M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Oil Change Price
      09-22-2016, 01:38 PM   #1
PackPride85
Oil Change Price
I don't plan on waiting until 10k for the free change. Anyone know how much the dealer charges for oil changes on the M2?
      09-23-2016, 11:26 AM   #2
gmzanatta
gmzanatta's Avatar
1807
Drives: LBB 6MT M2 # 660/713
Too many variables. Why not just call you local dealer for an accurate quote?
      09-23-2016, 12:12 PM   #3
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
2018 Porsche GT3  [0.00]
2020 BMW X1  [0.00]
Or DIY. Total DIY cost is less than $40.
2016 GT4, 2016 M2, 2014 X1, 2013 135is, 2006 330i, 2003 323 Ci, 2001 330i, 1999 M3 (RIP), 1996 318is, some non-BMWs
      09-29-2016, 10:21 PM   #4
Nicname
Nicname's Avatar
Drives: 2021 M2C
Should oil changes be done every 6-7k miles?
Current: ///M2C
Past: ///M2
997.1 Turbo
///M3 E92
      09-29-2016, 11:54 PM   #5
omasou
omasou's Avatar
Drives: BMWs
2022 BMW X6 40i  [0.00]
2020 BMW M2C  [0.00]
Check out the BMW VALUE SERVICE and this page of posts...http://f87.bimmerpost.com/forums/sho...1303060&page=3
Where are you buying an oil filter and 7 qts of synthetic oil for $40?
When parts are $77+ OEM Oil Service Kit / Inspection I it makes the $79 BMW VALUE SERVICE worth a trip to the dealer.
      09-30-2016, 07:09 AM   #6
Pyrat 2
Pyrat 2's Avatar
2020 BMW X1  [0.00]
Check out the BMW VALUE SERVICE and this page of posts...http://f87.bimmerpost.com/forums/sho...060&page=3
Walmart sells 5 quarts of LL01 synthetic for $23. Filters available at lots of places for less than $10.
BAN_M2C3639.50
      09-30-2016, 01:16 PM   #7
BAN_M2C
BAN_M2C's Avatar
Drives: 2019 M2 Competition
That's what I usually do to my daily car, Mobil 1 from Walmart 5 qt always under $30 and a new Filter $5 when bought in bulk and changed every 5K miles..
2019 M2 Competition Ordered
2017 LBB M2|2011 BSM 135i|Follow me on IG
2019 M2 Competition|2011 BSM 135i|1987 325is|1974 Granarot 2002|2017 LBB M2 (Sold)
      09-30-2016, 02:32 PM   #8
Pyrat 2
Pyrat 2's Avatar
2020 BMW X1  [0.00]
No reason you can't do it for your M2 too. They have both Castrol and Mobile 1 LL01 for $23 or$24 plus tax. I change my oil after every track event. Probably unnecessary but cheap insurance. I don't reset the oil service but log it in a book. Then I get the dealer changes too under warranty.
Actually changing mine this weekend after last weekend at Road America.
BAN_M2C3639.50
      09-30-2016, 03:44 PM   #9
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [0.00]
I get that and use to change my own oil but the X5 takes 8 qt and I believe the M2 takes 7 qt which makes the price difference less. That or I'm just getting lazier
      09-30-2016, 04:12 PM   #10
BAN_M2C
BAN_M2C's Avatar
Not unnecessary given the peace of mind you get. I would do a fresh oil change after each track event in my old track car. Just something less to worry about for less than 40 bucks, thats why I bulked up on filters.
      09-30-2016, 04:17 PM   #11
BAN_M2C
BAN_M2C's Avatar
Is age getting to you??
Kidding aside is it uncomfortable to get to the filter etc? All my past cars it has been pretty straightforward and would always do myself unless under dealer maintenance but it wouldn't hurt to have a change in between if the dealer period is too long.
      09-30-2016, 04:27 PM   #12
Pyrat 2
Pyrat 2's Avatar
2020 BMW X1  [0.00]
Slightly off topic but I thought you all might be interested. My E90 330 and E84 X1 use the exact same filter. For grins I compared to the M2 filter. See pic below. They are identical in every dimension and way except that the part number is different and the M2 filter is stamped M next to the part number. E90 filter costs $9.80 online. The M2 costs $15 from the same place online.
Appreciate 6
BAN_M2C3639.50
omasou1695.00
oolas3383.50
BSMF87138.00
dtmurf312.50
      09-30-2016, 04:42 PM   #13
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [0.00]
It is usually straight forward but the new cars have a under panel that needs to first be removed. On the X5 I can take it off w/o jacking up the car but it's a bit of a tight fit to get the rear screw
That's great. I use OEM Bimmerparts when I can but they usually only have older models. Looks like they carry these for the price mentioned, http://www.oembimmerparts.com/search...566327&Submit=
BAN_M2C3639.50
      09-30-2016, 08:24 PM   #14
Pyrat 2
Pyrat 2's Avatar
2020 BMW X1  [0.00]
Huh???
The filter is right on top of the engine under the hood. This is the same as every BMW I've ever owned. 2xE36, 2xE46, 1xE82, 1xE84, 1xF87. It's as easy as it gets.
As far as the drain plug there is no bottom panel in the way of the drain plug. It's right there in plain sight. All of my other BMWs have either had it in plain sight or at worst required a plastic trap door to be opened that did not require any tools. The M2 is far and away the easiest oil change of any BMW or other car I've owned assuming of course that you put it up on ramps as it sits fairly low. One exception. The front spoiler sits very low so putting up on ramps requires that your ramps be long enough.
BAN_M2C3639.50
omasou1695.00
      10-01-2016, 03:47 AM   #15
ric124
ric124's Avatar
Jamaica
429
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
It's less than 10k miles for the oil change or this could be adjusting for my driving style. Oil already got changed at 1200 miles and now it says next oil change in 6800 miles. It's synthetic oil so following the car/manufacturer recommendations should be fine.
BAN_M2C3639.50
      04-10-2018, 03:53 PM   #16
alscks0414
alscks0414's Avatar
656
Drives: MY18 X3 M40i, MY18 M3 ZCP
huh?? what is this app????
      04-10-2018, 07:25 PM   #17
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [4.87]
It is BMW Connected.
      04-10-2018, 07:31 PM   #18
alscks0414
alscks0414's Avatar
656
Thanks just checked now but only offered to us. Canadians, again, are freaking included....
      05-03-2018, 04:29 PM   #19
bummie
Drives: 2017 M2 LBB
My local dealer charges $50 for an oil change if you use the coupon sent via email. I've used an independent guy for years and he charges $125. Needless to say, I'll continue using my BMW store for oil changes as long as they keep sending me coupons.
      05-13-2018, 10:05 AM   #20
tranck
tranck's Avatar
486
Drives: 2018 Alpine White BMW M2
2018 M2  [0.00]
Sry..I'm new...where do you get these coupons? Link?
      05-28-2018, 03:31 AM   #21
akkando
akkando's Avatar
5015
Yes, how do I get in on these coupons?
Copyright ©2000 - 2021, vBulletin Solutions Inc.
