BMW M2 Forum > M2 Photos, Videos and Builds > M2 slim edition
      11-21-2017, 12:21 PM   #1
Peter_VIE
Austria
136
M2 slim edition
BIMMERPOST
     Featured on BIMMERPOST.com
I am modding my M2 towards a lighter track tool, below the current status and mods:
Wagner Evo I.C.
Acrapovic exhaust
HJS 300 cell cat
BMC intake filter
M Performance suspension + 2-pcs race springs on rear
steel brake lines
Endless MX 72 rear & 22 front
Recaro Pole Position seats
rear seats removed & carbon separation/cover
GTS gearbox software
Liteblox battery
Brake cooling on front
HRE 101 LW 19'' & Cup2 Semi
weight w full tank, no driver 1.485 kgs
weight allocation 55 front / 45 rear
still on the to-do list:
- camber plate & strut bar
- Carbon bonnet
- aworkx flash tune
Appreciate 23
      11-21-2017, 01:26 PM   #2
MerlinPurple
MerlinPurple's Avatar
Drives: M2 LBB
seeing the csl badge gives me the shivers, looks right on the M2
Appreciate 5
      11-21-2017, 02:30 PM   #3
lax01
Drives: 2017 M2
damn so 3300 lb with rear gut, wheels, race seats...no cage...so back up to 3400-3450 with cage
Any other weight reduction planned? You gut the trunk?
      11-22-2017, 02:28 AM   #4
AK.Alexx
Belgium
43
Drives: BMW M2 on order
Very nice! From which company are the front brake cooling?
a4nut84.50
JustChris10387.00
      11-22-2017, 06:37 AM   #5
alexc93
Drives: M235i
I'm sure there's still some weight to be shed (roof mainly), but great build!
May i ask why you didn't go with an 18" setup if weight saving was the goal?
2014 M235i || 8ZF || Black Sapphire Metallic || Black Dakota Leather
|| 30% Llumar CTX || IND Front Reflectors || BMW Performance Grilles || Light Weight Front Lip || JB4 || MPI Downpipe || ER Charge Pipe ||
      11-22-2017, 08:24 AM   #6
Yellowflash21
Slovenia
353
Also what was the stock weight and the balance?
Also that dyno is before adding downpipe and IC?
      11-22-2017, 10:24 AM   #7
AndrewC1989
AndrewC1989's Avatar
Drives: 2017 M2 | 2015 328dx
2017 M2  [5.00]
2015 328d xDrive  [0.00]
awesome! needs an RKP carbon roof though
https://ind-distribution.com/product?sku=RKP-F87-ROOF
      11-22-2017, 10:14 PM   #8
M2OG
Drives: a car
what do you think about the 300cell cat?
      11-22-2017, 10:22 PM   #9
lax01
Drives: 2017 M2
I always expect that too be more expensive for some reason...
      11-23-2017, 02:02 AM   #10
Yellowflash21
Slovenia
353
The install is more expensive than the part itself.
      11-23-2017, 03:30 AM   #11
963mw
BMW Fanatic
963mw's Avatar
Curious to know about the brake cooling in the front. Also can you please share more photos, this build looks insane.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      11-23-2017, 05:29 AM   #12
Peter_VIE
Austria
136
Thank you all for your comments, pls see answers below:
++ Any other weight reduction planned? You gut the trunk?
planned only bonnet, not trunk, as I do not want to loose too much weight on rear at that stage. Basically all mods are so fare done to be considered as reversible. Once I start the roof, i need the doors, the interior, the screens, but I will loose the car's license.
++ Very nice! From which company are the front brake cooling?
German company "https://www.lightweight-titanauspuffanlagen.de", but suggest to avoid this company. Aworkx is doing their own development and they should have something in future.
+++May i ask why you didn't go with an 18" setup if weight saving was the goal?
Pls see my thread "wheel weights" at the tire section of this forum. I did not find suitable 18" wheels, so I used the 513M, which show higher weight than the HRE 19"
++ Also what was the stock weight and the balance?
Stock weight was about 1570 kgs, balance no idea, did not scale. I think it was more to the rear, as battery and back seats are about 48 kgs
+++ Also that dyno is before adding downpipe and IC?
Dyno includes all mods mentioned above. I did it just for reference "before/after" when installing the aworkx flash. The guy from the dyno told me, on his dyno the stock M2 usually show about 350 hp.
+++ what do you think about the 300cell cat?
Difficult to say, I think, response improved slightly and sound increased and more & louder "bangs" in sport mode
963mw274.00
      11-23-2017, 06:41 AM   #13
Yellowflash21
Slovenia
353
350hp engine power?
So how it looks you gained 20 hp with 300cel and intercooler.
      12-04-2017, 05:10 PM   #14
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Cool project
      04-12-2018, 12:08 PM   #15
Peter_VIE
Austria
136
update:
- Wiechers carbon strut bar
- Millway camber plates
work very well w semi and full slicks on track
f20two197.00
      04-13-2018, 06:48 AM   #16
_pancho_
_pancho_'s Avatar
Sweden
Drives: F25 2.0dA -16 / F87 M2 Man -17
Great build!
I'm curious about the seats.. what base you used? How you coded airbag lights off?
regards Tobias
      04-13-2018, 10:34 AM   #17
Peter_VIE
Austria
136
Originally Posted by _pancho_ View Post
Great build!
regards Tobias
Thank you,
Base from aworkx, there is an adapter to mount below the seats to avoid airbag warning, it is not coded.
      04-13-2018, 11:47 AM   #18
twin fed
Doc Brown
twin fed's Avatar
920
Drives: 2016 MG MT M2
Interested in the strut bar. Did you notice a difference with and without it. I always felt the front could use a little more bite. Are there any American distributers that you know of?
      04-13-2018, 01:15 PM   #19
wolfbane1967
Hi
Great Car
Where can i buy airbag adapter to avoid warning?
      04-13-2018, 01:34 PM   #20
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
Lightweight is one of the shittiest companies I've ever dealt with. But I was able to adapt the CF backing plates and did this. Works incredibly well. https://f87.bimmerpost.com/forums/sh....php?t=1404878
'16 M2 Long Beach Blue/Black, 6MT
'19 X5 4.0 M Sport Black Sapphire/Tartufo
'18 Alfa Romeo Stelvio Quadrifoglio Vesuvio Grey/Black
Peter_VIE135.50
      04-14-2018, 02:33 AM   #21
Peter_VIE
Austria
136
www.tunershop.com
I installed strut bar, camber plates & slicks simultanously, the difference in car's behaviour changed so much, hard to say what part the strut bar makes. But any tuner I talked to recommended the strut bar if you go on track, particulary w slicks/semis.
      04-14-2018, 02:38 AM   #22
Peter_VIE
Austria
136
Originally Posted by wolfbane1967 View Post
Hi
Great Car
No idea, just ask the provider of the seats or the installer.
Tags
weight reduction
Copyright ©2000 - 2020, vBulletin Solutions Inc.
