08-30-2018, 05:15 AM | #1 |
Rep 103
Bm3 stage 2 93oct vs mhd stage 2+
Hello friends, I would like someone to tell me which one does more hp? 100-200 times? What is the most aggressive melody? Thank you!
08-30-2018, 09:01 AM | #2 |
Rep 2,577
From recent logs I've read, MHD STG2+ is more aggressive, but that does not mean more power. It all comes down to the octane support. You will need RON100~102 to properly do it.
BM3 STG2 is made for RON98/AKI93 with adequate cooling upgrade. But if you have access to RON105~109 or Ethanol on a regular basis, you can do BM3 race gas or E30 map, which is more powerful than all said above.
Lemania 2320
08-30-2018, 10:39 AM | #4 | |
Rep 2,577
Keep in mind High quality gas isn't high octane. I can tell you 98RON don't even handle 98RON map well if you do back to back multiple gear pulls and/or IAT goes to triple digit which is normal. 100+ map would throw your ignition all over the place and even your butt dyno would tell car's running like shit. Flash tune is no piggyback. There is no fixed boost target set with either bm3 or MHD, it all depends on IAT. MHD crack up boost as high as possible low down, while BM3 more and more tend to make flat torque plateau revision after revision. It's up to your taste. You need to go either BM3 stg2 98 map or mhd 98 map (stg2 no plus).
Lemania 2320
08-30-2018, 02:03 PM | #6 | |
Rep 4,529
Current '22 X3M LCI.. |
08-30-2018, 09:36 PM | #7 | |
Rep 2,577
For example, when I was on Dinan Turbo one year ago, it put down "glorious" 414whp on RON98 on a dynojet where M4 ZCP stock didn't even break 400 on the same day. The ambient was as cold as 50F, the 5th gear pulls can hardly heat IAT up to above 80F. 4 cylinders out of 6 saw timing capped out at 10 degrees up top and the other 2 had just minor corrections, a sign of running on the edge already. However, on hotter days and when IAT gets above 90F, it shows more corrections and power loss, definitely need higher octane to support. My point is you can find very ideal condition for a low octane to run well on an aggressive map, but that doesn't change the fact the map isn't made for it. You really need to push hard in summer. Log repeated multiple gear pulls, see how it's holding up at IAT 120F. Under that condition the most of aftermarket tunes cannot even live up to their map octane claim.
Lemania 2320
horsepower_and_hounds1843.00 bm3nyc56.00 |
08-31-2018, 04:06 AM | #8 | ||
Rep 4,529
I've concluded that mhd leave a fair bit of safety margin even in stg2+ compared to BM3 stg 2.....
08-31-2018, 08:45 AM | #9 |
Rep 473
Running MHD stage2+ 102 Map!!
I only have 98ron but add 4ltrs to a tank for additional fueling without effecting fuel pump pressure. Log attached with 100-200 times of low to mid 9's. https://datazap.me/u/mattspies/log-1...30-31-32-33-34 https://datazap.me/u/mattspies/log-1...30-31-32-33-34 https://datazap.me/u/mattspies/log-1...34&zoom=39-183 |
09-01-2018, 06:39 AM | #10 | |
Rep 4,203
09-01-2018, 06:41 AM | #11 | ||
Rep 473
Wagner FMIC EVO Comp!! |
horsepower_and_hounds1843.00 |
09-02-2018, 02:47 AM | #13 |
Rep 473
09-02-2018, 01:47 PM | #14 |
Rep 709
09-03-2018, 12:43 AM | #15 | |
Rep 4,529
The usual stg2 bolt ons ie DP, CP and FMIC BP
09-07-2018, 11:07 AM | #16 |
Rep 328
BM3 Race Gas Tune is the shizznizzle, fill up with 93 and add 1-32OZ can of Torco Accelerator for an octane rating of 103+
I've been running this tune for 5000+ miles, no issues, great logs. 398/466 at wheels, I'll post 100-200 times via Dragy soon. PS2 next upgrade |
4
09-07-2018, 05:34 PM | #17 | |
Rep 473
09-09-2018, 10:20 PM | #18 |
Rep 328
09-10-2018, 08:43 AM | #19 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
09-10-2018, 04:51 PM | #20 | ||
IG @bmwF9xG80
3817
Rep 7,595
It says it in his link first post https://f87.bimmerpost.com/forums/sh....php?t=1506904
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 Last edited by FSociety; 09-10-2018 at 09:21 PM.. |
09-11-2018, 02:22 AM | #21 | |
Rep 1,348
09-13-2018, 04:27 PM | #22 |
56
Rep 55
Drives: F90 M5,F85 X5M, F15 X5, F80 M3
We just flashed STG2 93oct OTS on a M2 customer
Contact US @bootmod3nyc on IG
CTS Turbo Intakes/Downpipes/Chargepipes N55/B58/S55 | Lusso F90 M5 Downpipes/Intakes/Midpipes| Bootmod3 N55/S55/N63TU/S63TU Dealer ! |
FSociety3816.50 |
