M2 Technical Topics > Suspension | Brakes | Chassis > F87 M2 share your alignment specs
      06-28-2016, 11:18 AM   #1
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I thought I would start a thread for everyone to share specs or any thoughts regarding factory or track oriented alignment settings.
Edit : This first alignment was with lowering springs only and no camber plates. I had a bit too much toe in at the rear.
When I installed coilovers/camber plates I settled on 1/16 total toe in the rear as recommended by HPAutosport.
0 toe with -2.8 degrees of camber front and
-2.0 in the rear. Car felt great on the street and track.
      06-28-2016, 11:34 AM   #2
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
There is a thread already where I posted mine.
http://f87.bimmerpost.com/forums/sho...ight=alignment
      06-28-2016, 11:49 AM   #3
HP Autosport
Drives: F80 M3
From what you posted the rear has way too much toe-in, am I reading that right?
      06-28-2016, 03:21 PM   #4
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Thanks
      06-28-2016, 03:27 PM   #5
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I believe the total toe would translate to just about 4mm of total toe in. .37 degree of total toe.
I was put off that the m4 spec called for almost 0 toe in the rear. I've never ran so close to 0 on a rwd car. So I went in to about 4mm, equal to other f80 track alignments I've seen. Although I'm not running much camber at all.
What's your setup? I could be totally wrong but I didn't think it was overkill.
It doesn't help reading a alignment in MM and trying to translate/convert over from Swedish haha.
      06-28-2016, 03:38 PM   #6
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Most of the alignments should be easy to understand the names of.
The numbers are in the order Before // Accepted range // After adjustments. So Börvärden is what the allowed specs are for each item.
      06-28-2016, 03:41 PM   #7
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Yeah I took a look at it and figured it out. Thanks for posting that btw.
I've just heard of the f80 problems of squirm under braking with the almost 0 toe in they call for. I believe IND and others pushed it to around 4mm total to help the problem.
      06-28-2016, 03:53 PM   #8
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
I haven't pushed the car to notice anything like that (or it doesn't with the MPS) under braking.
      06-28-2016, 03:56 PM   #9
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I'll see in a month or so at the track. I'm new to track driving but I'll share anything I come across.
      06-28-2016, 04:17 PM   #10
David@ActiveAutowerke
We're currently setup with -2.5* camber up front with 0 toe and -2* camber in the rear with 1/16" total toe-in.
      06-28-2016, 05:16 PM   #11
HP Autosport
Drives: F80 M3
I was put off that the m4 spec called for 0 toe in the rear. I've never ran 0 on a rwd car. So I went in to about 4mm, equal to other f80 track alignments I've seen. Although I'm not running much camber at all.
zero toe front and slight toe-in in the back is what you want. If that what you have, you are good to go.
      06-28-2016, 06:43 PM   #12
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Thanks guys. I'll dial it back a little bit
      06-28-2016, 08:35 PM   #13
clubsport
Drives: LBB
Mine, with just camber plates are:
Front -2.3
toe 1/64 in
back -1.9
toe 5/64 in
      07-04-2016, 09:21 AM   #14
MR.
MR.'s Avatar
Guys, what is your preferred alignment setting for a stock car? Any thoughts on that?
I might have my tuner look at the set up since I have vibrations under heavy braking, and I do not think my brakes would be the main issue here with only 10K km driven.
MR
      07-04-2016, 09:48 AM   #15
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Anyone, how much front camber can be dialed in without aftermarket camber plates?
      07-04-2016, 11:30 AM   #16
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
None over stock at -1.5
      07-04-2016, 12:50 PM   #17
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
MR
I probably dialed in a little too much rear toe. But my preferred settings are front 0 toe, rear-more toe in than it calls for, just a tiny bit.
Camber for me as well as everyone is -1.5 up front unless you have plates. No pins to pull here.
I set the rear at -2.
      07-06-2016, 05:52 AM   #18
MR.
MR.'s Avatar
Excellent thanks!
MR
      07-07-2016, 04:55 PM   #19
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
So stock camber up front is 1.5? Shouldn't it change to something like 1.7 after being lowered?
Current
AW BMW M2
Past
VO BMW 1M
      07-07-2016, 10:52 PM   #20
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
It should once settled. It didn't Initially, at least without me in the car.
      07-11-2017, 07:18 PM   #21
chillindrdude
chillindrdude's Avatar
1161
Drives: anything with 4 wheels
Getting my camber plates done tomorrow. Anyone else with numbers?
My Trackable Street Car
2016 BMW M4 GTS
      07-11-2017, 11:03 PM   #22
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
TC Kline plates on coilovers here. Fronts are at -3 and rears at -2.3/4 on stock alignment eccentric bolts and stock arms. The front can go one degree more or all the way back to stock adjustability wise.
The only other suspension mods are H&R sways and adjustable links.
have a feeling I might be dialing back those camber figures but I have yet to see tires temps on track with the new setup. The car feels great though.
0 toe front
And a little more than factory toe in rear
