E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Aluminum pedals
Reply
      02-11-2006, 01:06 AM   #1
mykcheng
mykcheng's Avatar
Drives: 2010 E90 M3 6MT
Aluminum pedals
Hey everyone,
I'm new and a proud owner of a Silver 330xi. Was thinking of buying the aluminum pedals from BMW, but don't know if I want to spend money on labor. Are they easy to install on my own, or will it be better to spend money on labor? Also, does anyone not recommend these pedals or has a better idea? Your input and thoughts are greatly appreciated. Thanks.
      02-11-2006, 01:18 AM   #2
godzmod
godzmod's Avatar
Drives: 330ci 2004 SMG
not hard at all to install the pedals.
here is the link show you howto install
http://www.e90post.com/forums/showthread.php?t=1444
330i AW-FullyLoad
oH boy -DonTbNV-
      02-11-2006, 08:38 AM   #3
BMW06
BMW06's Avatar
Drives: F15 xDrive35i
I have installed aluminium pedals myself & it does go really well with aluminium trim. I was thinking of spending on labor too... but it was 125% of the price of pedals itself.
This forum has DIY for them & are pretty accurate. I think one shouldnt spend $110 on labor when its a matter of drilling few holes & driving in few screws. Its too simple...
and the joy u'll get from working on ur car is priceless.....
Originally Posted by mykcheng
Hey everyone,
      02-15-2006, 03:00 PM   #4
climkt
Bimmer Manual all the way
climkt's Avatar
Singapore
66
Drives: e90 320i manual
speaking of pedals and footrests, anybody bought a M e90 aluminium foot rest. The e46 m footrest for the m3 was only available in left hand drive version, I managed to modify it for my prev e46 318i. Hoping to do the same for the e90.
      02-15-2006, 03:04 PM   #5
E90Fleet
South Africa
1312
Drives: BMW
Its still LHD only, but you get a very nice RHD one from AC Schnitzer
BMW if you are reading, I need a job, Please.
      02-15-2006, 03:12 PM   #6
climkt
climkt's Avatar
Singapore
66
hi e90fleet,
do you know the order/ product no for the left hand drive m aluminium footrest for the e90?
my singapore dealership is always very slow to get parts.
      02-15-2006, 03:15 PM   #7
brian32e
brian32e's Avatar
16
Drives: '06 Alpine White 330i ZSP
yikes so the $80 aluminum pedals are $110 to install (near $200 total)??
      02-15-2006, 04:13 PM   #8
ben1364
Drives: E90 330iA
Someone please tell me how much the aluminium pedals improve clutch action, add horsepower/torque, turn in, provide increased fuel efficiency and/or whatever... <g>
      02-15-2006, 05:36 PM   #9
cdheaven
I'm Starving , So I Guess You Are What You Eat
cdheaven's Avatar
229
Drives: 2006 325i
uhh, this is a joke, right?
2006 325i Sparkling Graphite Metallic-Black Leatherette
Navigation-Bmw Assist Automatic-Xenons Carbon Fiber Front Lips-Aluminum Pedals Power/heated Front Seats
5% Tint all around 30% On windshield all the way down
      02-15-2006, 08:16 PM   #10
markE90
markE90's Avatar
Philippines
75
Drives: AW X5 35d
I installed mine..easy!
      02-16-2006, 08:19 PM   #11
Discodancingrover
F=MA?
Discodancingrover's Avatar
17
Drives: 2006 325xi
My dealer told me it would take them 30 minutes max to install them. So abuot $50 for install. I'm going to do it because I don't have access to the tools to get it done.
      02-16-2006, 10:30 PM   #12
cdheaven
cdheaven's Avatar
229
Drives: 2006 325i
fifty isnt too bad. even though its a fun time, and its good to work on your car.
When i called to get a price they were like "uhh, eh, uh, it could take an hour, or two, and its like 180 dollars an hour, or something" and they had no idea. and it was crazy. but fifty sounds very fair.
      02-16-2006, 10:39 PM   #13
marcus330i
marcus330i's Avatar
42
Drives: 2006 330i 6spd
I had problems with the bottom bolts on the gas pedal. I had to use a hemostat to hold the nut in place while I screwed in the bolt. It's a very tight place to put your fingers. I also ended up with another black plastic gas pedal (that came with the alum pedal kit) and it wasn't the same as the original pedal...so I didn't use it. I put the alum plate over the original pedal. (did I screw up?...don't think so...it works/looks perfect)
Realtor Mobile: 6spd / Sport / Prem / Navi / ED 3-30-06
73 3.0s/84 528e/90 525i/97 M3 4dr/99 M3 Conv/2001 330i/2004 545i ED/2006 330i ED June 05
You're in control...is there anywhere you want to go ? -------------------------
      02-17-2006, 01:13 AM   #14
fakerlin
Drives: 330xi Touring
All it does is add 200 bhp.
330xiT March 2006 delivery | Titanium silver | Sat Nav | M6T
      02-17-2006, 02:16 AM   #15
FlyingFinn
Finland
20
Drives: M235i
The plastic gas pedal is not used if you have the module type gas pedal in your car. As in your case you do. Bolts and nuts are not meant to be used for gas pedal. This may prevent the throttle to open completely. There are four self-tapping screws in the kit for gas pedal.
      08-11-2006, 08:38 PM   #16
egyptfolyf
Drives: '06 Range Rover, '06 S4,
AC Schnitzer pedals all the way!
      08-11-2006, 10:16 PM   #17
angrymofo
angrymofo's Avatar
Drives: e60 528i lci
i installed my ACS pedals lst nite...took 1 hour...all you need is good drill and the right size bits, make sure you have bits that can drill thru metal as the brake pedal is metal. but its pretty easy DIY
2008 528i Space Gray | M-tech spoiler | Tint all around | GPThunder AE | ST Suspension coilovers | RPI exhaust | BBS RW
RIP - 2006 325i Arctic & 2006 330i Sparkling Graphite
      08-11-2006, 11:11 PM   #18
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
the dead and gas pedals were easy.........drilled then screwed.
but the brake pedal was a little harder....i had to use a titanium drill bit.
and the screws and bolts that came with the kit were too SHORT!
i had to go to Home Depot and buy longer screws and bolts.
time: 1 hour
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      08-11-2006, 11:43 PM   #19
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
the install is pretty easy... just the brake pedal requires some elbow grease 'cause it's made of steel.
Personally, part of the fun of modding is the satisfaction of doing it myself. Accomplishment.
"Teach the ignorant. Ignore the stupid."
      08-12-2006, 08:13 AM   #20
e90fanatic
Absolute0
e90fanatic's Avatar
Drives: Has a Roundel
dont get the aluminum pedals...i installed it when i got my car and i sort of regret doing so. when wet, my foot slips around...prefer the old rubber pedals and save the $200+ after installations
To procede or not to procede......
      08-12-2006, 08:20 AM   #21
chicagolab
chicagolab's Avatar
30
Drives: E90 330i 2006 TiAg
quick question about aluminum pedals, like mentioned above......do your feet slip more with these pedals because of the metal surface or is there some type of grip to keep them from slipping? I was thinking in the winter frequently having wet soles of my shoes and I do not want to compromise safety
E90 330i | Titanium Silver | Black/Aluminum | Step | Idrive | Sunshades | PDC | Heated Seats | M3 Lip | Roof Spoiler | Front Splitters | Lux 5.0 | Blacklines
Link to my European Delivery write up:
http://www.bimmerfest.com/forums/sho...d.php?t=143486
Reply
e90post
