M2 Technical Topics >
Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics >
Dashcam file auto download script
| 11-18-2017, 12:53 AM | #1 |
![]() 1443
Rep 1,466
I posted in the 'What did you do to your M2 today about the fact that I'd used a script to automatically download the files from my dashcam whenever I'm home. I got a request from dcmac to post more details about this, so here it is... in a more appropriate sub-section.
I should point out from the outset that this script is aimed at BlackVue cameras. It could potentially be modified for other brands, but of course, the device would need to be on your network, and there would need to be some way of getting a list of files, and then pulling them off. In the BlackVue cameras this all happens over HTTP, so it's pretty straightforward. So far this script is working perfectly, but I am finding that it takes a very long time to download the files, simply because there is so many of them and they're a large size. 1 day of data not going particularly far is in excess of 40GB! I could probably reduce this by turning down the sensitivity in parking mode, but I would rather know if something has happened to my car, and the low cost of memory makes this a bit of a non-issue anyway. So the script itself, is as follows: Code:
#!/bin/bash
echo
###### Set location where you want to store dashcam data. Sub-directories will be created for each day ######
rootpath=[Your data storage location]
###### If IP Address can be set static in the dascham or DHCP server, set the IP address here, otherwise comment out this line ######
ipaddress=[Dashcam IP Address]
###### Use to locate IP address if you cannot set it to be static in the dashcam or DHCP, otherwise comment out whole section ######
# macaddress="00:25:42:XX:XX:XX"
# ipaddress=$(arp -n | grep -i $macaddress | awk '{print $1}')
# if [[ -z $ipaddress ]]; then
# # Ping all addresses between 192.168.1.100 and 192.168.1.200 to make sure we have a complete arp table
# for i in {100..200}; do (ping 192.168.1.$i -c 1 -w 5 &> /dev/null &); done
# # Allow some time to get the ping responses
# sleep 5s
# # Try again to locate IP address in arp table
# fi
if [[ ! -z $ipaddress ]]; then
count=$(ping -c4 $ipaddress | grep 'received' | awk -F',' '{ print $2}' | awk '{ print $1}')
if [ $count -eq 4 ]; then
echo "BlackVue is up at $(date) ($ipaddress)"
echo "Getting file list"
if curl -# "http://$ipaddress/blackvue_vod.cgi" -o ${rootpath}list.txt --no-verbose;then
# sort the file, get the oldest files first
sort ${rootpath}list.txt -o ${rootpath}sortlist.txt
while read line
do
# check if valid line
if [[ $line = *Record* ]];then
# extract the different file formats from the line read
path=$(echo $line| cut -d':' -f 2)
path=$(echo $path| cut -d',' -f 1)
file=$(echo $path| cut -d'/' -f 3)
sdir=$(echo $file| cut -d'_' -f 1)
# echo "$sdir" - "$file" - "$path"
# check if directory exists. If not, create it.
if [ ! -d "$rootpath$sdir" ]; then
mkdir "$rootpath$sdir"
fi
# check if file exist. If not, copy from dashcam.
if [ ! -f "$rootpath$sdir/$file" ]; then
#If front camera file, try to download gps and 3gf file first
if [[ $path = *F.mp4* ]];then
echo "Downloading ${path/F.mp4/.gps}"
(cd $rootpath$sdir; curl -# "http://$ipaddress${path/F.mp4/.gps}" -O)
echo "Downloading ${path/F.mp4/.3gf}"
(cd $rootpath$sdir; curl -# "http://$ipaddress${path/F.mp4/.3gf}" -O)
fi
if ! (echo "Downloading $path"; cd $rootpath$sdir; curl -# "http://$ipaddress$path" -O);then
echo Transfer of "$file" failed...
if [ -f "$rootpath$sdir/$file" ]; then
# remove bogus file
rm -f "$rootpath$sdir/$file"
fi
fi
fi
fi
done < ${rootpath}sortlist.txt
echo "Completed at $(date)"
fi
else
echo "BlackVue is down at $(date) ($ipaddress not responding)"
fi
I have a launch daemon running this once every hour. The script only copies files that aren't already copied, so once the transfer is finished, the only thing happening every hour is a check for new files. I hope this is useful to some of you.
