M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Valve Carbon Buildup
      07-25-2017, 06:44 AM   #1
PackPride85
Most people probably aren't to this point yet mileage wise, but at some point because its a DI motor, the valves are going to require cleaning from carbon buildup. I'm not too familiar with how BMWs handle this, but with my mazda it was generally recommended at 50-60k miles.
I've heard that BMW dealers (in the US) actually offer a blasting service that uses crushed walnut shells. Just curious if others on here have previously used this service and how much they typically charge.
This thread seems to be a pretty good indication that the problem does exist and the method actually works:
http://www.e90post.com/forums/showthread.php?t=682116
      07-25-2017, 12:51 PM   #2
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
I think this was fixed with the N55 motor?
I know Toyota 4DS motors they do not have carbon build up issues at all. Each cylinder has 2 injectors both port and direct injection. The combination of using these injectors you do not have any carbon build up from the valves.
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      07-25-2017, 12:53 PM   #3
PackPride85
None of the bmw motors use the port/di combo like the 4ds that I know of. That's the only real "fix".
      07-25-2017, 08:24 PM   #4
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Use Ethanol once in a couple month should do.
Lemania 2320
      07-25-2017, 09:00 PM   #5
flyboy385
Drives: '18 MG M2 6MT
I recently brought in my 2011 N55 135i with around 75,000 miles on it to have the intake valves looked at.
After more than 50,000 miles with JB4, DP and exhaust, my mechanic said it was amazingly clean and I could go another 75,000 miles before valve cleaning was needed.
I imagine the N55 in the M2 should be similar, so probably not something to worry about yet.
      07-25-2017, 10:59 PM   #6
J3STER
Drives: AW M2
How will this help? The cars runs DI, the fuel does not touch the valves.
