BMW M2 Forum > M2 vs... > 1M vs M2 track report
      05-08-2016, 01:19 PM   #1
M3 Adjuster
Albania
7864
BIMMERPOST
     Featured on BIMMERPOST.com
i recently had a chance to explore the M2 on track this past weekend and had a chance to compare it directly with the 1M.
1M Tex and his wife are certainly among the first dual 1M/M2 owners -sweet garage!
[IMG]http://i333.photobucket.com/albums/m...92C3E814E0.jpg[/IMG]
1M Tex car is no longer stock, and in driving his Dinan Tuned 1M, he has remarked that the M2 has been a stellar street car, however, compared to his modified car, if anything, slightly underwhelming. Well, we all know that the butt dyno is not a precise measuring tool... so we decided to have some fun comparing stock vehicles.
My car is a 1M bone stock... 31K miles, camber plates, euro MDM
Their M2 is bone stock... 1200 mi service completed,
while not exactly a stock to stock comparison. the M2 benefits from " drift mode" , and the Euro MDM setting that can be coded to the US version 1M actually allows the car to rotate, unlike the standard US MDM setting which was so restrictive that most drivers simply switched it off.
When we arrived at the track, we got a good chance to compare the cars side by side...
[IMG]http://i333.photobucket.com/albums/m...27C8FDC86B.jpg[/IMG]
[IMG]http://i333.photobucket.com/albums/m...20344BCE92.jpg[/IMG]
[IMG]http://i333.photobucket.com/albums/m...3C8B6745CE.jpg[/IMG]
without going to a full tale of the tape... A few photos show how similar the 1M and the M2 are.
The exterior styling, apart from headlamps and tail lamps, is largely the same.
[IMG]http://i333.photobucket.com/albums/m...A84DDA1540.jpg[/IMG]
[IMG]http://i333.photobucket.com/albums/m...86E7369E01.jpg[/IMG]
The hoffmeister kink at the rear window is nearly identical. The rear trunk openings are nearly the same shape, with the M2 actually having a slightly wider trunk opening that is masked by the shape of the rear taillights.
[IMG]http://i333.photobucket.com/albums/m...6394048A53.jpg[/IMG]
[IMG]http://i333.photobucket.com/albums/m...0780AC8B0B.jpg[/IMG]
[IMG]http://i333.photobucket.com/albums/m...267B84B2D7.jpg[/IMG]
[IMG]http://i333.photobucket.com/albums/m...31BB3C8646.jpg[/IMG]
Since we are at the track... it might be a good time to check out the M performance Analyser App..
[IMG]http://i333.photobucket.com/albums/m...BBC5E12184.png[/IMG]
the app is FREE.. BMW M Car not included... The M analyser uses a bluetooth dongle that connects at the car's OBD II port in the driver side kick panel. This allows an overwhelming amount of data from the vehicle sensors to be observed by the vehicle owner via an iPhone/ipad/android/tablet. The bluetooth dongle - BMW part # 614 323 65 115 for Apple and 614 323 65 116 can be found readily on eBay for around $200.
[IMG]http://i333.photobucket.com/albums/m...2747DAE1B3.png[/IMG]
here are some settings from the paddock...
[IMG]http://i333.photobucket.com/albums/m...248F2A22C5.png[/IMG]
I have long since coveted an Aim SOLO DL..however at $499-699, while it has been on my Father's day and Christmas lists for the last several years, one hasn't appeared and I hadnt convinced myself to plunk down that kinda dough.
I decided to borrow one from a friend as a good way to get lap data. As it turns out, the M analyzer provides all the data of solo DL and also can overlay video.
As well as the information available from the vehicles yaw sensors.... data from the emissions, fuel systems, and a myriad of other sensors are available. Want to know instantaneous fuel pressure? manifold pressure? air fuel ratio?, it's all available in the Core Drive section. If you would like to calculate fuel mileage and track fuel consumption there are tools for this in fuel drive.
