M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Exhaust valve?
      01-05-2017, 09:19 PM   #1
F87mon
Drives: Mineral Grey M2
Exhaust valve?
Hello this is my first thready in this forum, pardon my english.
Does anyone know in what condition does the exhaust valve close/open? I notice even at idle my exhaust valve is open. I did bring this question to local BMW dealership and it's also open at idle on the other M2. We played with comfort/sport/sport+ nothing changes. Drove the car so it reach normal temp the valve still open. We even open the valve actuator to see if it's rotating, which isn't. If the valve remains open why BMW put the valve in the first place?
      01-09-2017, 02:31 AM   #2
Peter_VIE
Austria
193
http://www.bimmerfile.com/2016/02/22...ng-the-bmw-m2/
quote:
The exhaust flap is closed at idle, in the lower speed range and nearly of the time when the car’s in COMFORT mode (the exception being under heavy load).
In SPORT and SPORT+ positions, the exhaust flap is fully open when the engine is idling while the vehicle is stationary and in the lower gears.
unquote
      01-09-2017, 08:24 AM   #3
serrated
I believe it's also open during cold start (stock exhaust)
      01-09-2017, 04:02 PM   #4
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
The valve will be open upon cold starts and eventually will shut once warmed up. After that, to get the valve back open you will have to switch it into Sport or Sport+ mode, and get the car past I believe 3.8k rpms and it will open back up and stay open.
Maks///M2278.50
///M TOWN35366.50
      01-10-2017, 06:04 AM   #5
F87mon
I can confirm that the valve is open in comfort mode at idle when the engine already warm up. for me this is still mystery.. anyway it's better to stay open than closed. It's just that i need to be more subtle on the right foot when passing quiet neighborhood
      04-11-2017, 03:37 PM   #6
philisme
Belgium
56
Drives: BMW 1M Coupe + M2 + 330e
2016 BMW 330e  [0.00]
2012 BMW 1M coupe  [10.00]
2017 BMW M2  [0.00]
I have the same "problem". The exhaust valve on my M2 stays OPEN, I can't see it closed.
After installing the Akrapovic exhaust system, the valves (Akrapovic provide a second flap with an harness and a control module to connect it) stay OPEN all the time. (I didn't buy their "Sound Kit" aka "remote control").
I thought the problem came from Akrapovic module, so I disconnected all the Akrapovic hardware and reconnected the valve as stock, but it won't close...
BMW 1M Coupe - AW - 2012
BMW M2 DCT - BSM - 2017
BMW 330e iPerformance - GSM - 2016
      07-23-2017, 02:58 PM   #7
VegasM2
Drives: 2017 M2 LBB/Manual/Exc.
I'm also having a similar issue and it's even more noticeable with my newly installed Dinan exhaust. i absolutely love it when im really on it with the valve open but when im cruising i'd love to know that it's closed. with the Dinan especially since when the valve is open all the gasses are directed to the far right pipe alone, which doesn't travel through the exhaust can at all. the other three, which do are inactive. pretty much like not having an exhaust at all.
is there a way to code it to stay totally closed when in comfort mode?
2017 M2|LBB|Manual|Executive Package|Fabspeed SportCat|Dinan S4 Tuner w Big Turbo|Remus Exhaust|Dinan Intake|Dinan Intercooler|Dinan LPFP Upgrade Kit|Ultimate Clutch Pedal|BMS Clutch Stop
      07-24-2017, 12:12 AM   #8
NO_USER_
Drives: .
Get the BMS canflap module! I just installed it, it's awesome! Press the BC stock button and you can turn the valves open/closed/stock functionality. And there are additional features as well. You literally plug it right into the OBDII port! There's also the Macht Schnell EVC with a few more features but also a little more effort to the install. Both great options for full valve control!
VegasM285.50
      09-03-2017, 08:49 PM   #9
bluebro
Drives: F87 M2C, G87 M2
I also have the valves constantly open after fitting the Remus exhaust, I can't get my head around the fact that the actuators don't seem to move at all even when in comfort mode.
Fuman26.50
      09-03-2017, 09:18 PM   #10
NO_USER_
Drives: .
Comfort mode doesn't close the valves
      09-03-2017, 09:45 PM   #11
Prodigy.
Prodigy.'s Avatar
727
Drives: ///M2
So can you hear any difference when switching between comfort & sport/sport+?
I'm getting the Remus fitted soon and don't want the valve open and the exhaust loud while cruising in comfort on the fwy.
Fuman26.50
      09-03-2017, 09:51 PM   #12
NO_USER_
Drives: .
You will hear a difference when switching between comfort and sport but it's not the valve, not exactly sure what it is (watergate adjustment?) that makes it quieter at idle. But under normal driving it'll sound the same between all modes but the valve closes at certain points more frequently in comfort...
