05-31-2018, 07:27 PM | #1 |
96
Rep 144
TTFS| Introducing N55 HPFP Single Pump Upgrade
While the factory fuel system is adequate for stock vehicles these engines quickly run out of fuel with even basic performance upgrades. To help combat this, we are introducing the first High Pressure Fuel Pump (HPFP) for the N55 direct injection engines! Our extensive work with Xtreme-DI has revealed this pump can expand the tuning and performance opportunity of your N55 motor. This is a complete bolt on upgrade and comes with everything needed to make installation a breeze. As you know the price can not be posted here, but it is far lower than our dual pump setup which has a higher fuel capacity.
The installing of the pump is fairly easy but, it must be accompanied by our custom base tune to work correctly which, is included with your purchase and you can use our tuning services for performance tuning or have your preferred tuner take your N55 to the next level with this brilliant upgrade! Maximum Flow Rate: 195LPH @ 7000rpm Maximum Rail Pressure 200bar / 2900psi (like OEM) Fuel Compatibility: all known fuels, all Ethanol blends Mechanical Data Geometric Pump Capacity 1.22cc (OEM = 0.897cc > +36% capacity) After doing our own R/D testing we decided to ask an old time friend and industry leader Active Autowerke to do some independent testing and here was their results with an M235i with a Pure Stage 2 (PS2) and our pump on a mustang dyno. As you can see from the data it is supporting 425 wheel horse power and 500 wheel torque on a mustang dyno with pump gas only. Independent Testing Done at Active Autowerke Last edited by TuningTech FS; 05-31-2018 at 08:43 PM.. |
8
Yiruna393.50 ZM22783.50 PiK61.00 alscks0414689.00 mishutka16.50 NO_USER_537.50 m2rs4_official95.50 5thGearPinned63.50 |
05-31-2018, 07:56 PM | #3 |
96
Rep 144
In case anyone is wondering tuning is available by BM3 and MHD with out a need for our base tune for faster service. All our dealers can also provide the tuning services provided by us. http://tuningtechfs.com/ttfs-dealers/
05-31-2018, 08:42 PM | #6 |
Rep 934
Does this flow enough to run Full E85 with a Pure Stg 2?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
05-31-2018, 08:49 PM | #7 |
96
Rep 144
You would need the dual pump for full E85, but it is going to get you ways further than your stock pump. If you are on a budget build E85 with Ps2 then it is worth the move since it is much more consistent than some other alternatives.
05-31-2018, 10:37 PM | #8 |
Rep 2,828
pm price
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
TuningTech FS95.50 NO_USER_537.50 |
06-01-2018, 09:29 AM | #9 |
Rep 168
Post price
Edit: http://tuningtechfs.com/ttfs-n55-hig...p-single-pump/ Need to get some competition in this category. |
06-01-2018, 10:50 AM | #10 | |
Rep 415
Thanks |
06-01-2018, 07:21 PM | #12 | |
96
Rep 144
Sent! Quote:
Pm Sent. |
06-01-2018, 09:28 PM | #13 |
Rep 2,828
lets see some numbers with stock trbo on a m2 please!!
06-01-2018, 10:52 PM | #14 |
BMW Fanatic
331
Rep 1,076
Please PM price.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
06-02-2018, 03:27 PM | #18 | ||
Rep 599
Drives: M2, C63s, 718 Cayman GT4
2018 MG M2 - Ohlins R
M2C_PLUS1774.00 |
06-02-2018, 03:41 PM | #19 | ||||
Rep 599
M2C_PLUS1774.00 |
06-02-2018, 07:07 PM | #20 | |
96
Rep 144
Also remember those numbers are to the wheels. Not to the crank! Try finding another N55 with a different fuel setup that is making 493 wheel torque on a mustang dyno which is about 550 wheel torque on a dynojet. The turbo is capable of making the power but proper consistent fuel delivery is key. |
