BMW 3-Series (E90 E92) Forum
Is it normal for the engine to burn up this much oil in only 5000 miles?
10-18-2016, 12:01 AM | #1 |
Rep 424
I have driven about 5000 miles since the last oil change back in January and now the oil level is halfway between max and min.
Assuming the sensor is accurate, does this usage rate look normal or is my engine burning excessive oil? |
10-18-2016, 12:31 AM | #2 | |
Rep 2,367
Drives: 2011 335i
10-18-2016, 12:36 AM | #3 |
Where'd my VTEC go?
481
Rep 6,067
That's half a quart in 5000 miles, so nothing too out of the ordinary. But yes, I would check for any signs of leakage.
Most automakers won't even consider it a problem unless you lose 1 quart in 1000-2000 miles or less.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
10-18-2016, 02:51 AM | #5 |
1920
Rep 13,119
The entire length of the graph is only the top quart
So as the last guy said that is .5 quarts is pretty good. If you add oil there is a delay between when you add it and when the graph stabilizes enough to take a reading. You have to drive the car about 3 times for over 20 minutes before you can believe the reading. |
10-18-2016, 04:48 AM | #6 | |
General
17393
Rep 18,784
The e-dipstick is accurate but is not a direct-read device like a mechanical dipstick. The e-dipstick has a cycle time built into it that, as ctuna said, takes time for the system to establish a new reading and determine the new oil level. It takes over ten minutes of drive time and the car (engine) must reach several operating parameters before a new level is established. The problem is this, using you car as an example, your engine is showing 1/2 quart low on engine oil. The normal reaction is to add a 1/2 quart of oil to the engine and then immediately take a reading. Well the e-dipstick, until it meets the operating parameters (time, temperature, g-forces), will report the last-known reading, which will still be 1/2 quart low. So then the reaction is to add the other 1/2 quart, and now the engine can be overfull with oil. Secondly, your car is showing a 1/2 quart low, but it could be closer to 3/4 of a quart low but just not yet there. Adding in a 1/2 quart and waiting for the correct update interval, the e-dipstick may return a reading of full and then the next day return a reading of 3/4 full. This is why waiting until the "+1QT" notification comes up to top off the oil is the best procedure to follow. The engine holds 7 quarts of oil, which is more than enough if down to 6.5 quarts of oil to safely run the engine until the CBS shows the "+1QT" notification. And a consuming a 1/2 quart in 5,000 miles is completely normal. Any oil leak the N52 has, valve cover, oil pan, or oil filter housing, even all three together, will not cause that much oil loss.
max_330i340.00 |
10-18-2016, 04:51 AM | #7 |
Rep 3,655
Completely normal. By the way, you should change your oil at 5-7k, don't wait til 15k like the manual says. DI engines dilute the oil a lot and your turbos will thank you for changing it more often.
10-18-2016, 04:54 AM | #8 |
General
17393
Rep 18,784
If he had turbos....
10-18-2016, 05:12 AM | #10 |
General
17393
Rep 18,784
I can't speak to the N54/55 because I have no direct experience with it, but the N52 has no problems going 10,000 - 15,000 on oil changes.
10-18-2016, 06:47 AM | #11 |
Rep 221
My car, also a 2011 328i, appears to lose/burn no oil between oil changes. The sensor has never indicated anything less than full the entire time I've owned it.
2011 328i Coupe | Alpine White | Oyster/Black Dakota Leather | M Sport Package | Premium Package | iDrive | Harman Kardon Surround | Steptronic
10-18-2016, 07:18 AM | #12 | |
1706
Rep 14,829
My wife's car needs to top off, I'd say 1/4 qt. every guessing 700 miles? 1/2 qt. would put it over (has a dipstick). Do the math, that could be 2 qts. per change. Friend's 2013 Q5, same thing, and Audi "corrected" the issue in '14. Corrected?? Friend's Odyssey needed new piston rings and it was a recall. I do know all car mfgs. will say it's normal (even Porsche), I just wonder why some cars don't consume oil, of the same model/year..... |
10-18-2016, 08:02 AM | #13 |
Fuck it dude, let's go bowling.
888
Rep 2,480
OP, this is likely a leak, not "burning". You will not know if the car leaks until you inspect the VC, OFH and oil pan. Oil will collect in your underbelly panel for a good long while, and excess may just "bleed" off out the back of the panel while underway. You can't tell just by looking at your garage floor.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
10-18-2016, 08:15 AM | #14 | ||
Rep 3,655
10-18-2016, 08:29 AM | #15 |
Rep 231
In my 328, sometimes the sensor goes wonky. A few times I've seen the oil level at half-way, think that the next time I fill up I should add some and then bingo it's back at full a few days later.
If I drive hard, losing half a quart over a few thousand wouldn't bother me at all. |
10-18-2016, 09:14 AM | #16 |
1706
Rep 14,829
of course because everyone on this thread is likely very observant, we want to know "why." Probably 75% of the motorists out there don't care, if they have to add, they just add, or let someone else do it.
Today, at 5 AM, I lifted the hood of the used Lexus as I have been doing for 2 weeks ( cuz I want to be 100% sure no fluids are being lost (been checking oil and coolant, ps and brakes). And then, I see a puddle under the car....oh boy..... Start doing some investigation, and there is a hole, with a tube and grommet, and the tube does not protrude out of the hole. The underside is smooth like the BMW. I don't know what the tube is draining, but at least the puddle about 3" in diameter has an explanation.... |
10-18-2016, 09:19 AM | #17 | |
General
17393
Rep 18,784
10-18-2016, 09:28 AM | #18 | |
1706
Rep 14,829
10-18-2016, 08:18 PM | #19 |
Rep 424
Thank you all for your help!
I took this picture yesterday before getting gas. As for the oil change, I plan to go in at 52500 miles as the last one was at 45k. I asked my dad who has a 06 E60 and he said it's normal to see the oil level go down a bit over time. |
10-18-2016, 09:02 PM | #20 |
Rep 2,367
Drives: 2011 335i
What I hate is when it's almost at min and it fluctuates between telling u to add a quart and being ok
10-19-2016, 04:14 AM | #21 |
Rep 595
10-19-2016, 04:51 AM | #22 |
General
17393
Rep 18,784
Why?