2018 ///M2 LCI, LBB, 6MT...
| 11-18-2017, 08:47 AM | #2 | |
![]() ![]() ![]() 461
Rep 467
| 11-20-2017, 12:07 AM | #3 |
I INDIC8
618
Rep 1,289
Drives: 2018 LBB M2, 6MT
This is awesome. I have a blackvue on my xmas list, and I will probably setup my NAS to run this at night to clear out the files.
I'm an IT guy by trade and tech nerd by choice. ![]() I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. ![]() |
| 11-20-2017, 01:14 AM | #4 | |
![]() 1443
Rep 1,466
I think the script will work fine on Linux, but you might have to modify back to using wget instead of curl if that's not already installed in your distribution.
| 11-20-2017, 03:21 PM | #5 | |
I INDIC8
618
Rep 1,289
| 12-09-2017, 02:18 PM | #6 |
![]() 1443
Rep 1,466
OK, a little update to the script...
I quickly found that I was filling up the disk I was using to save files to, and was having to go and manually delete the older files, which is of course annoying. I have enough disk space for just over 2 weeks of regular driving. I'm sure a long trip would result in more data, but I do have some wiggle room on the disk, so decided on 14 days of backups. I inserted the following lines just after the section that sorts the list of files, before the while loop. This way it doesn't delete files older than 14 days if the dashcam isn't connected at all. Code:
# delete dashcam files over 14 days to prevent over filling the disk
find "$rootpath" -mtime +14 -delete
| 05-09-2018, 12:27 AM | #7 |
I INDIC8
618
Rep 1,289
I found what basically amounts to a "one-liner" of your script over here...
https://www.bjornsblog.nl/tips-and-t...synology-wifi/ wget has some niceness - it won't overwrite or try to re-download an existing file, but it is smart enough to complete an unfinished download, so the script itself doesn't have to include any logic to check existing files, and it's much more robust against the camera disconnecting in the middle of the download. I just set it up tonight and I'm going to let it run for a few days and see what I wind up with. I have ~4.4 TB free on my NAS so space isn't really a concern right now...
| 01-07-2020, 05:20 AM | #8 |
Rep 2
Refined script. Thank you.
I joined this forum just say thanks to Nezil for initiating this post and I have since expanded on the intellectual property of many others and have created a more defined script:
1. worked and tested on Netgear RN426 (running ReadyNAS 6.10.2) and Blackvue DR900s-2CH 2. incorporated to remove old downloads at certain time every day 3. added features: a. ffmpeg to check integrity of downloaded mp4 files (sometimes they get corrupted during download, eg car left garage) b. ability to run under crontab every single minute (to run cronjobs) because it will not start another instance if one instance is already running (I set mine at every 5 minutes) c. ability to exclude one file type (I excluded new files (=N*), so I download only event files (=E*), park files (=P*) and manual files (=M*)) d. ability to avoid duplicate download of gps and 3gf files e. all the adjustable parameters are set at the start of the scripts to allow easy modification to suit your particular environment f. ability to choose how may times the script will try to download the file g. most excitingly, speedup codes were added. Previously, the downloads were slow because after a wifi disconnection, it restarts download from the very start. Although it would ignore the already downloaded files, it wastes a lot of time going from file to file to find out it has already been downloaded. Note: 1. there is the part from Nezil's script that allows variable IP address (obtaining from router), but I always have the router set to give my Blackvue a fixed IP address. 