E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > N52 cooling fan not working
Reply
      08-23-2016, 02:26 PM   #1
mausmaus
Drives: 2011 X5 35d, 328i xDrive LCI
Question N52 cooling fan not working
Back in July my battery died. In the process of jumping or charging it prior to replacing the battery, my LCM/FRM3 bricked.
Installed and registered a new battery. Sent LCM to Alex@AlpineMSS and he flashed it for me. Loaded up INPA coded LCM, good as new.
At some point my cooling fan also stopped working.
The car is throwing a 2EFE error code for the DME module.
Diagnosing effort so far...
  1. Tried activating it manually in INPA, but no luck.
  2. Checked cooling fan fuse (#88), looks fine.
  3. Checked relay in the e-box and in glove compartment.
  4. Jump wired the coolant temperature sensor...nothing.
  5. Plugged in used fan from junk yard, tried INPA activation again...nothing. The auto recycler guarantees their parts, so it's hard to imagine theirs is dead as well.
I'm going to plug my multimeter leads into the cooling fan connector, and see if I get a 12v reading by trying INPA activation again.
Remaining guesses are: DME cannot send signal to fan, a wire has shorted out, or there's a mystery fuse that I do not know about.
      10-02-2016, 06:32 PM   #2
mausmaus
bump, for help
      10-02-2016, 06:50 PM   #3
PourBoi-Jay
PourBoi-Jay's Avatar
Drives: 2009 335i M-Sport
Check all of your ground points. I was having nearly the same issues, and discovered my fan ground wasn't properly bolted to the chassis.
Try that first before anything else.
2009 E90 335i
Black Sapphire || Oyster || M-Sport || 6spd
BMW-Performance||OEM+||Cobb||Wagner||CP-e||AFE||Forge||ER||BMS||Lux||RB||Bridgestone||Manz o||Bilstein||Eibach||Whiteline
Reply
Tags
cooling fan, diy, n52
e90post
