2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Enabling video in motion MY16
      06-13-2016, 10:56 AM   #1
Tony88
Drives: M235ix
Hey guys I can't seem to find the SPEEDLOCK_X_KMH_MAX or MIN on my 2016 M235i. They both exist in a different module on the same ecu for I think navigation 3006 when I use the search function but its already set to not active and seems like it would only effect nav anyway. I found everything else needed to disable the different locks but this has my stumped.
Has something changed in the newer cars?
Any help would be appreciated!
Thanks!
      06-14-2016, 02:14 AM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Have you tested the coding?
      06-14-2016, 10:49 AM   #3
Tony88
Drives: M235ix
What do you mean? I have done quite a bit of other coding with no problems and everything else has worked fine. I also have tested video in motion and it works right up until I move a few mph and then stops.
      06-14-2016, 10:56 AM   #4
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Thanks!
Did you set the speed lock to FF ?
      06-14-2016, 11:58 AM   #5
Tony88
Drives: M235ix
That's what I'm saying I can't find. It doesn't even seem to be there so I can change the values.
I already changed the handbrake/gearbox in P to none
and the handbrake lock is set to not active
Just simply can't find the SPEEDLOCK_X_KMH_MIN/MAX lines to edit.
      06-14-2016, 12:05 PM   #6
Almaretto
Almaretto's Avatar
2374
It is there.
      06-14-2016, 01:39 PM   #7
Tony88
Drives: M235ix
Man I can't find it for the life of me. Even if I use the search function neither one comes up except for in the 3006 Nav section so its not the correct ones I want.
I don't know where else to look!
When I get home tonight I'll give it another shot
Thanks for the reply guys
      06-14-2016, 04:26 PM   #8
Almaretto
Almaretto's Avatar
2374
Do not get hung up on sections. You probably have the correct parameter if you found the matching verbiage. I am not sure at which I-Step you are, but the image I posted was from CAFD_00000DED_003_015_224.
If you cannot find, feel free to PM me your *.ncd and I can take a look.
      06-20-2016, 11:04 AM   #9
Tony88
Drives: M235ix
Man I'm telling ya, I searched line by line down the whole thing and didn't find the speed lock lines. They only exist like I said in the NAV section but are already set to not active. I don't know where to go from here.
      06-20-2016, 12:14 PM   #10
pikcachu
pikcachu's Avatar
1403
what values can you set for that ? what do you see on the right window where it shows comment and possible values?
      06-20-2016, 02:00 PM   #11
Tony88
Drives: M235ix
I took a screenshot on my laptop at home but I think the only options are
not active/3kmh/10kmh
      06-20-2016, 03:10 PM   #12
Almaretto
Almaretto's Avatar
2374
What is the name of your CAFD?
It sounds like you have HU_NBT_EVO, rather than HU_NBT.
In HU_NBT, SPEEDLOCK_X_KMH_MIN is found in 3000 HMI, with some navigation parameters.
In HU_NBT_EVO, SPEEDLOCK_X_KMH_MIN is found in 3006 Navigation (As shown).
Either way, in those Function Data Lines (FDL's), there are three predetermined, drop-down values (nicht_aktiv, 8_kmh, and 3_kmh). Changing the werte value, will show parameter as UNKNOWN = FF. With that modification along with other parts of this multi-step coding, gives you Video in Motion.
      06-20-2016, 06:46 PM   #13
Tony88
Drives: M235ix
You know your stuff
Yes its HU_NBT_EVO, and yes it's found in 3006 Navigation. I didn't know I was supposed to change the werte value as it already says not active so I didn't think much of it! When I get a chance to play with it again I'll give changing the value a try.
Thanks so much for the help!
      06-20-2016, 06:54 PM   #14
Almaretto
Almaretto's Avatar
2374
You know your stuff
      06-27-2016, 02:40 PM   #15
Tony88
Drives: M235ix
Ok, finally got it working yesterday. I changed the werte value to 1 first but that didn't work so I changed it to 99 and boom, works.
Thanks so much you guys for your help!!
      06-27-2016, 05:06 PM   #16
Almaretto
Almaretto's Avatar
2374
If it works, great; otherwise, you may need these additional settings:
  • 3000 SPEEDLOCK_X_KMH_MAX werte = FF
  • 3000 SPEEDLOCK_X_KMH_MIN werte = FF
  • 3000 VIDEO_HANDBRAKE set to: nicht_aktiv
  • 3000 VIDEO_FRONT_LOCKED set to: nicht_aktiv
  • 3000 VIDEO_SPEEDLOCK_CONDITION set to: none=00
  • SPEEDLOCK_SPEEDVALUE_MIN: Werte = 1F
  • UNBELEGT (below the above): Werte = 07
  • SPEEDLOCK_SPEEDVALUE_MAX: Werte = 3F
  • UNBELEGT (below the above): Werte = 03
      07-04-2016, 08:57 PM   #17
Rommel42
Drives: M235i 2016
Hi Almaretto,
I have the same HU_NBT_EVO on my M235i 2016.I'm new to coding.So far I deleted the seat belt reminder.My question is,how do I change the Werte to FF?Thanks for any help.
      07-04-2016, 10:34 PM   #18
Almaretto
Almaretto's Avatar
2374
Originally Posted by Rommel42 View Post
Hi Almaretto,
For detailed instruction with pictures, see "Change Werte" pdf. Though, basic steps as follows: Right Click Werte > Select Edit > Change value in "Values from ECU" box below > Select "Apply Changes" Icon to Right > Select "Save Icon" to write changes to *.ncd.
  • Note: change drop-down menus or Werte values, NOT both. Drop-down values will automatically change wertes.
  • Any werte value—other than one corresponding to a predefined, drop-down—will result in an option read as “UNKNOWN” when viewed again.
      08-03-2021, 09:21 AM   #19
Pogo99
Drives: 2017 BMW 330i
Many Thanks
I have been coding on my 2017 330i and appreciate the utility of cheat codes created and shared by you.
I am still attempting to enable VIM, and missing something in either coding Werte values, or subsequent speedlock deactivation.
Any additional insight will be greatly appreciated.
      08-05-2021, 10:35 AM   #20
kubax86
kubax86's Avatar
2017 can't do it by just a speedlock coding.
2addicts
