09-16-2017, 08:23 PM | #1 |
Rep 20
265/35F, 285/35R fit on stock wheels?
Its time for new tires, was wondering if 265/285 will fit on the stock wheels, car isnt lowered at all.
Any rubbing? Stretching? Last edited by GrayMoose; 09-16-2017 at 09:09 PM.. |
09-17-2017, 05:00 AM | #2 | |
Rep 3,695
Also, the 285 rear is taller and when my car was dropped 20mm I would get fender liner rub when the trunk was loaded, had a passenger in the back seat, and hit a large bump. Just a little rub, so no big deal, and I now get no rub with a 15mm drop. |
8
Dirtboy197.00 MovingChicane109.50 Old Geezer205.00 bunnyhive55.50 CSBM52721.00 codylikerice68.50 JackyStuntin154.50 MASHCT624.00 |
09-19-2017, 07:08 AM | #5 |
Rep 3,695
09-19-2017, 10:18 AM | #6 |
Rep 258
I guess I'll have to try it out when my M2 arrives in November. I'm not a fan of the stretched look that the stock tires have. Just gotta cross my fingers that I'll get the Michelins; I can use the front 245s on my E46.
09-19-2017, 02:43 PM | #7 |
Rep 3,695
And you'll be able to stick the OEM rear 265s upfront and just buy a set of 285s for the rear. A 295 would rub the fender with my setup.
09-20-2017, 12:55 PM | #8 |
Rep 258
10-02-2017, 01:39 PM | #9 |
Rep 3,695
Just an update that I did get a little fender liner rub on the front when I was at the track last. It’s a clockwise track and the rub was drivers side under full compression.
So, who’s going to try 265/30 & 295/30 and report back? |
10-03-2017, 02:46 PM | #11 | |
Rep 3,695
Also, do you guys think 30s vs 35s would ride a lot harsher on the street? |
10-03-2017, 05:59 PM | #12 |
Rep 379
Yeah, I was surprised. Stock, just camber plates and no spacers.
10-18-2017, 12:06 PM | #13 |
Rep 229
Trying to revive this thread.
Interested in pics of 265/285 or 275/295 setup on stock wheels and stock suspension (only). I had 275s on another car with 9 inch rims so I know this size fits just fine on fronts. Of course not sure about rubbing.
17 m2: CSF Turbo FMIC, Fabspeed DP, BM3 Stage 2, VRSF Charge Pipe, Schroth quick fit, Vorshlag CC plates, Apex 18x10, BMS Clutch Stop.
10-18-2017, 10:44 PM | #14 |
Rep 391
I run my stock rear 265/35 pss on the front and bought 285/35 for rears. All stock rims and suspension. Fills fender nicely and pretty much flush to outer fender. I did notice it doesn't slip the traction light as much now, not just the width but also the added diameter.
10-18-2017, 10:53 PM | #15 |
Rep 391
Another pic
Old Geezer205.00 CSBM52721.00 |
10-18-2017, 10:58 PM | #16 |
Rep 391
When switching over to my winter set I noticed very light rub marks on drivers side front, just on the front side inner plastic fender liner. Very minor, no groove or anything, just polished up the plastic a bit.
I also get a bit of tramming on uneven pavement with this set up. |
CSBM52721.00 |
10-19-2017, 12:35 AM | #17 |
Rep 229
Drop the Hammer: Thanks! If you have any pics with more light, that would be great, to see the wheels/tires a little better (maybe not as you're apparently on winter setup). Appreciate it!
10-19-2017, 06:57 PM | #18 |
Rep 391
10-22-2017, 04:07 PM | #19 | |
Rep 4,254
///M Power
10-22-2017, 08:14 PM | #20 |
Rep 391
10-22-2017, 10:43 PM | #21 |
Rep 4,254
275/35 maybe the sweet spot then
///M Power
