06-13-2018, 09:19 PM | #1 |
Rep 391
Belt blew and now oil leak - added pics
So at my first autocross event on weekend, on 4th run I heard a very loud pop under the hood. Pulled off track and checked under hood. Belt fuzz everywhere. But about 20 percent of the belt was still intact and would work on the pully’s. so a partial blow? Anyways, some of the cords must have either hit something or wrapped on main pulley and took out crankcase seal on front of engine. As I now have an engine oil leak. I can’t see where it’s coming from but it’s hitting the main pulley and getting nicely distributed everywhere. It only leaks when running and is very minor at this point, but probably could get worse or if belt fragments get sucked into timing chain, which could alter timing or the fragments could block the oil pan suction intake, then the engine could grenade.
I have an appt at my local tuner shop next week for diagnosis. yes I’ll be putting it on a truck to get there as it’s not worth the risk of more damage. 28,000 kms on it. I won’t take it the dealer as there’s a bunch of mods on it, and I don’t really feel like pushing on warranty (in my world you have to pay to play, and I’m fine with that). Anyone have any similar experience with this happening?
17 M2 AW, DCT, black grills, eventuri, bm3 Stg 2, csf intercooler, Fabspeed sportcat, AA charge pipe, 285r/265f pss, 285/30r18 re71r’s square apex 10x18, and smooth riding TC Kline coil overs with a very heavy throttle foot.
Last edited by Drop the hammer; 06-16-2018 at 01:36 PM.. Reason: Added pics to thread |
06-13-2018, 09:27 PM | #2 |
Rep 391
Or any n55 guys know if I’m on the right track? Engine can fire right up, and idles fine. Codes that were thrown were lean condition and extreme lean condition. Was running Fabspeed sport cat, eventuri, and bm3 stage 2 on 91. I think the code is unrelated to the tune, belt blowing and oil leak, I think it was caused by lots of wide open to off throttle to on throttle on the track and the eventuri intake. I’ve cleared codes, and retuned back to stock tune at this point. Car booked into shop for Tuesday.
06-13-2018, 09:33 PM | #3 |
Rep 391
Leak is very small as well, I did the oil level test and during the test it leaked a 2 inch diameter spot on the ground. Oil still shows full. And leak looks like I haven’t lost much oil at all. Sitting for the last 3 days it hasn’t dripped any oil either.
06-13-2018, 10:48 PM | #4 | |
Rep 258
Fragments blocking the oil pan suction intake? Dont know what part you’re referring to, but if you’re asking if it would get picked up by your oil pump/related components, that’s also nearly a 0.00% chance. The minor oil leak you have is most likely due to the belt pulling a small oil-related hose from where it was attached. Should be a simple belt replacement and reattachment/replacement of a hose. |
06-14-2018, 10:57 AM | #5 |
Rep 391
I really hope so. The crankcase seal is directly behind the crank pulley and wrapping belt cords around it can push the seal into the engine, which can then cause seal to contact the timing chain, that grinds up the the seal into fragments and they get washed into the oil sump and can block the suction. That’s what I was meaning. I agree that Slim to no chance of actual pieces of belt could make it past the seal area unless the seal was completely pushed into engine. Also I suppose it could be dct oil as there’s lines running down there too that could have been hit. Wish I had a lift to look from under and remove pan.
06-14-2018, 09:47 PM | #7 |
Rep 2,448
Keep us posted on what the shop says. Hope it's nothing serious.
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
06-14-2018, 11:23 PM | #8 |
587
Rep 898
Pictures would be nice. This is the first time i've heard of a belt failure on the M2 N55. Hopefully it's not the crank hub... though very unlikely.
Looking forward to updates.
06-15-2018, 11:15 AM | #9 | |
Rep 3,949
06-15-2018, 02:18 PM | #10 |
Rep 391
I have a few hours tomorrow to inspect it and get it onto jack stands. I’ll take some pics. The belt looks hilarious as only a thin strip remains intact. Looks like the belt only runs the ac and alternator. Anyone know what the dct oil smells like? Is it similar to the typical red atf fluid?
06-15-2018, 04:22 PM | #11 | |
587
Rep 898
06-15-2018, 08:51 PM | #12 |
Rep 391
Some pics from top
06-15-2018, 09:04 PM | #13 |
Rep 391
I tried to get other photos buts it’s tight for the phone to squeeze in there from the top. Most of the oil seems to have come from the crank pulley and radiated outwards.
06-15-2018, 09:05 PM | #14 |
Rep 391
Definitely engine oil
06-16-2018, 01:33 PM | #15 |
Rep 391
Dropped the pan off bottom and found the remnants of the rest of the belt and underside is soaked in oil. Few more pics. I think I’ll take her in to dealer as I can’t see where it’s coming from. Fingers crossed that it’s a minor repair.
06-16-2018, 02:04 PM | #16 |
Rep 3,695
Damn, hope it’s an easy fix.
A buddy of mine that races PWC TC in a M235ir had a serpentine belt failure at a recent race. Anyone else heard of this happening with the N55? |
06-16-2018, 04:04 PM | #17 |
Rep 391
It’s a big mess with oil film everywhere. I can’t handle anything leaking on my floor. Why I was hesitant to pull the bottom pad.
06-17-2018, 05:09 PM | #18 |
587
Rep 898
Jesus christ, that doesn't look fun. Hopefully this is a fluke incident and not anything serious.
If it's leaking oil you definitely have a crank seal issue. Not too bad of a fix as long as the crankhub didn't slip.
06-18-2018, 03:35 PM | #20 |
Rep 391
Truck is on its way over to pick it up now. Fingers crossed that it’s just the crankseal and belt to repair. Another autocross event this weekend, hopefully she’s up and running by then!!
New to autocross, but wow what a rush, I’ll be a regular in the future. |
06-18-2018, 05:34 PM | #22 |
Rep 1,718
What a mess! Looks sort of like a bird getting sucked into a jet engine...POOF!
Hopefully nothing too major and just looks worse than it is. Interesting to see what the shop says. GL |
