2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Brake Noise
      03-24-2016, 12:51 PM   #1
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Brake Noise
Maybe you guys can help out:
I have EBC Yellow pads, stainless lines, fluid, stock everything else (with brakes).
With both these pads (and the Porterfield R4S pads), I get some slight squeaking. The weird part is, I get the squeaking (light) when I am not on the brakes, but just driving along. As soon as I apply some pressure, the squeaking stops. Brakes work fine otherwise.
Does anyone have any idea what might be causing this? This tends to happen when the brakes are cold. As they warm (a few hard stops, etc.) it tends to go away. I've looked around the interwebz for an answer, and other people have this problem with disc brakes, but it is definitely not common.
Any help is appreciated.
      03-24-2016, 08:05 PM   #2
Mywifes335
Mywifes335's Avatar
Drives: 2014 FBO M235i
New rotors or old rotors?
      03-24-2016, 11:53 PM   #3
Liquidpaper
Drives: '15 M235i
Original rotors.
      03-25-2016, 01:29 AM   #4
csg
always learning
csg's Avatar
57
Drives: fast, takes chances
it's possible you have some pad deposits on the rotors and the pads are just brushing the deposits during normal driving. This same thing happened to me when I street-drove my Hawk DTC60s between weekends on basically new-stock blanks. Street driving the pads all-but destroyed the rotors for the following weekend, horrible deposits. I had to quit early in the last session because the car was unsteady under braking.
-Colby
2020 M2C (his)
2022 Audi A6 Allroad (hers)
1997 Land Rover Defender 300TDi (ours)
      03-25-2016, 01:03 PM   #5
Liquidpaper
Drives: '15 M235i
This very well could be the case. Luckily, Yellowstuffs are not as abrasive on the rotors as Hawk DTC60s. Again, as the brakes heat up, the noise goes away. I guess that is what I get for having slightly more aggressive than stock brake pads.
      03-25-2016, 02:26 PM   #6
Mywifes335
Mywifes335's Avatar
Originally Posted by Liquidpaper View Post
Original rotors.
Your old rotors might not be fully mated to the new pads. The old rotors aren't smooth, despite how it looks to the naked eye. So these grooves left by your old pads are likely brushing up or scratching along unevenly with the new pads, causing resonance - squeaking.
You can try bedding them in again but it might make it worse. Suggest getting new rotor blanks or getting them cut on a lathe.
Perhaps try rubbing a bit of ceramic (permatex) grease on the backs of the pads and reinstalling.
      03-25-2016, 02:40 PM   #7
Liquidpaper
Drives: '15 M235i
I thought this might be the case. These rotors are on their last legs -- my plan was when these pads die out, its rotors/pads time. I'll ask my mechanic next time I'm in the shop. Thanks.
      03-25-2016, 02:44 PM   #8
Mywifes335
Mywifes335's Avatar
No problem. I used to swap pads in/out before/after track days so really accustomed to this.
      03-25-2016, 02:59 PM   #9
Liquidpaper
Drives: '15 M235i
The funny thing is that I don't swap my pads. However, my rotors are pretty heavily grooved at this point (I'm at about 22k miles and have a lot of track time on them), so I think its just the end of line for them.
      03-25-2016, 03:19 PM   #10
Mywifes335
Mywifes335's Avatar
22k miles is a lot!
      03-25-2016, 03:20 PM   #11
Liquidpaper
Drives: '15 M235i
22k miles is a lot!
Yeah. I've heard of people getting as much as 28k on the original rotors, even with track abuse, but maybe my time is up. Thanks for the input.
      03-25-2016, 07:09 PM   #12
Pparana
Drives: 2015 m235i
22k!
partsgeek has various rotor options starting at $50. No need to run them anywhere near that long. One set of race pads and I put on new ones. I get noise when i go back to ebc yellows (use them as street pads, compatible with my race pads). I suspect if you put new rotors on you would be shocked how much better the car stops.
      03-25-2016, 07:29 PM   #13
Mywifes335
Mywifes335's Avatar
Yeah since it's not a "real" M, rotors are cheap!
I have the M235i...just in case.
      03-25-2016, 08:35 PM   #14
Liquidpaper
Drives: '15 M235i
Thanks guys.
How hard is it to bed used pads on new rotors? I think my pads are fine, just the rotors need changing.
      03-25-2016, 08:39 PM   #15
Mywifes335
Mywifes335's Avatar
Easy. I don't remember the official sequence but drive around a bit do some medium stopping then do 3-4 successive 70-0mph stops. Usually works for me.
Just be careful.
      03-26-2016, 10:04 AM   #16
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
Thanks guys.
Here's a link on how to bed in brakes from previous thread about disappointing brakes on the 2series
http://www.zeckhausen.com/bedding_in_brakes.htm
      03-26-2016, 10:29 AM   #17
Mywifes335
Mywifes335's Avatar
Near stop prevents accidentally holding the pad onto a hot rotor which would cause warping.
Don't keep brake on at stop after bedding in.
On track days I either keep the car in gear or use wheel chocks - no parking brake after runs.
      03-26-2016, 10:49 AM   #18
Liquidpaper
Drives: '15 M235i
I always bedded my brakes in a similar way - some normal driving + 6 - 10 hard stops from 60 to 10, but don't let the brakes clamp and warp the rotors.
      03-28-2016, 12:56 PM   #19
casper83
casper83's Avatar
119
Drives: M235i XDrive
I had an issue several years ago with squeaky breaks and research led to harmonics. The brake pads would vibrate at a high frequency and cause a squealing noise. If this is the case for you the squeal potentially goes away when hot because the frequency of oscillation changes.
tips from Wagner on how to dampen vibration:
http://www.wagnerbrake.com/tech-tips...oise-solutions
      03-28-2016, 01:42 PM   #20
Liquidpaper
Drives: '15 M235i
This is very informative. Thank you.
      04-07-2016, 01:11 PM   #21
Liquidpaper
Drives: '15 M235i
So I picked up some new rotors and got them installed (needed a brake fluid recharge/swap anyway). Fixed my problem (mostly). Still makes a bit of noise, but I think that is in part due to the Yellowstuff compound (it's pretty aggressive) and the fact that the pads are not totally bedded yet.
I took it out last night on the PCH (only road in town that doesn't have traffic that you can get up to 60 mph on) and did the bed in procedure. I got a nice transfer layer going, but the Zeckhausen guide says that it make take two bed-in sessions to get the brakes up to maximum grip, although they are much better today than they were when I picked up the car from the shop yesterday.
Related note -- Stoptech makes some reasonably priced (cheaper than OEM) slotted/vented (not cross-drilled) rotors for the M235i. My mechanic was actually pretty impressed. Also, I swapped my brake fluid to this Torque RT700 fluid. It's not cheap ($33 a half liter), but holy crap does it work well. I did 15 or so stops from 60-70 last night to bed my brakes, and the pedal never even began to get soft. I would recommend if you wanted to try something different from the standard Gastrol SRF fluid (or a Motul fluid). It's also made in America ('Merica), up in Sonoma, CA.
      04-07-2016, 01:23 PM   #22
Mywifes335
Mywifes335's Avatar
Glad you got it sorted man! ��
Where did you buy the rotor blanks from?
Originally Posted by Axius View Post
Why the sad face, I fucking love sausage.
2addicts