Test drive provides measurement tools for 0-60, 1/4mile, braking distance, and also acceleration elasticity tests ( e.g 50-70 mph passing ).
I was so impressed with the bluetooth dongle. I purchased it last night! For all but the most serious trackway person... this app is a must have. If you are time trailing or racing or really want to be able to compare data among drivers,... the DL does provide additional capabilities..... on to the driving!
The track... motorsports Ranch... is a 1.7 mile course... It has several off camber turns and essentially one main straightaway, and two shorter straights, and this allows for incredibly close competition between cars.
For example.. a JP E30 M3 runs nearly identical times as a similarly prepped IP E36 M3.
I took the M2 out in my first session to get a feel for it. Well.. it didn't take very long!
Aside from the higher M2 seating position... (my 1M has manual seats), as I rolled from the paddock onto the track... i nearly forgot that I wasn't in my 1M. I am 5'10" and am happy to report that I did not have any issues with helmet room.
I drove with a passenger, and familiarized myself with the car for the session.. using sport plus for the driving mode.
The next session, I jumped into my 1M and hit the track. As I pulled from the paddock.. i noticed a MUCH larger wave of torque. When under full acceleration... the 1M demands your attention as it scrambles for rear grip, and launches the car forward in a a rush that, frankly, is at times a bit terrifying! As i rounded the circuit in the 1M... I rejoiced in the feeling and feedback from the steering rack... THIS is how steering should feel. As I turned into corners.. the live rear end of the 1M definitely kept me on my toes. On this day... the track was rather green.... i noticed both cars felt nervous approaching the apex of a corner. The 1M and the M both tend to step out at the rear when lifting, however the 1M is much less forgiving. I had to be careful to not dive into corners too hard, because if I needed to lift, I also would need to be ready to counter steer the rear. The solution to this for 1M owners, is wider rubber at the rear. WAY more rubber. With 285 or 315s at the rear, the 1M is able to stay better planted at the rear at turn in.... and also when applying forward thrust... However on this day.. with stock 265s on the rear, and a somewhat green/greasy track... as the tires heated up, I had to work harder to keep the rear end in in line.
Back in the paddock... I checked the solo DL...
[IMG]http://i333.photobucket.com/albums/m...41E2CCAE6C.jpg[/IMG]
I was able to improve my times up to lap 7 but after that.. it was difficult to keep the same pace as the Michelin Super Sports wilted in the Texas heat. Now back to the M2 for some timed laps...
As i returned to the course in the M2... it struck me how much THE SAME it is. The seating position, controls, view, handling... everything from the cockpit is nearly the same. The CONTROLs for the M2, however, are much lighter. Clutch effort is very light. The shift effort/feel of the transmission is nearly the same, but lighter. While the gearbox is definitely slicker, I found myself preferring the heft of my 1M shifter in gear changes. The brake pedal effort also felt lighter in the M2. And of course, the steering effort was lighter. The M2 steering is very good. The EPS is FAR improved over my 2013 x1. However it is still EPS and therefore it is numb and also felt light. The 1M steering is incredible on center and as one turns the wheel, it has a heft and sensation that communicate what the car is doing and also how the road feels. The M2 does a great approximation of this... and did not feel completely out of sorts at any time.
my notes texted to bdaddylo after stepping out of the M2
M2 is softer all around
softer clutch
softer brake pedal
steering number
gearbox lighter
1M puts you back in the seat with boost and the M2 builds more slowly and then has more power at the top end
NO WAY I WOULD TRADE
M2 literally feels like the same car actually
M2 revs more freely
Definitely better grip in the corners in the M2
" honestly doesnt feel much faster "
so let's check the SOLO..
[IMG]http://i333.photobucket.com/albums/m...9DB92378A5.jpg[/IMG]
well, what didn't feel much faster was a difference of 2.5 seconds !
As I checked the data, lap 4 was fastest... but all the laps after lap six were higher as the tires gave up due to heat. The Michelin Supersport is a great combo street tire, but it is nowhere near the league of some of the top autocross/street compounds like the Yokohama Advan, Hankook RS3, and Bridgestone RE tires out on the market.
