09-03-2016, 10:05 AM | #3 | |
Rep 624
We still have to do wheel alignment (on monday) then I'll know more on what the range of possible camber are with these :-D The camber plates I got are made in Sweden so maybe not for you in the US (shipping and so on?). But for anyone within the EU it might be a thing? http://www.millway.se/suspension/cam...-coupe-m2-8312 |
09-04-2016, 12:27 PM | #5 |
Rep 551
I recommend camber plates from Ground Control or waiting for the units from Vorshlag.
09-05-2016, 09:56 AM | #6 |
Rep 624
So we did the wheel aligment today. No problem setting front camber to 3 degrees which is what I wanted. There's a lot of room dialing in more. I didn't try out max but I'd guess in the neighborhood of 4 degrees.
In the rear (all stock) max what was possible seemed to be just over 2 degrees. We got max 2.0 on one side and 2,2 on the other. For me 3 degrees in the front and 2 degrees at the rear is just fine. |
09-10-2016, 11:44 PM | #8 |
Rep 624
09-10-2016, 11:51 PM | #9 |
3843
Rep 54,362
Drives: F80 M3
09-12-2016, 10:00 AM | #10 |
Rep 1,541
Are they loud? Any clunking noises when driven on the street?
09-12-2016, 10:08 AM | #11 |
Rep 1,541
09-12-2016, 10:12 AM | #12 |
Rep 3,006
What do you think of these?
http://www.2addicts.com/forums/showthread.php?t=1221293 I asked Dinan if they will work w/the M2 but have not received a response. |
09-12-2016, 10:14 AM | #13 |
Rep 3,006
Question.
I have watched the guys multiple times align my cars and have noticed just torquing the bolts down can throw the numbers off and requires a bit of fiddling. When using the plates and adjusting the settings for track day, autocross, etc and then back to street without an alignment rack. Will the alignment be off a significant amount? |
09-12-2016, 10:28 AM | #14 | |
Rep 624
omasou2088.00 |
09-12-2016, 10:29 AM | #15 |
Rep 624
Anthony235715.00 |
09-12-2016, 12:15 PM | #16 | |
3843
Rep 54,362
Drives: F80 M3
F2x and F87 plates are the same. I think Dinan ran into some issues and have recalled all the plates. You can probably search for that thread. |
09-13-2016, 12:36 PM | #18 | |
Rep 1,541
Thank you.
09-13-2016, 04:23 PM | #19 |
3843
Rep 54,362
Drives: F80 M3
Anthony235715.00 |
09-14-2016, 09:36 AM | #20 |
Rep 1,541
I figured. Thanks for the verification
07-06-2017, 03:56 AM | #21 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
07-07-2017, 04:00 AM | #22 |
Rep 53
I find the Millway plates very silent
have them with a KW v3 |
Nugget649.50 chrispraeger761.00 |