I had the Remus Exhaust. It's the same for every exhaust. If you want valve control get the BMS CANflap Module (I have that) or the Macht Schnell unit and you can control the valves (between open, closed, and stock) from the BC stock button, pretty cool!
I can say tho with the valves closed on the Remus it isn't that much quieter...
      09-20-2017, 02:59 AM   #13
Prodigy.
Prodigy.'s Avatar
727
Drives: ///M2
Had the Remus system fitted yesterday, a mate was following me and could see the right hand flap opening and closing while i was driving, the left side flap however did not move at all, anyone else experience this? seeing the flaps are wired in unison they should operate together, yes? I'm assuming installation error?
      09-20-2017, 03:45 AM   #14
dbperformance
Drives: None
Just remove the adapter of the exhaust muffler when your valve is open, and then it always will be open.
      08-03-2018, 10:51 AM   #15
Jcon157
Jcon157's Avatar
Drives: '18 M2, '15 M235, '16 X3
'18 M2  [0.00]
'16 X3 xDrive35i  [0.00]
'08 335 (Retired)  [0.00]
'15 M235  [10.00]
Has anyone on this thread (or anyone else for that matter) been able to resolve the issue where the exhaust valve simply doesn't work? Mine is permanently stuck open and won't close under any circumstance. The BMW Tech's at my dealership are stumped too. Appears it never worked right from the factory.
I did a more detailed write-up about it on Post #13 in this thread:
https://f87.bimmerpost.com/forums/sh....php?t=1516177
The response we got from the PuMA BMW Tech was quite amusing.
*I have the Dinan exhaust/res delete combo and the ASD Bypass installed (not that it should matter for the valve functionality though).
tenkies165.00
      08-03-2018, 05:25 PM   #16
tenkies
Drives: 2017 M2 LBB 6MT
I recently acquired an Akrapovic and it seems like my flaps are open all the time as well. Not a huge deal for me as I still have the stock DP and the Akrapovic exhaust is not that loud and I'm 98% in Sport or Sport+ mode when driving anyway which means the flaps would be open regardless.
Jcon157321.50
      08-03-2018, 05:44 PM   #17
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
If you want to open/shut them at will but don't want to buy the akra sound controller any of these will do the trick:
$27
http://www.bimmerlink.com/
$200
https://www.cgprecision.com/#!/VSC-1...egory=19726366
$400
http://machtschnell.com/exhaust-valv...vc-module.html
I have CG and use it with my Remus exhaust. Works great. Also integrates into the homelink buttons. Super cool.
tenkies165.00
Jcon157321.50
      08-03-2018, 06:19 PM   #18
tenkies
$27
$200
$400
Thanks for listing options and the links. At this point I don't feel the need to spend extra $ on closing the flaps. It's not a big deal to me but who knows later on down the road after I get a aftermarket DP.
      08-03-2018, 06:21 PM   #19
AndrewC1989
That's exactly why I bought one. I have a 200cell fabspeed sportcat and sometimes the car is louder than I want it to be so being able to force shut the valves at times is very helpful. Like you said, if your cat is stock then it won't be super useful but if you do decide to change it out later you'll definitely want valve control.
      08-03-2018, 06:27 PM   #20
Jcon157
Jcon157's Avatar
'18 M2  [0.00]
'15 M235  [10.00]
I hear ya. Like you, I drive in Sport/Sport+ most of the time so it's not an issue then. However when driving for 2+ hours on the highway with cruise set at 80mph, my wife especially doesn't enjoy the background drone we hear.
According to this document, when drive mode is set to Comfort the exhaust flap should close. Mine refuses. Have you tested this with your car sitting at idle to see if your valve closes? (after the initial startup has settled down of course)
terrywang119.00
      08-03-2018, 06:34 PM   #21
Jcon157
Jcon157's Avatar
'18 M2  [0.00]
'15 M235  [10.00]
I was all set to buy the Burger Tuning OBDII CAN Module (http://www.burgertuning.com/f_series...odule_BMW.html) until I discovered my valve doesn't work so I put that on the back burner. I just like the fact it was so simple to connect/disconnect.
I hadn't heard of the CG before. Really like the idea of integration with Homelink . If I ever get this resolved I'll certainly check that one out. I checked out the link but I don't see install procedure anywhere. Am I missing it?
      08-03-2018, 06:40 PM   #22
AndrewC1989
https://www.manualslib.com/manual/89...-1.html#manual
It's a really easy install but the car has to go up on a lift or at least the rear needs to be up on jack stands. Took like 5-10 min to install mine once the car was in the air. It's plug and play, no modifications needed.
Jcon157321.50