1M best lap 1:30:15
M2 best lap 1:27:61
Top Straightaway speed for the M2 was 110 mph
top straightaway speed for the 1M was 108 mph
I had a fourth session to go out... and probably should have gotten back into the 1M to double check my times. However with the day getting hotter, i rather doubt i would have trimmed more than a half second off the time. Instead, I began to play with the M analyser and found that not only does it work in the M2... it also works in my 1M. I bought my car as a bare bones stripper plus a few options and did not pay for the drive or connected drive. I was very surprised to find that the M analyzer works for my vehicle as well and I immediately ordered it for future use!
after returning home and for the last 24 hours I have been thinking of the 1M and the M2 and how absolutely similar they are. Aside from a different dash, center stack and the power seats being slightly taller , The M2 has followed the 1M mold in nearly every way and strives to improve upon the M2. In many ways, the M2 is a version 2.0 of the 1M.
The M2 is a better daily driver, it is unquestionably faster around the track, and it has more creature comforts. It has idrive standard, power seats standard, more technology all around. It's exhaust tuning and overrun are delightfully enjoyable and make you want to rev it and listen to it burble and crackle. With ASD present.. it's certainly entertaining in the paddock, although the farting on deceleration on track is not a sound I find endearing. The N54 in the 1M certainly has this same DNA... Now I'll have to buy a midpipe or something !?!
I'm absolutely thrilled that the M2 is available, as now many more BMW enthusiasts will have a chance to own a vehicle that is one of the best BMWs of all time.
Which is better - 1M or M2 ?
If a stopwatch is involved.. then the M2 is the better option. An M2 DCT can crack off lap after lap effortlessly.
However..
For the absolute driving enthusiast... the person who wouldnt even THINK about getting a DCT... the 1M is absolutely the holy grail between the two.
The 1M is the analog classic. No ASD. No EPS. A manual steering rack that is sublime, combined with a shifter, clutch, and transmission, and chassis that provide more visceral feedback to the driver.
The 1M is a stallion that dares to be tamed, and it's absolutely more challenging ,involving , and more fun to drive.
Attention bmw AG ...
I'm still all in for an M2 CSL, but *please* make it a manual..
Appreciate 41
      05-08-2016, 01:20 PM   #2
M3 Adjuster
Albania
7864
GO pro Video - recon lap -
GO Pro Video
stock BMW M2 Chasing the E36 GTS-2 machine of David Bubeck at MSR
my best lap was 1:27,61 on lap 4 .... i was being followed by a Spec Miata that ran 1:26s... as did the GTS-2 machine.
A friend of mine with an E36 M3 sedan with suspension and track tires also ran a 1;27:00
Appreciate 10
      05-08-2016, 01:21 PM   #3
M3 Adjuster
Albania
7864
TBD
      05-08-2016, 01:42 PM   #4
Adem1534
Adem1534's Avatar
Drives: '16 M2
Awesome! Thanks man! Looking forward to what's to come.
      05-08-2016, 01:55 PM   #5
7UP
23
Drives: 1M
Exciting!!
      05-08-2016, 02:05 PM   #6
goodboy1451
Drives: BMW 1M Coupe
Whoop whoop!!
      05-08-2016, 04:19 PM   #7
zenmaster
Drives: '17 M2
Question - is there a difference in available ODB data from an M2 vs any other BMW?
      05-08-2016, 04:21 PM   #8
Bmwhocr
Bmwhocr's Avatar
90
Drives: F80 AW M3 | NB Miata
Wow! Thanks for sharing your comparison after driving them back to back. Im sure there are a lot of us who missed the 1M that are wondering about the many questions you answered.
Personally I think driving feel/enjoyment is more important to me than lap times. However, I doubt there will be any complaints from me with a new M2 as a DD with occasional track time
      05-08-2016, 04:30 PM   #9
bimmerzurich
bimmerzurich's Avatar
70
Drives: BMW M3 F80 COMPETITION / BMW M
Thank you for that wonderful report !
