10-20-2018, 05:01 AM | #1 |
Rep 844
CEL on FS Downpipe!!
Got my 1st CEL @ 17,500 miles. Only performance mod is the Fapspeed downpipe with over 10k miles on it.
P0420 - Cat System Efficency Below Threshold Bank 1 I reset it and it came back on within a few days. I just reset it again one more time but it doesn't look promising. What's my best option moving forward? I haven't been active on the forum for a few months so I'm not up to date on this CEL or new downpipes I can consider as replacement for worse case scenario? |
10-20-2018, 10:07 AM | #2 |
Rep 211
I'd get a hold of Fabspeed directly. They guarantee no check engine light with their sport cat downpipes, so they should hopefully be able to do something for you.
10-23-2018, 10:04 AM | #5 |
Rep 844
Got this response from Fabspeed.
The code you are getting could be caused by different things other than the catalytic converter. Please view the below requirement on out warranty page: Fabspeed products containing catalytic converters are protected by a 2-Year Limited Warranty against failure or defects in material and construction. This Warranty does not apply if the product(s) has been installed on a vehicle that has been run with leaded race fuel or fuel additives. In order for Fabspeed to replace a catalytic converter under warranty, the following conditions and requirements must ALL be met: 1. Catalysts must not show any physical damage or signs of abuse. Signs of abuse include, but are not limited to, motorsport or on-track use, leaded fuel, fuel additives, etc. 2. Catalysts must be no more than two years in age from original purchase date. 3. There are no visible exhaust leaks anywhere in the exhaust system upstream of the catalysts. 4. Two ECU printouts showing catalyst inefficiency faults. After the first printout the ECU fault memory is cleared. If the fault returns, a second printout should be made and submitted for warranty approval. *Printouts must include operating conditions and vehicle hours. 5. No other faults which will alter the OEM or Fabspeed ECU tune air/fuel calibration should be present on the printouts for catalytic inefficiency (for example: codes for fuel trim, O2 sensors, MAF sensor, etc.) 6. A graph of the oxygen sensors before and after the catalyst must be supplied. This graph should show the oxygen sensors in operation on a fully warm vehicle in closed loop operation. Currently waiting to put more miles on to see if CEL will return the 2nd time around. Last edited by D CHOI; 10-23-2018 at 09:29 PM.. |
10-23-2018, 11:06 PM | #7 |
Rep 4,551
Drives: 2015 328d xDrive
If it doesn't go away on it's own I'd swap the 02 sensor before moving forward with a claim or replacement
NYC Bimmer259.50 |
10-24-2018, 10:34 AM | #8 |
756
Rep 2,149
Why? Are the O2 sensors known to go bad? And if it's the downpipe, why should OP spend his money diagnosing other stuff? Especially when his only mod is the dp and the car has so little miles on it.
10-24-2018, 10:37 AM | #9 |
Rep 4,551
Yes, o2 sensors are known to go bad and cause these faults and they are much cheaper/easier to replace then catalytic converters so it's definitely worth a shot in my opinion to rule it out as a possible cause.
NYC Bimmer259.50 |
10-24-2018, 10:37 AM | #10 | |
Rep 699
10-24-2018, 11:11 AM | #11 |
Rep 844
Right but in my case the DP is under warranty so they will replace it for free. As for the instructions goes it asked to test the 02 sensors and show graphs. I'm not familiar with how this process works but the shop should be able to tell if it's bad right away right? Or are 02 sensors tricky to diagnose?
10-24-2018, 11:15 AM | #12 |
Rep 4,551
I'n not sure I've always just replaced them and you can tell that way immediately. It's a $75 part.
NYC Bimmer259.50 |
10-24-2018, 02:58 PM | #13 |
756
Rep 2,149
Sounds like BMW should recall them if they are going bad at 15,000 miles. Quick google search says they last 100,000 or longer. But kinda hard to do that if you have an aftermarket downpipe installed. Just seems like getting a downpipe is a huge PIA when something goes wrong.
10-24-2018, 04:19 PM | #14 |
1006
Rep 1,653
Sorry Guys. I have been on vacation. I am looking into this as we speak.
4
10-25-2018, 03:16 AM | #16 |
Rep 844
Good news is the CEL hasn't come back on after being driven for longer than the 1st reset. Not sure how long it takes computer to reset and fully adapt but over 100 miles seems like a decent amount of time.
10-26-2018, 06:30 PM | #19 |
Rep 1,899
10-27-2018, 09:08 AM | #21 |
Rep 181
10-27-2018, 09:30 AM | #22 |
1006
Rep 1,653
Phil from Fabspeed here.
Eventually, yes catalytic convertors will fail and cause a CEL. The milage that it takes for the cats to fail is really dependant on the type of cat and quality of cat material. It should also be noted that how the car is used ie type of gas, street or track, tuned or not, will all play a factor into how long the cat lasts. If your vehicle is tuned and you are running race fuel on the track that will significantly change the longevity of the cat over running premium on the street having "fun" with your vehicle. I hope this helps I have seen and heard about HJS cats lasting over 100,000 miles. |
nioh_lbbm21716.50 |
