08-17-2018, 09:50 AM | #1 |
Rep 409
Newb question... simplest way to make my car sound better?
Hi all,
I recently picked up a 2015 335i X-drive M Sport. It sounds pretty good inside the cabin but I would like it to sound just a bit more "sports car". Nothing obnoxious, just a bit more growl. What is my easiest option that is also "budget friendly"? Thank you in advance for your input.
2015 335i X-drive, Black Sapphire Metallic, M Sport package LOADED. MPE/VRSF Charge Pipe/BM3 Stage 1 93 Octane
08-17-2018, 10:22 AM | #2 |
Rep 279
Resonator delete. Won't be much louder, but if your auto, you'll hear the shift burble a bit more.
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
08-17-2018, 10:54 AM | #3 |
Rep 63
Catless downpipe with stock exhaust is a great option. Sounds almost stock except at cold start and WOT on my M235i. You just need BM3/JB4/MHD to suppress the CEL from going catless, or look into a high flow cat.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless 2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30 |
08-17-2018, 11:00 AM | #4 |
Rep 1,295
High flow cat HJS in europe or fabspeed in US (same inside) will not throw CEL but improve sound, not sure if you'd consider that budget friendly though.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
reddemon73103.00 |
08-17-2018, 12:01 PM | #5 |
Rep 409
Not looking to spend $1300 on a HF cat. just too much $$$.
Any other suggestions? I don't want to throw codes etc.
08-17-2018, 12:08 PM | #6 |
Rep 2,319
08-17-2018, 01:11 PM | #8 |
Rep 1,105
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
08-17-2018, 04:41 PM | #9 |
Modder of everything I own
147
Rep 491
Downpipe and resonator delete for sure, it did it for me!
ooops, downpipe will throw codes. I would do the resonator and muffler delete then.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
08-18-2018, 05:31 PM | #10 |
Rep 409
I've read muffler delete causes awful drones on highway at 2K rpm and less. I can'd deal with that as I do a ton of hw driving. Perhaps just a resonator delete?
08-22-2018, 09:18 PM | #13 |
Rep 928
CG precision catted downpipe and resonator delete no codes and sound a lot better. ECS tuning has the downpipes for 640.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
08-23-2018, 10:55 AM | #14 |
Rep 552
Pick up an axelback then get a resonator delete. You probably won't be satisfied enough with just a res delete and stock exhaust. I picked up a used MPE and it added a nice growl. Res delete is next for me.
08-23-2018, 11:17 AM | #15 | |
Rep 409
MPE is where I think I'm headed.
yoon_209368.00 |
09-19-2018, 10:05 AM | #16 |
Rep 25
Newb alert**
Hey guys, I have a 320 xDrive with jb1 tune. I deleted the resonator and it sounds pretty nice but I want to give it a little more roar/gurgle/crackles. I don't want to muffle delete because I think that is to much going into school. People suggested a Highflow downpipe but i don't know anything about it. Does anyone know the negatives about getting one? ie: engine light, legality, dangerousness to the car. Thank you. |
09-20-2018, 11:15 AM | #17 | |
Rep 552
Disadvantages: voids warranty for a number of components, strong smell of exhaust, check engine light on (some tunes can remove this). You will fail emissions test/inspection in most states and have to remove it beforehand. You have the option of running a catted downpipe to avoid some of this, but they are more expensive. Other reasonable options: have a custom exhaust built /w magnaflow (or something similar) or purchase an axelback |
09-20-2018, 08:59 PM | #20 |
Rep 282
Try opening the exhaust flap (basically forces the one side of the exhaust that has a valve to be open all the time). It won't make the same noise as a cat less or new exhaust, but it's free to do...
This assumes you have a dual exhaust... |
09-24-2018, 06:37 PM | #22 | |
Rep 1,063
The only ones I'm aware of for the N55 are the Wagner w/ the EUR6 and Fabspeed. I don't even know if they make N20 versions. |
