07-29-2016, 01:35 AM | #1 |
Rep 780
Drives: 13 GT50014 AW M235i(sold)
Need help big issues
So I coded EBT and evreything was great but then I lost my instrument gauge lights and a service message came up. So I loaded the backup and tried to code the ecus back to before and I coded the one that sets off every possible error- I tried to insert a new caf file but no luck.. So uh little help pretty please
07-29-2016, 05:58 AM | #2 |
Rep 780
I loaded my saved SVT and coded the entire file and got 7 errors, not sure where to go from here
07-29-2016, 02:20 PM | #3 | |
Rep 5,262
You should not code the whole Ecu tree. You should code just one Ecu at a time |
07-29-2016, 03:29 PM | #4 |
Rep 780
So I followed revert instructions and my car is back to normal, just took a few restarts. I'll find out later if my Gaige lights are back or not - has anyone ever heard of cluster lights going out with coding?
07-29-2016, 04:06 PM | #5 |
Rep 780
I'm also having difficulty getting sport display to work, the rest of the codes have been fine now however
07-29-2016, 05:15 PM | #6 |
Rep 5,262
07-29-2016, 06:22 PM | #7 |
Rep 780
07-29-2016, 07:48 PM | #8 |
Rep 5,262
07-29-2016, 07:54 PM | #9 |
Rep 8,364
Certain ECU's will throw errors when coding them. As long as there are no errors shown in E-sys and still have blue CAFD with green check marks when read SVT, then usually fine. Errors on instrument cluster or head unit will either clear themselves with driving or you sometimes have to use external transmitter. You should not be loading SVT. It is fine to load FA if you VO coding without writing changes to VCM.
07-29-2016, 08:30 PM | #10 | |
Rep 780
Tpms is not working for me no matter what however- I have 3 metal caps one plastic if matters |
07-29-2016, 08:54 PM | #11 | |
Rep 5,262
you in the US? All M235s in the US will have metal stems if you have the one below then you don't have the sensors? |
07-29-2016, 10:10 PM | #12 | |
Rep 8,364
07-30-2016, 12:27 PM | #13 |
Rep 780
I am in the US, I just get the green tire color on the screen- no values
07-30-2016, 03:03 PM | #14 |
Rep 5,262
07-30-2016, 03:41 PM | #15 |
Rep 780
Hmm yeah I'm going to a pro coder later today to have him just do the rest of the features and to take a crack at getting some of these (tpms) possibly working
07-30-2016, 03:46 PM | #16 |
Rep 780
07-30-2016, 04:06 PM | #17 | |
Rep 5,262
07-30-2016, 05:14 PM | #18 |
Rep 780
I guess I'll se whatsup with it, maybe the coder can figure it out- I do really want the tpms data not just OKAY/NOTOKAY
07-30-2016, 08:30 PM | #19 |
Rep 8,364
Good luck. On newer head units, PSI should show from factory and it is only the temperature readings that need to be coded. Once the tires turn green after a little driving, it should register shortly after.
07-30-2016, 08:41 PM | #20 | |
Rep 5,262
Maybe the previous guy had different wheels without sensors and coded out the TPMS so it wouldn't throw an error and now if he put the stock wheels back on, the sensors won't do anything if the car was coded out |
07-30-2016, 09:03 PM | #21 |
Rep 780
It's like your name is Miss Cleo or something haha, yeah exactly what was done, it was used- picked it up a week ago. Off lease just has a few niggles- like changes in volume don't show on any screen? Unless that's normal
