02-13-2017, 06:36 PM | #45 |
Rep 3,888
02-13-2017, 06:40 PM | #46 |
Rep 1,973
N55 and S55 engine comparison: close deck VS open deck
I don't know why there was such a controversy about the M2 engine being an open deck VS the M4 engine being a close deck as BMW's own technical documents show their different engine block designs (hence the engine denominations S versus N).
Ok I understand that the Press Releases were misleading saying that the M2 engine is of "close deck design". But that was easily debunked. Maybe M2 owners can use the below information to financially settle with BMW if they feel cheated. I believe if the "close deck" information is still officially available from BMW or was available for a long time, there is grounds to be upset because close deck and open deck designs are very different! Let's have a closer view with pics and diagrams taken from the engine informations provided by BMW... M2 N55 engine information here (click on the photo of the engine to download PDF file): http://f30.bimmerpost.com/forums/sho...d.php?t=854477 M3-M4 S55 engine information here (click on the pdf file with the name "S55 Engine Technical Docs": http://f80.bimmerpost.com/forums/sho....php?t=1015603 So let's go a little bit more into details. The N55 engine family: The M2 engine is part of the N55 inline-6 engine family, which is an evolution of the N54 engine family. Both N55 and N54 have very similar engine block designs and share the same bore and stroke: 84 mm (3.3 in) bore, 89.6 mm (3.5 in) stroke and 2,979 cc (181.8 cu in) capacity. Both engines are of OPEN DECK design, meaning that there is a space between the engine block and cylinders sleeves to cool the engine. This engine design is the cheapest to manufacture and provides the best cooling efficiency. The difference between the N55 and N54 lies primarily in the fact that the N54 has twin turbochargers whereas the N55 has only one twin scroll turbocharger. Another difference is that the N54 engine did not have the variable valve lift (Valvetronic) whereas the N55 does. Also the N54 had piezo injectors and the N55 has solenoid injectors... Below are pics of both engines and you can see that they are of very similar design. Pic of N54 engine block Pic of N55 engine block Now, let's go back to the M2 engine. Its official denomination is N55B30T0 (272 kW). That means it uses the N55 open deck engine block. The difference between this N55B30T0 to the "regular" N55 engine (or N55B30O0 in its latest and most powerful version (240 kW)) are, according to BMW, "the M2 gets the pistons and crankshaft bearings from the BMW M3/M4 and also their valvetronic variable valve timing system. The BMW M2 also receives an upgraded cooling and oil sump system." The M3/M4 engine is a different beast altogether and has a different denomination (S55B30T0 (317 kW)). This engine block is of CLOSE DECK design which means that there is no space between the engine block and cylinder sleeves, which makes for a much stronger engine, but harder to cool. A close deck design engine is a design made for high performance engines and engines used in competition. since there is no coolant space between the engine block and cylinder sleeves, the engine is much stronger and can endure higher loads for a longer time. The drawback is that this kind of engine needs a much beefier cooling system. Pic of S55 engine block showing close deck design, see how much thicker and sturdier the engine block is... Now let's have a visual comparison of these engines with images taken from BMW's own technical information: Visual of N55 engine block showing the open deck design: Visual of S55 engine block showing the close deck design (and text from BMW confirming it) S55 engine external view N55 engine external view
1981 323i, 143 Kashmir-Metallic, 0094 Pergament, Sports M5, LSD.
02-13-2017, 06:49 PM | #47 |
salty cowboys fan
6158
Rep 3,406
Realoem FWIW: http://www.realoem.com/bmw/enUS/show...diagId=11_4446
02-13-2017, 06:51 PM | #48 | ||
Rep 3,888
From BMW Group press release: Quote:
02-13-2017, 06:59 PM | #49 |
Rep 3,888
Sounds like jumping the gun.
I also spoke with BMW Genius who, citing from an internal Engineering Technical Training manual, told me that the engine was a closed deck. - No one from BMW corporate has yet denied that it is closed deck. - No actual photographs have been shown of N55B30T0 engine with head removed |
02-13-2017, 07:01 PM | #50 |
Rep 5,102
You sure that last pic is an N55? Mine doesn't look anything like that configuration. Maybe a B58?
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
02-13-2017, 07:13 PM | #52 |
Rep 1,973
If you are referring to my pics. Yes it is: taken from the BMW own technical information PDF...
02-13-2017, 07:15 PM | #53 | |
Rep 1,973
All the evidence is there from BMW'S own technical documents...
02-13-2017, 07:16 PM | #54 | |
Rep 3,888
02-13-2017, 07:18 PM | #55 |
Rep 1,973
Blatant lies.... see my post for evidence... http://f87.bimmerpost.com/forums/sho...8&postcount=46
02-13-2017, 07:23 PM | #56 |
Rep 5,102
Bizarre. Doesn't look remotely like my 2016 N55 engine, specifically the pipe to the left and the rectangular box on the right side of the block. Sure looks like the B58 but what do I know.
02-13-2017, 07:28 PM | #57 |
Rep 5,102
This isn't my car, but this pic is exactly my config. Doesn't quite look the same. Wonder why.
02-13-2017, 07:36 PM | #58 | |
Rep 1,973
This hints that this engine block will probably be the base of the next generation M3-M4 engines as it is over-engineered from the start. I suspect that the M240i will have the potential of much higher hp via tuning than the current M2 just because of the inherent sturdiness of the B58 engine...
Yellowflash21369.50 ORIGIN M.3159.50 |
02-13-2017, 07:39 PM | #59 | |
7906
Rep 11,785
Personally I would say your stance regarding this is much too strong without clear evidence. It's much more likely that the error was an oversight. So many people in these threads barely know the difference between open and closed deck and it wouldn't be surprising at all to me to find that the person that wrote the material was in error or reversed the wording. I would think that's a lot more likely than a deliberate plot to fool the customer. Anyone of course that feels that they got ripped off after relying on minor details in a press release ( like what type of tires will come on the vehicle ) will likely have a difficult time proving their case ... |
02-13-2017, 07:39 PM | #60 | |
Rep 1,973
On the other hand, the new B58 engine is!
02-13-2017, 07:39 PM | #61 |
Rep 5,102
oh crap.... just realized that image for the n55 was an M2 engine not a 235 n55. Dang. Sorry!
02-13-2017, 08:10 PM | #62 |
this is the way
18136
Rep 8,516
@1m21s, what's that look like?
02-13-2017, 08:11 PM | #63 | |
Rep 13,093
Given the obvious change in the "Powerful Engines" M2 section of the official BMWNA website in the meantime, would be interesting to know what is exactly stated in the internal M2 Technical Training (US) nowadays re the M2 engine deck design.
///M is art ↔ Artemis
02-13-2017, 08:13 PM | #64 | ||
Rep 647
02-13-2017, 08:15 PM | #65 |
Rep 1,973
To complete my case, here's the excerpt from the technical training material of the M2. The attached is the section on the engine.
First here are the regular N55 engine (code: N55B30O0) and the M2's N55 engines side by side (code: N55B30T0). You can see that they share the SAME engine block. Therefore there is NO WAY possible that this engine block could be of closed deck design. It would need to be much sturdier in design . The difference between the 2 engines are:
N55B30O0 and N55B30T0 side by side, note the same crankcase Except from the M2 Technical training showing the difference between the N55B30O0 and N55B30T0: S55 engine for comparison. Note that the crankcase is much sturdier. and of different design... I guess this says it all!
terrywang94.00 |
