M2 Technical Topics > Suspension | Brakes | Chassis > DIY Brake Duct Project
      10-04-2019, 03:47 PM   #133
FlyingLow78
The G8X is a disaster. 🤮
931
Drives: Not a BMW anymore
The 24 hours encompassed the production of both scoops and both hose interfaces. We used a .8 nozzle with 100% density for strength.
For the M3, if I had to do it again, I’d move the holes for the zip ties a little farther away from the control arm and add a little more “lip” to the opening for stability.
I’m trying to decide if I have the courage and resources to do a side-by-side comparison of the ducts versus the Porsche scoops. The ducts require some kind of backing plate to be installed and I don’t think I want to be pulling calipers and rotors off as my track time ticks away.
      10-04-2019, 04:58 PM   #134
MagnusT
MagnusT's Avatar
Sweden
538
Ah, the hours do add up :-)
Don't know if it's relevant but I earlier ran the GT3 scoops for one season, with just some of the metal backing plate folded away to get air on the disc and caliper. So no hoses or anyhting. That was better than stock but not 100% enough cooling for my tracks/driving/PFC08. But the scoops + hoses is worlds better. First time I have more cooling than neccesary and room to spare. Again, that is for my type of tracks, driving style, brake pads... :-)
DrKevM52273.50
      10-25-2019, 11:11 AM   #135
FlyingLow78
931
I'm going to take back what I said. These scoops are a damn good design incorporating some really intelligent design cues.
I've run into a challenge, though. Mine are rubbing on the wheel body when turning full lock. Its not bad, but enough to leave evidence on the ducts.
We tried changing the design to incorporate a little more room where the wheel is contacting, but we can't get the program to let us edit it effectively. Is there a more "original" file we could try?
Also, I got my hands on a second set of Porsche front scoops and they fit beautifully on the rear with zero cutting. The air goes directly at the caliper and rotor where I cut the shield.
Kankles1484.50
      10-25-2019, 01:34 PM   #136
MagnusT
MagnusT's Avatar
Sweden
538
I could definitely make a new slightly adjusted design but I'm surprised they rub on your car since I run 10" in the front and have no rubbing. Either way we need to find out what is different so I know what to change. Why don't you contact me on magnus@rejsa.nu so we can work it out together :-)
      11-29-2019, 05:18 AM   #137
FlyingLow78
931
Sorry, I just saw this post. We modified the original drawing to add some clearance by the inner lip of the wheel where it had been contacting the scoop. I also mounted both scoops as far inboard as they could go. This necessitated disconnecting the headlight leveling sensor arm on the left side. I have done a few events with the revised ducts and everything is perfect.
      11-29-2019, 06:52 AM   #138
Megator
Megator's Avatar
518
Drives: M2 Competition
Could you pls share the STL? I have been working on the other side and will have a 2nd proto done this weekend. If it fits I will make a 3D printed mold to make CF ducts that attach to the OEM shields.
      11-30-2019, 02:00 AM   #139
MagnusT
MagnusT's Avatar
Sweden
538
[img]https://i.imgur.com/9J6vP9F.jpg?1[/ img]
Looks nice!
But I would love to understand why you had this clearance problem. Could you possibly take some pictures?
Are you maybe mounting them further inwards to the center of the car than I do? The more outwards you mount them the more clearance you get.
      11-30-2019, 01:23 PM   #140
Drop the hammer
Drives: '17 F87 M2 AW, Dct
I’m ready to take the plunge into adding front venting. I bought the 911 deflectors to add, but these vents above with some tubing look way more effective. I also daily drive my car year round (snowy winters) so I’m worried I might be directing snow/salty slush into my disks. Do you guys think I should set it all up for track days and just install night before and then remove them afterwards? I’d modify the stock backing plates to accept the tubing and just clamp on and off. The zip ties easy to cut off to remove the plastic piece. I would probably just leave them on for summer track season.
      11-30-2019, 02:47 PM   #141
MagnusT
MagnusT's Avatar
Sweden
538
I've had them on all the time but I'm thinking of removing them now if we get deep snow.
      01-05-2020, 01:19 PM   #142
MagnusT
MagnusT's Avatar
Sweden
538
@FlyingLow78 Did you see what I wrote earlier, the further out from the car you mount them the more room there is. Sounds like you mounted them much further in towards the car than neccesary. I'm a bit curious why you didn't mount them as intended, where there is enough free space and no contact issues. The air flow is very good at the intended mounting position.
      01-05-2020, 02:47 PM   #143
FlyingLow78
931
Sorry, just saw this, since I don’t get over to the F87 forums as much as the F80. I do mount them as far inboard as I can to clear, but I will look at mounting them closer to the wheel.
It is hard for me to get pics of the car with the wheels on and suspension compressed without a drive-on lift. I don’t plan on bringing the car out of hibernation until April, and I’m slammed with school and work all winter, so all of my projects are on hold until I graduate.
MagnusT537.50
      04-02-2020, 08:21 PM   #144
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
Amazing work. What is the latest that everyone is doing?
      04-28-2020, 08:58 AM   #145
MagnusT
MagnusT's Avatar
Sweden
538
I've updated on Thingiverse with a version of the original 3D-printable scoop with a slightly tougher version that probably can be used for gravel tracks hahaha!
https://www.thingiverse.com/thing:3566812
And again, the scoop should be mounted as far as possible away from the car, the closer it is to the wheel the more space to accommodate the wheel when turning it.
Kankles1484.50
      07-17-2020, 12:41 PM   #146
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
Whoa, now these are nice brake ducts!
https://www.motorsport.com/f1/news/f...s/4838478/amp/
      08-20-2020, 04:03 PM   #147
Bewstd
Drives: BMW M2, RAM 2500
which porsche ducts are those?
2018 M2- Alpine White 6spd
some two wheeled fun and a tow rig
      08-20-2020, 04:37 PM   #148
MagnusT
MagnusT's Avatar
Sweden
538
GT3
      08-21-2020, 02:20 PM   #149
FlyingLow78
931
Porsche part numbers 997.341.483.92 and 997.341.484.92. About €20 for a pair.
prompt292.00
      08-22-2020, 01:25 PM   #150
Megator
Megator's Avatar
518
My solution
Front I made scoops that clear 9" 513Ms
Rear im making some custom scoops
DrKevM52273.50
Kankles1484.50
      08-23-2020, 09:30 AM   #151
Kankles
Rear Admiral
Kankles's Avatar
Drives: Bavarian Milk Wagon
2019 BMW M2C  [0.00]
Originally Posted by Megator View Post
My solution
My Megator front scoops came out awesome, thanks! Waiting for the rear ducts now
Megator517.50
      08-24-2020, 04:32 PM   #152
SuperMarioM2
Drives: M2 M Performance Edition - 6mt
2017 BMW M2  [9.83]
Are you or anyone on this thread offering these for sale?
      08-24-2020, 05:22 PM   #153
MagnusT
MagnusT's Avatar
Sweden
538
The updated larger intake version I did a while back also works with the large Competition calipers, small 18" wheels and also 10" wide wheels in both 18“ and 19“.
https://www.thingiverse.com/thing:4436752
      08-25-2020, 01:59 PM   #154
eeyang92
Drives: LBB M2 LCI 6MT
Are ya'll printing these with ABS? Or even PLA (although I feel like it would immediately melt due to being so close to the brakes)
