2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning BMW B46/B48/B58 Tune Comparison
      05-15-2017, 11:18 AM   #1
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Talking BMW B46/B48/B58 Tune Comparison
Today; I would like to write about the different piggyback options available for the BMW new F chassis B48/B58 engines. This market is over-saturated with tunes priced from a couple hundred dollars up to a couple thousands. Not all tunes are equal, which ones are worth it and which ones are not? Read this post and decide for yourself.
Burger Tuning (BMS) B48/B58 Quick Install/Uninstall JB+
How:
Burger Tuning JB+ connects to Tmap sensor only. This is the simplest B48/B58 tune on the market.
Pros:
  • Easy install/uninstall (less than 2 minutes)
  • Adjustable boost (up to 4.5psi)
Cons:
  • Does not suppress CEL code from high flow downpipes
  • No datalogging capability
  • No code reading capability
  • No Bluetooth capability
Price
$199
Burger Tuning (BMS) B48/B58 JB4 stage 2
How:
Burger Tuning B48/B58 JB4 stage 2 connects to TMAP, MAP and OBD. It also comes with flex fuel connectors for E85 users.
Pros:
  • works with stock or modified cars
  • Number of preset maps that user can choose from
  • Code reading capability
  • Datalogging capability
  • Bluetooth capability (add on for $139)
  • Automatically suppresses CEL code from downpipe
  • Compatible with methanol injection systems
  • Compatible with E85
  • Additional features include (exhaust valve control, boost by gear, boost by RPM, gauge hijack)
Cons:
Long install time (45 minutes).
Price:
$529
Dinan B48/B58 Sport Performance Tuner:
How:
Dinan B48/B58 sport performance tuner connects to MAP and Tmap sensors.
Pros:
Easy install (5-10 minutes)
Adjustable boost
Cons:
Price
$299
Active Autowerke Active8 Tune
How:
Active8 connects to boost pressure sensor, Manifold pressure sensor, crank position sensor ( rpm pick up point)
Pros:
  • 9 different maps
  • Connects to RPM sensor
Cons:
  • No Bluetooth capability (might be added in the future)
Price:
$729
Thank you for reading. Dinan Stage 1 will be added to this comparison next.
https://x-ph.com/sale/
Phone number 702-494-9435
Appreciate 4
      05-15-2017, 10:10 PM   #2
AlexM240i
Drives: M240i
Great post.
Very helpful.
      05-16-2017, 05:15 PM   #3
mike@x-ph.com
Originally Posted by AlexM240i View Post
Great post.
Very helpful.
Thank you
      06-01-2017, 04:01 PM   #4
mike@x-ph.com
Active 8 added to the list, Dinan tune next
      06-29-2017, 10:36 PM   #5
ko113
Drives: m240i
I guess this should be updated since the new firmware for the JB4 no longer automatically suppresses CEL code from downpipe. Confirmed on N54tech and I got CEL on my ride home from work, easily deleted through the app though
      06-30-2017, 12:03 AM   #6
mike@x-ph.com
This thread will be updated soon with a new tune added and JB4 info fixed.
      02-17-2020, 12:35 PM   #7
Derelique
Drives: BMW X1
So will BimmerLink delete the CEL code for good if I get one of these? I’m new to BMW. Thanks in advance!
      02-20-2020, 11:11 AM   #8
mike@x-ph.com
I might be wrong but i think the code comes back every 50-100 miles.
If you want to hide the code for good, get a flash tune like Bootmod3
      03-13-2020, 10:31 AM   #9
e46dreammachine
Drives: e46 325XI
Thanks for posting this! Was going to make my first post asking about this but glad I found this after I registered.
Picking up a mint 17 240iX tomorrow and looking at all the different options. Will be my first time putting a software tune on. My main question is a comparison between the Dinan offering and AA8.
I know the dinan has a bypass option on the fly but does the AA8 provide this capability as well?
Do they throw any CEL codes during their usage (on stock internals/exhaust).
Performance for dollar and warranty?
Lastly, what is the estimated total cost doing the software and a propertune at a local dyno (Bimmersport is the authorized AA and Dinan installer).
Many thanks!
      03-13-2020, 11:11 AM   #10
mike@x-ph.com
Many thanks!
The AA8 has been discontinued and replaced with the Active flash.
Neither of these tunes will throw a check engine light.
If warranty is important to you, Dinan is the way to go.
If you want performance/dollar checkout Bootmod3, Jb4 or Active8 flash
      03-13-2020, 01:47 PM   #11
e46dreammachine
Drives: e46 325XI
Thanks for the quick reply Mike!
Looking at active as my warranty is up soon on the car in about 6000km. How easy is it to select between OE, stage 1 and stage 2 once installing active flash?
Thanks
      03-13-2020, 07:04 PM   #12
mike@x-ph.com
Thanks
It takes a couple minutes to flash a new map
2addicts
