M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Winter wheels M2, will e92 M3 Winter Wheels Fit?
      11-26-2016, 06:46 PM   #23
BFLY
BFLY's Avatar
79
2020 BMW/M2C  [0.00]
2012 BMW X5 3.5d  [0.00]
2017 BMW M2  [0.00]
My wheels are from e90 M3 (style 270m). They feet perfectly.
      11-26-2016, 06:49 PM   #24
BFLY
BFLY's Avatar
79
2020 BMW/M2C  [0.00]
2017 BMW M2  [0.00]
Also, surprisingly, the tire check light did not come on. I found that to be interesting, I was fully expecting it to not be compatible.
      11-26-2016, 09:42 PM   #25
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Are those 18's or 19's?
www.ReTuneTheDeTune.com
      11-27-2016, 09:10 AM   #26
BFLY
BFLY's Avatar
79
2020 BMW/M2C  [0.00]
2017 BMW M2  [0.00]
They are 235/40/18 square.
      11-28-2016, 08:13 AM   #27
ChrisK
ChrisK's Avatar
Drives: '19 M2C
and no issues at all?
      11-28-2016, 10:18 AM   #28
WRXXX
Drives: E92 SG M3 (SOLD), '17 M2
Finally put mine recently. 235/40/18. Rims were similar to op's. Its tight but it fits. Cleared the brakes with just a few mm to spare but it fits. Took it out for a spin. No noise or rubbing from the brakes.
      11-28-2016, 02:47 PM   #29
BFLY
BFLY's Avatar
79
2020 BMW/M2C  [0.00]
2017 BMW M2  [0.00]
The 270M wheels fit perfectly. Wheel spacing to the shock tower and the fender is good and clears the brakes without adding any spacers.
At speed, there isn't any pulling and hard breaking is straight. I don't think I'll need an alignment from the way the car feels.
I do have less traction, but they are winter tires.
      12-19-2016, 10:03 AM   #30
CarEnthused
CarEnthused's Avatar
77
Drives: GT4
Same wheels as the OP and my rears scrape against the back of the caliper. Very disappointing, I was supposed to drive 1200 miles round trip this weekend but without a proper winter setup I'm not sure how I'm going to pull that off without paying considerably for it.
carenthused.com - VROOM15 for 15% off LensRentals
[CURRENT] 2016 Porsche GT4 (for sale)
[PREVIOUS] '17 Alfa Romeo Giulia QV, '16 M2, '13 911 C2 7MT, '08 E92 M3, '07 E92 335i, '97 M3 Coupe, '95 318ti
      09-25-2019, 04:29 PM   #31
TheAMackAttack
Drives: 2016 M2 LBB DCT
Resurrecting this one from the dead... any idea whether M220 wheels from an E92 M3 would fit on our M2's? Found a great deal on some that have winter tires on them and would love to pick those up if they'd fit.
I believe the stats for M220 wheels are F: 19x8.5, ET29, R: 19x9.5 ET23...
      09-25-2019, 04:35 PM   #32
M3-Mike
M3-Mike's Avatar
53
Drives: 2020 M2 Competition
Bump, yes I too have a set of M220 19" rims in the garage, if they fit my 2020 M2 they would be great as winters.
      09-25-2019, 04:44 PM   #33
TheAMackAttack
Actually... the M220's I have my eyes on are a square setup (19x9.5) with 255/35/19 tires in the fronts and 265/35/19 rears... I dont really understand the whole offset thing and hoping that someone who understands it better than me can opine on whether or not these would fit. Thanks!
      09-25-2019, 05:15 PM   #34
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Offset is where the hub is in relation to the center line of the wheel. Most wheels have a negative offset.
Stock wheels on the M2 are:
19x9 ET29
19x10 ET40
A lower offset effectively moves the mount point closer to the center line of the wheel, making them protrude further out when mounting them on your car.
Offsets are measured in millimeters, so ET29 is effectively 29mm off the centerline of the wheel, further towards the outside of the rim. If you were to go with say, an ET25 wheel, that would put the mount 4mm closer to the centerline, and push the wheel out an additional 4mm.
Compounding this, the offset is in relation to the wheel width as well! Stock front wheels are 9". If you go with an 8.5" wheel in the front, it changes everything in relation to your required offsets.
The main concerns with offsets are to ensure the tire does not rub on suspension, or on the fender when turning.
I realize this doesn't answer your question, but there are a number of tire/wheel calculators out there that will give you an idea of how much different a particular setup is.
In addition, if you own an M2C, you also have to be concerned with barrel clearances, even with 19" wheels. The brakes are massive, and some 19" wheels won't clear them. For the folks with the OG M2, we have the same issue with 18" wheels.
Hope this helps!
EDIT: if the M220s you are talking about are indeed square, they are probably 2 sets of rear wheels. Given the offset of ET23 (assuming, please check) the fronts are going to stick out about another 12mm or so, and the rears are about 10mm or so. These should be ok as far as offset goes, but check your barrel clearances.
https://www.willtheyfit.com/index.ph...9-5&offset2=23
Motorcity BMWCCA Member
Instagram | YouTube
      09-25-2019, 05:23 PM   #35
TheAMackAttack
19x9 ET29
19x10 ET40
Hope this helps!
Thanks... so I googled a wheel fitment calculator and its saying that the front M220's would have an inner rim which is 0.3mm closer to the suspension strut and that outer rim will poke out 12.4mm more than before. And in the rear, the inner rim will be 23.4mm further away from the suspension strut. The outer rim will poke out 10.7mm more than before.
So trying to interpret this would this mean that I would need a spacer in the front but that the rear would be fine?
      09-25-2019, 05:26 PM   #36
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
19x9 ET29
19x10 ET40
Hope this helps!
No, you won't need a spacer. The clearances to the strut are fine. Adding a spacer is going to push it even further out. You're closer to your fenders now, but it's well within acceptable parameters..
See my edit above.
For reference, I run 18x10 ET35 wheels (square) with 265/35r18 tires for my track setup. I have to have at least a 12mm spacer in the front (effective offset ET23) to clear my suspension due to the wide wheels and tires. I run a 5mm spacer in the rear to even it out a bit.
Instagram | YouTube
      09-25-2019, 05:44 PM   #37
TheAMackAttack
See my edit above.
Thanks for your insight, man... really appreciate it. So one last question, I won't need a camber plate or anything? I could just expect to bolt these things right on?
      09-25-2019, 05:48 PM   #38
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
See my edit above.
You shouldn't. But there may be a bit of rubbing on the liner.
It all comes down to barrel clearance. You'll have to test fit for that or find someone who has them installed.
Instagram | YouTube
