BMW 3-Series (E90 E92) Forum
Misfire Single Cylinder
07-17-2017, 10:03 PM | #1 |
Rep 5
hello so i have fbo 335 with Cobb ap Running stage 2+, i've been trying to chase down this misfire in cylinder 3, i have swapped coils, and plugs even bought new ones with no success, i admit i havent done walnut blast yet, but the misfire is only in 1 cylinder, should it be safe to say i need a new injector?? and can i only swap 1 injector being the fact its so pricey?
07-18-2017, 09:35 AM | #2 | |
Rep 223
2008 Sparking Graphite 335i 6MT Coupe - Single Turbo
2007 Montego Blue 335i 6AT Sedan |
07-18-2017, 09:55 AM | #3 |
Rep 32
I'm going thru this same issue but my car is stock I've had cylinder 3 misfire for almost a month now I changed the spark plugs and coil packs and I changed #injecotr with no luck
07-18-2017, 11:02 AM | #4 |
Rep 5
07-18-2017, 11:08 AM | #5 | |
Rep 5
29a3 o2 sensor low signal( I had this code after a vcg swap I figured mechanic messed something up, so I bought a new one swapped in with downpipes and still have that code and Cobb tune hasn't ignored it so I have a cel because of this also...) but my main concern is cylinder 3 misfire only I don't believe the 02 sensor is causing a single cylinder misfire...could I swap injector 3 to 2? Do I need to replace the o ring when doing so if it's possible? |
07-18-2017, 11:12 AM | #6 |
Rep 5
Any people in NYC that could give me a hand diagnosing this I don't want to buy parts I don't need and spend an arm and a leg lol, I just bought my fbo setup and it worked great for 2 weeks the power was amazing I need that feeling back haha
07-18-2017, 11:17 AM | #7 |
Rep 772
Drives: 2015 435i grand coupe xdrive
pull that plug out and see if its wet and or smells like gas. Is the misfire only on start up over night?
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
07-18-2017, 11:17 AM | #8 |
Rep 5
I'm going to try to datalog for the first time I will post my results when I get home using this info
http://www.e90post.com/forums/showthread.php?t=696472 But will this help with figuring out a possible injector problem or do I need to add in short term and long term fuel trims in this test? |
07-18-2017, 11:22 AM | #10 |
Rep 5
07-18-2017, 11:34 AM | #11 |
Rep 772
If you have index 11 injectors you can just put in index 12 at free will but you should have them coded. BimmerGeeks can do this for you remotely. If your injectors are not index 11 you should replace a the 3 on the same bank.
https://www.bmwpartsworldwide.com/oe...00-13538648937
