04-28-2020, 05:37 AM | #309 |
Rep 3,334
You can see a range of pads on Dave Zeckhausen's website. Make note of his useful comment at the top on rear pad factory shim design.
Current Stable:
MR RIZK757.50 |
05-11-2020, 03:09 PM | #311 | |
Rep 219
Unfortunately, no. Though I believe the closest shade is Limerock Grey, but it's not 100%. As an alternative, I wanted Polar Blue to match reupholstering and stitching I've been doing in that thread. However, while it's a thread color, they didn't have it in paint, so I went with a blended Atlantis Blue Metallic. Contrast on Space Grey is actually quite good.
2011 E90 M3 | Space Gray | RKP CF Roof | MPerf Recaro | Full Interior CF & Alcantara | BMW MPE v2, MS Test Pipes | BPM Tune | MFactory CF DS | Bilstein B6 Damptronic | Full DINAN & Eventuri & DO88 | Modesta BC-04 | Potenza RE-71R
2020 X3M 2020 Range Rover Sport SVR |
08-26-2020, 04:42 AM | #313 | |
Rep 4,515
Yes - as far as geometrically/size/mass all same grey/red/gold. No - gold ccb calipers have high temp internals to suit elevated ccb operating temps ie titanium pistons and better seals/dust boots. CCB pads are slightly different - compound to suit ccb and shape with large surface area
Current '22 X3M LCI.. |
08-26-2020, 05:11 AM | #314 | |
Rep 64
08-27-2020, 04:22 AM | #315 | ||
Rep 4,515
Txipi8411.00 |
05-24-2021, 10:19 AM | #316 | |
General
21115
Rep 20,741
Drives: 2021 911 turbo
Reference: https://www.essexparts.com/news-blog...m2-competition
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
01-01-2022, 05:09 AM | #319 |
Rep 14
I have issue after brake changing.
So my car is stage 2 tuning. And i asked bmw dealer to change M performance brake(red brake). the dealer said the tuning file is gonna be lost and the car will be standard file after coding the brake pressure. And after it all was done, my car has drivetrain notification. the dealer said, i need to coding the tuning file. But after i coding the tuning file, the car still have drivetrain. So i took bimmerlink it shows 2 error code. 1. D90D37 interoir light unit, incorrect variant install 2. 1f2108 DME, incorrect data record: variant monitoring my tuner said i need to ask the dealer for fixing the error code but the dealer said he afraid that i need to pay extra cost if the bmw offer to change some engine car’s components which i don’t have much knowledge about the engine of n55. My car has not anything broken before changing the brake. I need some advice. What should i do now?�� |
01-01-2022, 10:45 AM | #320 |
Rep 3,842
I've been getting the interior light error code since my car was new. I can clear the code but it just comes back. AFAIK it doesn't hurt anything.
DME incorrect data error code happens when there is a flash tune. I don't think it causes any effect. The only way to get rid of it from my experience is to flash back to stock. If you are talking about a light on the dash drivetrain malfunction, I don't think it would be necessarily connected to the error codes because they are very common. |
01-01-2022, 02:46 PM | #321 | |
Rep 14
i will ask my tuner for flash back to stock if it successfully works, i will update to you |
01-01-2022, 02:58 PM | #322 |
Rep 8,970
Brake changes have no need for DME mapping. The BMW dealer is talking BS.
Put your stage 2 map back on. Obviously warranty is not an issue for you so tell BMW to get lost. |
01-03-2022, 03:03 AM | #323 |
Rep 14
01-03-2022, 07:22 AM | #324 |
Rep 8,970
01-03-2022, 11:46 AM | #325 | |
Rep 3,842
To get rid of the data error with the ECU, it may need to be relocked. Relocking (BM3) and clearing all error codes is always a good idea before going in for a service. Of course if the car is bench unlocked relocking isn't an option. The interior light error code will not go away even if it's cleared in my experience. The data error must be cleared after flashing stock tune. It won't go away by itself. I've seen it cleared with Carly. |
01-03-2022, 12:21 PM | #326 |
Rep 8,970
You really need ISTA for diagnostics.
Agree you have to "clear" the faults, they don;t just go away by themselves. Is there a "drivetrain fault" dash indication? Limp mode CEL etc? |
01-04-2022, 03:22 PM | #327 |
Rep 14
The dash indicator is not show up any fault. but show up on screen.
Url of the error screen https://www.img.in.th/images/903cb70...7f501be715.jpg I asked for advice from another garage service. they said if the Ecu box is not lock for flashing to stock, they can fix it. If its locked, they said i need to buy new ecu box and they will install the original stock tuning file. it cost around 2000$ 😭 |
01-04-2022, 03:27 PM | #328 | |
Rep 14
Do you to the bootmod3 right? My car didn’t use bm3 for tuning. my tuner use ecutek. the drivetrain is show up on the dash screen here https://www.img.in.th/images/903cb7051b22f93c0420b37f501be715.jpg |
01-04-2022, 03:28 PM | #329 | |
Rep 14
01-04-2022, 03:34 PM | #330 |
Rep 3,842
If your car was built before March 2019 it can be locked and unlocked at will through the OBDII port. If it was built before July 2020 it can be bench unlocked. The only ones that need a new (old) ECU are cars built after July 2020.
There could be something else wrong with your car having nothing to do with the tune. |