2. I am not a programmer but learnt everything from here and other forums 3. Blackvue DR900S is really good. (Thank you Blackvue) I have Unifi wifi access points that allow devices to connect to the same SSID but automatically connects at 2.4 GHz or 5GHz depending on whichever gives the best connection. I can see sometimes Blackvue will connect at 5GHz and sometimes at 2.4GHz. Of course when the signal is good, 5GHz is a lot faster. (This is happening despite choosing ONE frequency only on the Blackvue's own settings). 4. On Blackvue, set the wifi cloud to use your garage wifi as "garage wifi". Although your car has been connecting to your car's mobile 4g, it will automatically reconnect to the garage wifi when you get home because of this setting 4. Installing ffmpeg on my ReadyNAS is easy, just sudo appget ffmpeg and it will install itself, as the repository is already sitting in the Netgear remote server ready to be downloaded and installed. ffmpeg is very fast in checking video integrity. 5. cronjobs: google please: for ReadyNAS: it is crontab -l for listing, crontab -e for editing 6. need to know how to do SSH access into Ready NAS (suggest putty.exe freeware) 5. Thanks to Nezil on the share on hardware installation: https://f87.bimmerpost.com/forums/sh....php?t=1457010 I did exactly that: Cellink Neo with a relay switch with car battery source, and also a power magic pro between the car battery source and the relay switch. (Power magic pro NOT between Blackvue and final electricity supply) 6. Sorry, I can't be a quick responder. Can only do these forum things during holiday. |
| 01-07-2020, 05:40 AM | #9 |
Rep 2
Here it is
Code:
#!/bin/bash
# Script path
scriptpath=/data/Video/Blackvue/Scripts/
# Root path
rootpath=/data/Video/Blackvue/X5/
# Car Name
car="X5"
# Exclude recording type..X=no exclusion,N=Exclude Normal Recording
ExcType="N"
# Number of attempts to download mp4 file (minimum is 1)
times="2"
# Locate IP address in arp table
ipaddress=192.168.100.17
# Removal of files older than certain days and empty folders left behind
certain=60
# Time to cleanup old files and empty folders eg. 03-18 or 11-00 or 23-30
cleanuptime=11-00
##### in case ipaddress is still empty then
# sleep 5s
# fi
# lock dirs/files
LOCKDIR="/tmp/"$car"script-lock"
PIDFILE="${LOCKDIR}/PID"
# exit codes and text
ENO_SUCCESS=0; ETXT[0]="ENO_SUCCESS"
ENO_GENERAL=1; ETXT[1]="ENO_GENERAL"
ENO_LOCKFAIL=2; ETXT[2]="ENO_LOCKFAIL"
ENO_RECVSIG=3; ETXT[3]="ENO_RECVSIG"
### start locking attempt
trap 'ECODE=$?; echo "["$car"script] Exit: ${ETXT[ECODE]}($ECODE)" >&2' 0
echo -n "["$car"script] Locking: " >&2
if mkdir "${LOCKDIR}" &>/dev/null; then
# lock succeeded, install signal handlers before storing the PID just in case
# storing the PID fails
trap 'ECODE=$?;
echo "["$car"script] Removing lock. Exit: ${ETXT[ECODE]}($ECODE)" >&2
rm -rf "${LOCKDIR}"' 0
echo "$$" >"${PIDFILE}"
# the following handler will exit the script upon receiving these signals
# the trap on "0" (EXIT) from above will be triggered by this trap's "exit" command!
trap 'echo "["$car"script] Killed by a signal." >&2
exit ${ENO_RECVSIG}' 1 2 3 15
echo "success, installed signal handlers"
else
# lock failed, check if the other PID is alive
OTHERPID="$(cat "${PIDFILE}")"
# if cat isn't able to read the file, another instance is probably
# about to remove the lock -- exit, we're *still* locked
# Thanks to Grzegorz Wierzowiecki for pointing out this race condition on
# http://wiki.grzegorz.wierzowiecki.pl/code:mutex-in-bash
if [ $? != 0 ]; then
echo "lock failed, PID ${OTHERPID} is active" >&2
exit ${ENO_LOCKFAIL}
fi
if ! kill -0 $OTHERPID &>/dev/null; then
# lock is stale, remove it and restart
echo "removing stale lock of nonexistant PID ${OTHERPID}" >&2
rm -rf "${LOCKDIR}"
echo "["$car"script] restarting myself" >&2
exec "${scriptpath}$0" "$@"
