M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Winter wheels for the M2 Competition
      12-18-2019, 02:10 AM   #23
Lotus99
Lotus99's Avatar
628
Drives: 19 M2C & 18 X3 M40i
Originally Posted by f31mtl View Post
See my post. 3025 CAD + taxes for wheels and tires. Wheels are made in Asia of course. Also the link shows the wheels mounted on an M2C (though the rear wheels are 19x10)
Sorry, missed that. Still 50% more than I paid so I'll stick with my choice...
      12-18-2019, 07:38 AM   #24
M2Cmtl
Drives: 21 Q7 & 22 4XE
wait you found a set of winter wheels/tires for 1500 CAD???
2020 M2C 24.04.2020 delivery - Sold 24.08.22
      12-18-2019, 07:54 AM   #25
Ggeezer
252
Drives: .
Check out Pneus en Solde in the east-end on the 40. A buddy of mine just picked up a brand new set of 19" wheels and tires for $2k.
      12-18-2019, 08:02 AM   #26
M2Cmtl
Yeah, did a quick search and the only cheap tires they have are "Northpole" brand and such...they have PA4s and such but they are actually more expensve than other places. I'm looking for real winter tires. Cheers.
      12-20-2019, 12:40 AM   #27
Lotus99
Lotus99's Avatar
628
Go with PMC Tire, that's who I'd recommend. I just got a set of 18" wheels and tires for my 2018 X3 for $2000, tax in! They only charge GST if you're outside of QC!
What's 50% of $2000? $1000...
$2000 + $1000 = $3000
Quick maths!
      12-20-2019, 06:39 AM   #28
M2Cmtl
Sadly the M2C requires 19 inch wheels...not many options. BMWs kit (641M) is almost 5k plus taxes...
      12-21-2019, 09:08 AM   #29
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Yowza, that's almost $800 more than I paid for mine in the states, considering the current exchange rate. My dealer did work with me a little bit though, got them for $200 over cost. Still waiting on the $75 rebate that came with them though.
      12-21-2019, 12:05 PM   #30
M2Cmtl
A member here got the 641M kit for 2690 USD from Sunmotors in PA. I'm kind of set of getting "real" winter tires (Nokian/blizzak/X-ice) but that's a decent deal. Tirerack's cheapest set if 2490 USD for PA4s with Flow F2 wheels...
      12-22-2019, 11:00 AM   #31
drewdq
Drives: 2020 M2C
Be careful. I have a 2020 M2C and picked up a set of 'recommended' wheels/tires from Tirerack - 19x9.5 FLOW ONE Race Spec F2 w/ 245/35R19 Michelin Pilot Alpin PA4. The front wheels rub when turning.
      12-22-2019, 08:32 PM   #32
Lotus99
Lotus99's Avatar
628
Nice looking wheels!
Wow, with a 22 offset, they stick out 13mm more than stock. Would love to see a shot from the rear of the car, to see how aggressive it looks. Hopefully all the extra stuff thrown up in the winter won't get too messy with that stance.
As far as the rub, I'm not surprised...
TIRE RUB
The tires I went with are 245/35/19 Michelin Pilot Alpin PA4’s (NEW: 10.5/32”). They rub a bit on the plastic fender wall on full lock, because despite being the exact same size as the OEM tires, they have a more square shoulder profile.
If you compare the two tires' Tread Widths, you'll see that too: The PA4's is 9.5" whereas the PSS is 8.8". It goes away after a few thousand miles of driving, and has caused no damage on the plastic.
      12-23-2019, 07:00 PM   #33
drewdq
Drives: 2020 M2C
They look pretty good, and don't stick out very much at all.
I ended up fixing the wheel rub issue by using a heat gun to meld the inner plastic fender guard/liner back enough to clear the wheel.
1) Removed wheel
2) Heated up the inner plastic liner around the spot the tire rubbed, and much of the larger surrounding area
3) Pressed the plastic guard outward from the center of the wheel hub to make more clearance
4) While holding, sprayed with cold water to set the plastic in place
5) No more tire rub
Appreciate 5
Lotus99628.00
QM287.00
Fabb228.50
wjones14658.50
      12-24-2019, 10:53 AM   #34
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
I almost went with those, but noticed the disclaimer at the bottom of their web site about rubbing. I called them, and asked the sales guy about it. He talked to one of the techs, and mentioned it was an issue at full turn. At that point, I decided to go with the BMW recommended set for peace of mind, even with the additional cost ($400)
The issue, from what I understand, is the 9.5 inch size with the wrong offset. The BMW recommended fronts are 8.5, so no issue there. Just not a lot of options available, unfortunately.
      12-24-2019, 05:26 PM   #35
Lotus99
Lotus99's Avatar
628
Never thought of that! Brilliant.
Sorry, that's wrong. Did you skip over the 1st and 18th (one year update) posts of this thread? I explained it all there... LOL.
      12-25-2019, 07:44 AM   #36
DriverDaily
Drives: M2 Competition
1) Removed wheel
5) No more tire rub
This is great info. How much clearance is there now after pushing in the liners? I'm hoping I can fit 265s up front just like people do with the original M2.
      12-25-2019, 08:32 AM   #37
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Sorry, that's wrong. Did you skip over the first post of this thread? I explained it there... LOL.
What's wrong? 9.5 won't fit without rubbing, but 8.5 will IF you get the recommended 641M's. Looks like you tried another 8.5, not the BMW ones, and had trouble with the brakes.
      12-25-2019, 12:55 PM   #38
NEfan508
NEfan508's Avatar
Drives: 2019 M2C
F: 8.5x19
R: 9x19 641m
235/35/19 same rubber
with mich alipn pa4 snows
Great wheel set for sure but why did I buy it when I'm in Florida now and it's parked for the winter back home?!?
Paid $2700'ish from Sun Motors in Pennsylvania (good deal imo)
penny wise dollar stupid...
      12-25-2019, 07:24 PM   #39
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Originally Posted by NEfan508 View Post
F: 8.5x19
R: 9x19 641m
same set I went with did you get the $75 rebate?
      12-25-2019, 07:27 PM   #40
Lotus99
Lotus99's Avatar
628
You have a serious reading comprehension challenge it seems. 641M wheels don't even come with 245 tires... And I never had any issues with brakes. We're talking about TIRE rub. Jesus.
Good luck to you.
      12-25-2019, 07:37 PM   #41
NEfan508
NEfan508's Avatar
Drives: 2019 M2C
F: 8.5x19
R: 9x19 641m
No I beat you, I got a hundred... 🤗
In November Rebate was $100, I didn't know about it until Brian from the dealer sent in the form to sign and email back, it was like a free dinner for me and Mrs. Miller
      12-26-2019, 11:52 AM   #42
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Good luck to you.
Perhaps you have dementia and don't remember what you even posted:
"The wheel we tried was 8.5" wide, with 35 offset, and while the clearance of the front brakes from the spokes wasn't a problem (so the higher offset was not an issue), the side of the rim did NOT clear the brakes unfortunately."
Sounds like an issue with brakes to me.
I'm fine I went with the recommended set and guess what I have no issue!
I'm also here to read helpful advice, not get in some pissing match, so I'll leave it at that
      12-26-2019, 11:53 AM   #43
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Good deal!
      12-26-2019, 02:43 PM   #44
drewdq
Drives: 2020 M2C
I didn't measure, but guesstimate I freed up almost ~1/2 inch from the liner high-spot with minimal efforts, and have ~1/8 inch of clearance when the tire is turned all the way. It's quite close, but no more rubbing.
Also picked up some nice bmw caps on the wheels now to make the wheels look a little bit more OEM
