07-31-2018, 06:47 AM | #1 |
Rep 180
Boost leak issue
Hey guys so I'm having a boost leak issue and I'm wondering if I botched the install of the dv+. I was having a boost leak issue for a while then I got smoke tested and said my chargepipe to intercooler connection is the cause of my boost leak. So then I found out the person who installed me intercooler forgot to put the O-ring in the chargepipe to intercooler connection. So I fixed that and then in that same session I installed the dv+. And I'm still having a boost leak issue. I figured it had to be the dv+ because if I fixed the issue of the chargepipe to intercooler then it has to be the dv+. I don't wanna pay for another smoke test and also to busy to take it to the shop so I figured I'd ask you guys. I also hear a flow of air that I never heard before from what sounds like where the dv+ is located. Here is a log too Incase it helps. Appreciate the help.
http://www.bootmod3.net/log?id=5b5a073cd10b43626a89d103 |
07-31-2018, 08:01 AM | #2 |
Rep 1,499
I don't see a boost leak from the log. Largest boost target to MAP pressure delta is only 1 PSI.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
07-31-2018, 08:07 AM | #3 |
Rep 180
Maybe I don't have one but reason I say I have one is because when I had the boost leak for sure my engine had a rough idle. And it stutters at low rpms. And after I fixed it. It still does it. I been having this issue for a while and can't seem to figure it out. It started happening after I cut my mufflers off but I had a boost leak before that so I though cutting the mufflers off made the symptoms of the boost leak worse but maybe it's a vacuum issue I don't know. I'm been going crazy trying to figure this out
07-31-2018, 08:09 AM | #4 |
Rep 1,499
What plugs are you running?
07-31-2018, 08:11 AM | #5 |
Rep 180
07-31-2018, 08:51 AM | #6 |
Rep 180
07-31-2018, 01:51 PM | #7 |
Rep 1,499
Do you have an aftermarket intake? If so put the stock one back on. If you still have the problem then gap your plugs to 0.024".
07-31-2018, 02:15 PM | #8 |
Rep 5,776
Were you having the issue before the dv+ install?
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
07-31-2018, 02:30 PM | #9 |
Rep 180
07-31-2018, 03:41 PM | #10 |
Rep 5,776
Hmm..not sure. No codes? The variable, as you said is that it started after cutting off mufflers, but that would not seem to cause stuttering or rough idle unless you bumped something loose somewhere.
07-31-2018, 03:44 PM | #11 | |
Rep 180
08-01-2018, 07:00 AM | #12 |
Rep 180
Update. Chargepipe meth bung was still loose I tightened it car runs better but wastegate duty cycle is still way too high so the leak is still there. I also smoke tested the bms intake which smoke was coming out from the maf sensor(smh) lol. Today I will put the car in the air and check under the car to cancel out the diverter.
