M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M-Performance Exhaust Bypass (Red Pimple) - DIY
      07-27-2017, 01:49 PM   #1
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
If you're looking for a way to permanently keep 'On' the obnoxious Red Pimple on to the New M-Performance Exhaust, this DIY will help.
Level of difficulty: Easy
Time required: 5-30 Minutes
Tools Required:
- Flathead Screwdriver/Fingernails
- 4-6 cm of wire, preferably a thin one
- Black Tape
Special thanks to SimNugget for providing detailed information on how to do this!
Detailed guide with pictures below.
Step 1
Remove plastic retainer clips circled in yellow with fingernails/flathead screwdriver and pull trunk fabric until you have access to the relevant wires
Step 2
Switch off MPE Exhaust Module
Step 3
Unplug the Red/Black Cable from the multi-coloured one
Step 4
Craft a 4-6cm wire and bend it in a U-shape
Step 5
Now Insert both ends of the wire respectively in each angle where the black wires lie (Where the blue circles lie in the shitty paint diagram)
It should look something like this
Step 6
Switch on MPE module and test the bypass. If it is not working you must thin out the wiring and push it deeper in the hole
Step 7
Secure the cables in whichever way you prefer. I’m temporarily using Black Tape.
Step 8
Tug cable back in & put trim back together
Step 9
Done! Button will automatically turn on and off with ignition.
Appreciate 11
Prodigy.697.50
johanva146.50
PiK61.00
DoZZa81.50
JustChris17485.50
Moris3.00
krizze928.00
NathObeaN1307.50
      07-27-2017, 10:14 PM   #2
arwin
Drives: 2017 AW M2
Wow. Great write up!
      07-31-2017, 06:16 PM   #3
mike@x-ph.com
mike@x-ph.com's Avatar
https://x-ph.com/sale/
Phone number 702-494-9435
      08-01-2017, 12:56 PM   #4
JustChris
General
JustChris's Avatar
Drives: Tesla MYRWD
Brill cheers! PS my neighbours hate you! (Jk)
My car made front page of Bimmerpost
Dav3948.50
      08-06-2017, 11:18 AM   #5
MR.
MR.'s Avatar
What a cheap fix...
MR
krizze928.00
      10-14-2017, 10:18 AM   #6
maliderosF87
Drives: F87
question
Is it true that if you double tap the remote controller and open the valves, then move the remote far away from the bluetooth receiver then the valves will permanently stay open even after you turn the engine off?
Read this in a thread in this forum, can anyone confirm?
      10-14-2017, 02:59 PM   #7
CommitConfirm
475
Drives: The Bus
It?s even easier than that. Cut both the read wires off at the base. Cut the black wires off a the switch and solder the two black wires together. You do not need the switch or the red wires for a permanent bypass.
      10-14-2017, 11:37 PM   #8
Dav3
Dav3's Avatar
949
Most people don't own a soldering iron though
just sayin'
krizze928.00
      10-19-2017, 02:44 AM   #9
SimNugget
49
Drives: F31 335XD
Great detailed write up - thanks for taking the effort to do it.
I think it is the best way as it looks stock and can be returned to stock if there are any warranty issues. I also didn't want a hole left in the trim if the red button was removed.
S
Dav3948.50
      10-19-2017, 05:02 PM   #10
DivideBYZero
DivideBYZero's Avatar
484
Drives: F87 M2<E92 M3<E46 M3
just sayin'
$15 will fix that.
JUST SAYIN'
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
///M TOWN16298.50
      11-13-2017, 03:41 AM   #11
krizze
Czech_Republic
928
Drives: 718 GT4 -Skoda Octavia VRS
Tools Required:
- Black Tape
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Did this today!! life saver thank you! now i don't have to explain to everyone why im going into my boot
Dav3948.50
      01-18-2018, 04:03 PM   #12
SimNugget
49
Drives: F31 335XD
Thanks for this detailed write-up, I had to redo this after the dealer removed it while doing warranty work.
I used one of these to splice the two black wires together.
http://www.partex-direct.co.uk/image...s2-500x500.jpg
S
      01-18-2018, 04:15 PM   #13
horsepower_and_hounds
Drives: BMW
S
Ass Wads
Dav3948.50
      01-19-2018, 09:08 AM   #14
SimNugget
49
Drives: F31 335XD
I know - I was livid!
      03-16-2018, 09:03 AM   #15
renny73
renny73's Avatar
Drives: F87 DCT MG
Great write up - thanks for posting.
Looking to get an MPE in the spring but the thicky inside of me is a little unsure about one of the steps above.
I'm guessing you don't plug the small plug back in, but what is it attached to in the picture showing it taped to something?
Thanks
      03-16-2018, 11:16 AM   #16
Dav3
Dav3's Avatar
949
Thanks
You re-connect all cables as initially presented in front of you
Only thing you really are doing is inserting a copper wire in given holes to short it so that it stays on
Tape is to hold the cable inserted in the two holes together. Probably a thousand better ways of securing the extra wire but it has held up for me for more than 6 months now
      03-16-2018, 11:52 AM   #17
voyagergab
voyagergab's Avatar
633
Drives: G82 M4 6MT, G01/F97 X3M
I don't think I have that red button in the trunk with my port installed MPE.
What does it do?
      03-16-2018, 12:08 PM   #18
///M²
///M²'s Avatar
283
Drives: 2017 BMW M2 6MT
2017 BMW M2  [0.00]
What does it do?
I believe it's in Europe only. You have to press that red button every time before you can open the flaps to track mode with the bluetooth controller. Once pressed you can open and close the flaps at will but as soon as you turn the car off and restart it you have to press the red button again before you can use the bluetooth controller. PITA.
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold
      03-16-2018, 12:10 PM   #19
voyagergab
voyagergab's Avatar
633
Understood TYVM!
///M²282.50
      03-19-2018, 07:31 AM   #20
renny73
renny73's Avatar
Drives: F87 DCT MG
Great stuff - many thanks
      03-21-2018, 07:00 AM   #21
renny73
renny73's Avatar
Drives: F87 DCT MG
As a matter of interest, does anyone have the part number or description of the plug where the wires are linked out?
      03-30-2018, 11:12 AM   #22
ferraris
Thanks for the instructions however I could not get the wire in sufficiently far enough to make the connection, it's really tight, I'll try the splicing method I think.
