07-24-2018, 04:23 AM | #1 |
Rep 71
forgot to install black cllp on turbo to intercooler pipe... bad?
So i forgot to reinstall that annoying black clip on the turbo to intercooler pipe after installing my FMIC. How worried should I be about leaks coming from that connection. Do I really need to tear the car apart again and put that piece on?
07-24-2018, 07:28 AM | #3 |
No 55mph
1622
Rep 8,477
NO
Hopefully you installed a quality aftermarket Charge Pipe at the same time
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
07-24-2018, 08:17 AM | #5 |
A family of bimmers
2757
Rep 7,743
That clip helps hold the metal clip fully on. it wouldnt be much to drop the cover and put that on just on that side. Id want to go back and put it on but thats just me. for peace of mind
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-24-2018, 08:36 AM | #6 |
Rep 5,458
Drives: F30
Im wondering what annoying black clip you are talking about (and if I reinstalled mine)... any chance you could post a pic?
07-24-2018, 08:48 AM | #7 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
Sounds like the OP is referring to the black plastic "locking" clip that holds the ends of the metal "circlip" in place. Probably not necessary, but wouldn't hurt to put it back on.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-24-2018, 09:05 AM | #8 | |
Rep 5,458
Drives: F30
Pretty sure I broke them when removing from factory pipes. Anyone have a part number? For a few bucks, I may pick up a pair and reach in to snap on. That being said, Ive had zero issues since install which has been at least a few thousand miles. |
07-24-2018, 09:33 AM | #9 |
Rep 942
Every diy I’ve seen on fmic, I’ve never seen anyone re-install that black plastic piece. Most of the time it breaks in the removal process. As long as the metal C clamp is in all is good.
07-24-2018, 09:38 AM | #10 |
Rep 38
screw that little black clip..
sspade2468.50 the dope steez404.00 |
07-24-2018, 10:45 AM | #11 | |
Rep 5,458
Drives: F30
07-24-2018, 11:01 AM | #13 |
Rep 5,458
Drives: F30
I understand its purpose. I would think you would have to be off-roading your car for it to be jolted out of position. Anything is possible though.
07-24-2018, 11:18 AM | #14 |
Rep 942
🤦*♂️ even the different fmic companies say you don’t replace the black plastic. It’s German engineering. Some things over engineered (clip plus black plastic) and some things under engineered ( plastic charge pipe ).
