F30POST
F30POST
2012-2015 BMW 3-Series and 4-Series Forum
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > CEL from charge pipe install?
Studio RSR
      07-23-2018, 07:32 AM   #1
rbol13
Drives: 2014 335i M Sport
Hi, had an ER charge pipe installed and after going going 4/5ths WOT had the CEL come on, contacting the shop today as I assume there is boost leak or something but just wondering if this can happen like how a DP can throw a CEL but not be malfunctioning.
Thanks
      07-23-2018, 07:38 AM   #2
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
I just changed out my broken OEM unit for a VRSF unit, with zero issues. Some possibilities:
1.If your pipe is a 2-piece unit, the silicone "connector" may not have been properly positioned or the clamps may not have been tight enough, resulting in a boost leak.
2. If the car's electrical system wasn't "asleep" when the TMAP sensor was disconnected, that will definitely throw a code and a resultant CEL.
3. The "bung" plug(s) may not have been fully tightened (the one on mine wasn't), also resulting in a boost leak.
4. Check that the collar that goes around the throttle body is pushed all the way on - there should be only a very small gap between the top of the pipe and the mating surface on the throttle body.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
wdeerfield2757.00
maxio19.00
rbol1323.50
      07-23-2018, 01:25 PM   #3
alohasurftoad
Drives: 440i gran coupe w/mppsk
If you re-used the OEM o-rings, check their orientation.
rbol1323.50
      07-23-2018, 02:04 PM   #4
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
I have an ER on mine. When I first put it on I did not tighten the silicone part tight enough and on a test run it came off. No CEL or codes but I know the feeling when a CP comes off. You might want to check the codes--could be an issue with the Tmap--sensitive part. Did the car feel normal?
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
rbol1323.50
      07-23-2018, 02:20 PM   #5
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
what code is it throwing?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
rbol1323.50
      07-24-2018, 07:32 AM   #6
rbol13
Hi all,
The car felt almost normal, maybe it was placebo but I swore it had slightly slower throttle response.
Took it in and there was a hose that had a kink in it, and they corrected it. Car appears to be all good now, no CEL and I made sure to give it WOT a few times to test if anything is loose.
Thanks again for the responses! Great community here!
f30post
