M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > M2C Vorsteiner V-FF 101 Wheels set up
      10-02-2018, 04:35 PM   #1
HOT M
HOT M's Avatar
Drives: 2019 M2C
What do you guys think of this set up for M2C? will they fit?
Front- 5x120 / 19x9.5 / +22 Offset / 265-35-19 Hankook V12 Evo 2
Rear- 5x120 / 19x10.5 / +34 Offset / 285-35-19 Hankook V12 Evo 2
2019 M2C Sunset Orange/Black (Ohlins/swift coilovers, Ground Control Camber Plates, Dinan Heat exchanger, BM3 ECU tune, CF mirror caps, diffuser and rear spoiler, Vorsteiner V-FF 101 Patina Bronze wheels)
      10-02-2018, 10:17 PM   #2
HOT M
HOT M's Avatar
Drives: 2019 M2C
Anybody? Any ideas?
      10-03-2018, 07:58 AM   #3
twboy1999
Drives: 1994 honda accord
should fit
they are the same spec as
bbs fir for m4
they fit the m2
on stock tire size
2019 M2 HS 10000km and counting
HOT M80.50
      10-03-2018, 09:18 AM   #4
HOT M
HOT M's Avatar
Drives: 2019 M2C
Originally Posted by twboy1999 View Post
on stock tire size
Thank you for your response, Do you think these tires will not fit?
      10-03-2018, 10:14 AM   #5
mr_lab_rat
mr_lab_rat's Avatar
564
Drives: 2017 M2, 2018 X1
265/30 and 285/30 would be closer to the stock size
HOT M80.50
      10-03-2018, 11:06 AM   #6
Dogs63
Performance Attaché
Drives: 18 BSM M2
I'm currently waiting for my Vorsteiners to be completed. Virtually identical specs:
19x9.5 et 23 F
19x10.5 et 34 R
I plan on running tires as follows:
255/35 F
275/35 R
These are even closer to stock sizes with a more appropriate diameter differential.
HOT M80.50
      10-04-2018, 05:01 PM   #7
Vorsteiner_Info
Vorsteiner_Info's Avatar
188
Drives: bmw
They will indeed fit with no issues. We recommend a 245/35/19 however in the front and a 285/30/19 in the rear. Please let me know if you have any questions.
HOT M80.50
      10-25-2018, 08:03 PM   #8
Dogs63
Performance Attaché
Drives: 18 BSM M2
Wheels are here!
Better than I anticipated...
Appreciate 6
bentom2335.50
HOT M80.50
bollinm25.00
R0ME0518.50
Spare°257.50
JTO245271.50
      10-25-2018, 09:26 PM   #9
larry.beck
larry.beck's Avatar
2018 BMW M2  [0.00]
Nice looking ride!
///M2 - 2018 LBB DCT
      10-28-2018, 02:09 PM   #10
Dogs63
Performance Attaché
Drives: 18 BSM M2
Originally Posted by larry.beck View Post
Nice looking ride!
Thanks LB!
Trying to restrain myself with the whole "mod" thing.
But how do you argue with a fresh set of wheels?
      10-28-2018, 03:19 PM   #11
larry.beck
larry.beck's Avatar
2018 BMW M2  [0.00]
Nice looking ride!
[SIZE="4"][COLOR="Navy"]Thanks LB!
But how do you argue with a fresh set of wheels?[/COLOR][/SIZE]
You can't!!!!!
      11-01-2018, 11:07 PM   #12
bdogk
300
Drives: M2CS,M4GTS,'21-X3
Wheels are here!
Looks great.
I'm contemplating Vorsteiner V-FF 110 Wheels in 19's, 9.5" and 10.5", front and rear, respectively.
I know Vorsteiner recommends running 245/30 and 285/30's. I won't be lowering my baby since I need all the clearance I can get to clear my driveway. I'm thinking running the 30 aspect ratio will already lower the car.
What tire sizes did you end up using and any clearance problem?
      11-02-2018, 01:47 PM   #13
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
[SIZE="4"][COLOR="Navy"]Wheels are here!
Better than I anticipated...[/COLOR][/SIZE]
Those look fantastic. What wheel model did you go with? Any room for wider tires or was your setup maxing it out?
      11-20-2018, 03:57 PM   #14
Dogs63
Performance Attaché
Drives: 18 BSM M2
Went with the aforementioned 255/35 and 275/35.
So far no clearance issues and again, lowered on Dinan spring kit.
      11-20-2018, 04:08 PM   #15
Dogs63
Performance Attaché
Drives: 18 BSM M2
Thanks!!
Vorsteiner VFN 301 19x9.5 et23-F, 19x10.5 et34-R
I came up with the offsets to mimic the setup I had with the OEM wheels.
Was running 12mm spacers front and back and (IMO) was a perfect fit.
Stock clearances inside with a 12mm push outward.
There's probably room for wider, but I wanted to be comfortable with the clearance and wasn't interested in crazy camber or rolling/trimming fenders.
      11-25-2018, 02:39 PM   #16
HOT M
HOT M's Avatar
Drives: 2019 M2C
So the 265/35-19 don’t fit in the front they barely hit the front plastic. Would camber plates remedy this? Or just get new tires?
      11-30-2018, 08:03 PM   #17
Dogs63
Performance Attaché
Drives: 18 BSM M2
IMO, new tires. The 265's are more than .5" larger in diameter than OEM. Trying to "camber out" the wrong tires seems like a bad solution.
HOT M80.50
      11-30-2018, 08:52 PM   #18
HOT M
HOT M's Avatar
Drives: 2019 M2C
thank you i bought some 255/35-19
      12-10-2018, 11:55 AM   #19
HOT M
HOT M's Avatar
Drives: 2019 M2C
so 255/35-19 in the front barely clear with these wheels.
      02-10-2019, 08:42 PM   #20
HOT M
HOT M's Avatar
Drives: 2019 M2C
bentom2335.50
      02-11-2019, 03:26 PM   #21
bdogk
300
I'm waiting for tires to be put on my Vorsteiner 103's in 19x9 et21. To be safe on clearance should I run stock 245/35's or can I go with 255/35's up front on stock suspension setup?
      02-11-2019, 06:46 PM   #22
SConn
SConn's Avatar
I just ordered the 103's and went with the 245/35 and 285/30 as Vorsteiner suggests. Especially with the Michelin tires that sit a bit wider anyway. This combo keeps the same height front to back as well. Stock actually runs a little higher in back.
2018 LBB M2 LCI
