01-05-2018, 04:24 AM | #1 |
Rep 4,515
N55 HPFP upgrades coming soon....
TTFS - OE S55 dual HPFP setup - will require tune/coding to get S55 secondary pump to work
https://www.facebook.com/TuningTechF...18218138223616 XDI - non OE PnP HPFP upgrade also due out soon too http://www.xtreme-di.com/index_files/HPFP35.htm
Current '22 X3M LCI.. |
01-06-2018, 11:27 AM | #5 |
Rep 4,515
Nice one - keep us posted ??
01-08-2018, 02:47 PM | #6 |
24178
Rep 190,750
Sub'd
NO_USER_537.50 |
01-09-2018, 01:22 PM | #7 | |
Rep 238
Sub'd. Curious to see how the price of this compares to the port-injection alternative.
However, Fuel-It does have an "indirect" solution - port injection. Should run you about $1700 - $2000 for the LPFP and port injection kit and that'll solve the crashing HPFP issue.
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
01-09-2018, 08:24 PM | #9 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
LPFP doesn't crash like the HPFP does. maybe an upgraded LPFP would be required when going beyond the stock turbo, but the HPFP seems to be the weak link right now to making big, reliable power. look at how the HPFP pressure dips by over 1000psi, but LPFP remains constant in my datalog
BeemerBoost118.00 |
01-09-2018, 08:49 PM | #10 | |
Rep 3,695
This is a completly different issue, tho, than the HPFP crashing under heavy boost and fuel load. |
01-09-2018, 10:17 PM | #13 |
Rep 238
Correct. Fuel-It recommends a "Stage 2" LPFP if you plan on running Port Injection with a bigger turbo. A bigger LPFP helps supply the demands of the HPFP while still being able to supply the port-injectors with their fuel demand.
01-09-2018, 10:30 PM | #14 |
Rep 3,695
01-10-2018, 04:58 AM | #15 | |
Rep 960
It’s interesting that it just falls off. It definitely seems like failure... Surpised it drops that much. Is it normal for the fuel pressure to drop and just stay there if it’s the hpfp failing? Last edited by Bt12; 01-10-2018 at 05:32 AM.. |
01-10-2018, 07:50 AM | #16 |
Rep 2,523
Subscribed!
01-10-2018, 04:04 PM | #17 | |
Rep 67
It took a couple of weeks, but now the firmware is available, and now is running on my car. Not sure if the issue has been fixed - still have more than 1/4 and below 1/2 tank, but we will see. The I-Step version with the fix is F020-17-11-540. |
01-10-2018, 04:18 PM | #18 | |
Rep 3,695
Dinan’s “hardware” fix cured my issue, so I question if BMW’s “software” fix would. I guess we’ll hear soon enough. |
01-10-2018, 05:24 PM | #19 | |
Rep 2,577
I had two HPDE last year on SH F1 circuit, a very horsepower demanding track - you'll reach factory speed limit point on straight no problem if you have 500+hp. On FBO + STG1 turbo, I was making no less power than most of stock turbo build that I assume. Pretty sure I was below 1/2 tank all the time (lowest being 1/4~1/5?). I am not a pro racer but I was hard on throttle. No issues whatsoever.
Lemania 2320
FSociety3812.50 |
01-10-2018, 06:21 PM | #20 | |
Rep 3,695
I found tracks with more on/off throttle application make the issue worse. The SH F1 circuit is a very wide track relative to most HPDE tracks and has more WOT throttle application vs shorter bursts of on/off throttle. The more aggressive the driver also makes the issue worse. |
01-11-2018, 03:19 AM | #21 |
Rep 2,357
Then N55 does not have a LPFP sensor so I dont know what that value being logged is...
I have seen 900psi in my logs without any CEL or hiccups.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
FSociety3812.50 |
01-11-2018, 09:49 AM | #22 |
Rep 168
Like all other similar ecus (MEx17’s) it’s calculated LPFP (very bad way of determining problems). I can tell you from my experience in the VAG world, when the lpfp starts to run out of juice the HPFP falls straight on its face. When this happens the ecu will still show lpfp has having enough pressure, due to no sensor.