else
# lock is valid and OTHERPID is active - exit, we're locked!
fi
fi
# at cleanuptime every day when the script is not busy downloading, delete dashcam files over certain days and empty directories to prevent overfilling the disk
if [[ "$(date +"%H-%M")" = "${cleanuptime}" ]]; then
echo $(date) Started removing files older than $certain days and empty folders under $car.....>>${scriptpath}oldfilecleanup.log
logfile=$(find "$rootpath" -mtime +${certain} -delete -print)
echo $(date) Removed old files:>>${scriptpath}oldfilecleanup.log
echo ${logfile} | tr ' ' '\n'.....>>${scriptpath}oldfilecleanup.log
logdir=$(find "$rootpath" -type d -empty -delete -print)
echo $(date) Removed empty directories:>>${scriptpath}oldfilecleanup.log
echo $logdir | tr ' ' '\n'.....>>${scriptpath}oldfilecleanup.log
echo $(date) Finished removing old files and empty folders under $car.....>>${scriptpath}oldfilecleanup.log
fi
echo "BlackVue-"$car" is up at $(date) ($ipaddress)"
if wget "http://$ipaddress/blackvue_vod.cgi" --output-document=${rootpath}list.txt --no-use-server-timestamps --no-verbose --timeout 60 --tries 1;then
# speedup : remove outdated filenames from Downloaded mp4 file list.txt
touch ${rootpath}"Downloaded mp4 file list.txt"
sort ${rootpath}"Downloaded mp4 file list.txt" -o ${rootpath}"Downloaded mp4 file list.txt"
line=$(head -n 1 ${rootpath}sortlist.txt)
if grep -Fq $file ${rootpath}"Downloaded mp4 file list.txt"
then
sed -i -n -E -e "/${file}/,$ p" ${rootpath}"Downloaded mp4 file list.txt"
fi
# speedup : cleanse the sortlist.txt by removing filenames of already downloaded or excluded mp4 files
while read line
do
then
grep -v "${file}" ${rootpath}sortlist.txt > ${rootpath}"1.txt"; mv ${rootpath}"1.txt" ${rootpath}sortlist.txt
fi
fi
while read line
do
#check that dashcam is still online
countA=$(ping -c2 $ipaddress | grep 'received' | awk -F',' '{ print $2}' | awk '{ print $1}')
if [ $countA -ne 2 ]; then
echo "BlackVue-"$car" is no longer online"
exit
fi
# check if directory exist. If not, create it.
fi
# If front camera file, try to download gps and 3gf file first
if [ ! -f "$rootpath$sdir/${file/F.mp4/.gps}" ]; then
if ! wget "http://$ipaddress${path/F.mp4/.gps}" --directory-prefix=$rootpath$sdir --no-use-server-timestamps --no-verbose --timeout 60 --tries 1;then
echo Transfer of "${file/F.mp4/.gps}" failed...
if [ -f "$rootpath$sdir/${file/F.mp4/.gps}" ]; then
# remove bogus file
rm -f "$rootpath$sdir/${file/F.mp4/.gps}"
fi
else
# add to the route file
cat "$rootpath$sdir/${file/F.mp4/.gps}" | awk -F ']' '{ print $2 }' | egrep -v '^$' >> "$rootpath$sdir/route.log"
fi
fi
if [ ! -f "$rootpath$sdir/${file/F.mp4/.3gf}" ]; then
if ! wget "http://$ipaddress${path/F.mp4/.3gf}" --directory-prefix=$rootpath$sdir --no-use-server-timestamps --no-verbose --timeout 60 --tries 1;then
echo Transfer of "${file/F.mp4/.3gf}" failed...
if [ -f "$rootpath$sdir/${file/F.mp4/.3gf}" ]; then
# remove bogus file
rm -f "$rootpath$sdir/${file/F.mp4/.3gf}"
fi
fi
fi
fi
if [[ ! $path = *${ExcType}*.mp4* ]];then
k=1
while [ $k -le $times ]
do
((k++))
if ! wget "http://$ipaddress$path" --directory-prefix=$rootpath$sdir --no-use-server-timestamps --no-verbose --timeout 60 --tries 1;then
echo $(date) Transfer of "$file" failed.....>>"$rootpath$sdir/error.log"
i=$(($times-$k+1))
echo Transfer of "$file" failed. Trying download again $i more time"("s")".
# remove bogus file
fi
else
#check integrity of downloaded mp4
errors=$(ffmpeg -v error -i "/$rootpath$sdir/$file" null $1 2>&1)
if [[ ! $errors = *null* ]] || [[ $errors = *channel* ]]; then
echo $(date) $errors .....>>"$rootpath$sdir/error.log"
i=$(($times-$k+1))
echo "$rootpath$sdir/$file" corrupted. Trying download again $i more time"("s")".
else
echo Download of "$rootpath$sdir/$file" successful!
echo $file >>${rootpath}"Downloaded mp4 file list.txt"
break
fi
fi
done
else
# speedup : these files are diberately excluded, so they go to the Downloaded mp4 file list
fi
else
# speedup : useful at initiation then useful because most likely the file is corrupt
echo $(date) DELETED because $errors .....>>"$rootpath$sdir/error.log"
echo "$rootpath$sdir/$file" corrupted and hence deleted
else
fi
fi
fi
fi
else
echo "BlackVue-"$car" is down at $(date) ($ipaddress not responding)"
fi
else
echo "BlackVue-"$car" is down at $(date) (not found in arp table)"
fi
| Bookmarks |
