month! |
05-27-2019, 08:26 PM | #82 |
Rep 3,695
05-28-2019, 06:26 AM | #84 |
IG @bmwF9xG80
3813
Rep 7,593
I love E30 thats all I ever ran in the summer months as well.
ZM22810.50 |
05-28-2019, 07:36 AM | #85 |
Rep 3,695
Changing from the stock DP is all I have left to complete my FBO + Dinan turbo build. I don’t expect changing the DP will impact IAT much, so short of changing to a huge lag inducing FMIC, WMI, or detuning I’m not sure there’s anything more I can do about IATs.
05-28-2019, 09:56 AM | #86 |
Rep 3,695
05-28-2019, 12:35 PM | #87 |
Rep 1,466
Please do start a thread up on this. I'm speccing out a WMI system myself at the moment and would be interested in sharing notes / plans etc.
2018 ///M2 LCI, LBB, 6MT...
ZM22810.50 |