Was good to read
Love both of her own ways
      05-08-2016, 04:49 PM   #10
CrashFL
M2 Pilot
CrashFL's Avatar
Drives: '17 M2
That was an absolutely GREAT write-up! I really enjoyed it and will reference it in the future, I'm sure, when I want to pick up the Bluetooth dongle and when I'm ready for track/ autocross tires.
Thanks for sharing your insights. I'm waiting patiently.... But damn I want an M2 right NOW.
America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt
'17 BMW M2
      05-08-2016, 05:06 PM   #11
gthal
gthal's Avatar
1866
Drives: 2018 340i xDrive
Great review!! Love the commentary and the track results. Can't wait to get mine out this summer and compare it against my M4 results (although not back to back like you )
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      05-08-2016, 05:16 PM   #12
Reedomn
Reedomn's Avatar
Drives: 458 Italia/991.1 GT3
Great thread!! Now I do not have do one of my own!!
458 Italia, 991.1 GT3
Sold- f80 M3, e82 1M, f87 M2,
e30 M3, e90 M3, e36 M3, e34 M5,
e36 M3, e30 M3........
      05-08-2016, 05:19 PM   #13
M3 Adjuster
Albania
7864
All cars from 2011 onward are supported !
"The 1M was not actually listed correctly.
It was designated " M coupe "
I don't believe that the M2 has any additional info.:
      05-08-2016, 05:22 PM   #14
1M Tex
1M Tex's Avatar
Drives: 2011 BMW 1M Coupe, AW,
The biggest small difference I notice is the armrest. Fixed in the M2 and movable in the 1M.
The 1 series M is the most badass, coolest, sickest BMW to debut since the 1988 M3. The E30 M3 finally has a successor. Please welcome the stupidly fast, wickedly tempered, awkwardly named, possibly perfect little son of a benchmark - Automobile Magazine, August 2011
      05-08-2016, 06:47 PM   #15
Franklin Joseph
Drives: BMW
and what are you saving space 2 and 3 for? the cota write up next month?
      05-08-2016, 06:59 PM   #16
M3 Adjuster
Albania
7864
Videos incoming I hope.
And yes I figure I will also make a COTA Update.
When is your car coming in? Time to see if it can fit some 275 and 285 runner up front :-)
Yes. And perhaps some wheel and tire combos
      05-08-2016, 07:13 PM   #17
zenmaster
Drives: '17 M2
Hmm, my 2013 doesn't support apps, so no sure how that would work?
      05-08-2016, 07:14 PM   #18
Ex-MINI
BMW Newb
Ex-MINI's Avatar
581
Drives: 2016 LBB M2 DCT
Thanks for the writeup...it was a fun read!
      05-08-2016, 07:22 PM   #19
M3 Adjuster
Albania
7864
It works by sending info directly from the OBD port via Bluetooth to your phone. So " BMW apps " is not needed, only the app that you download on your phone.
      05-08-2016, 07:42 PM   #20
1M Tex
1M Tex's Avatar
M2
Part to use.
      05-08-2016, 07:45 PM   #21
zenmaster
Drives: '17 M2
ok, got that confused with the go pro thing.
      05-08-2016, 07:53 PM   #22
M3 Adjuster
Albania
7864
So was I , and I still am.
I thought that there was a go pro app available for the vehicle via BMW APPS.
I was hoping to use the BMW APP to control my Hero 4 from the M2. We searched but could not find how to download apps to the car.
the BMW M analyzer can record Audio and video from the track. If you place your phone camera on the dash it will record video ala Harry's lap timer and overlay the car data on that video.
So, rather than buy a GoPro and a solo DL, the Bluetooth dongle and your phone and an app from the Apple Store or android store is all you need. :thumbs:
here is me discovering it would work in the 1m
Copyright ©2000 - 2021, vBulletin Solutions Inc.
