2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Strut braces from M2 for M235i coupe?
      03-21-2016, 01:11 PM   #1
DanATL
Drives: '89 635CSi, '16 M235i, '23 X5
Anyone know if the strut tower braces from the M2 (and 228i/M235i convertibles too) fit the M235i coupe? I would assume they do. Seems like a cheap thing to bolt in.
Part numbers are 51647301929 and 51647301930.
      03-21-2016, 03:45 PM   #2
Anderw
Anderw's Avatar
Drives: F80 m3
I might order these and give them a try , I don't see why it wouldn't work , or why bmw would have included these from the factory
      03-23-2016, 11:37 AM   #3
Richy_Boy
Drives: M235i & e46 M3 CS
Do you not have any strut brace on US M235i cars? My UK car has...
Rich
'14 M235i - KONI Sport, H&R Sport, M Performance Exhaust + Aero..
      04-02-2016, 11:01 PM   #4
csg
always learning
csg's Avatar
57
Drives: fast, takes chances
Pretty sure it's the same part as is standard on the convertible, but I could be wrong.
      04-03-2016, 05:13 PM   #5
allthatisntnow
allthatisntnow's Avatar
377
Drives: BMW M2C, 991 C2
There are no mounting holes for the parts on the 235 coupe though?
      06-29-2017, 07:14 PM   #6
EM58NDS 135i
Drives: 2012 M135i
Old thread i know, but was anyone successful in getting these braces to fit non convertibles?
      07-12-2017, 12:35 PM   #7
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Coupe does not have the forward mounting holes. I compared them when my buddy bought his M2.
      07-12-2017, 01:09 PM   #8
BEM-S4
BEM-S4's Avatar
Path of least resistance may be contacting KC Design and getting their strut brace. A few of us are running them and quite pleased with the product.
2022 Macan S
      07-12-2017, 03:50 PM   #9
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
anything can be fabricated to work.
that being said, to get it to work, will take alot of custom modification and fabrication. Look at the m235R race car that use it.
IMO, not worth the hassle.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      07-13-2017, 03:47 AM   #10
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Bryan,
M235R uses M3/M4 alloy and CF braces - from photo below - It look like it doesn't use the M2/F2x convertible side pressed steel bracings...
Current '22 X3M LCI..
      07-19-2017, 11:12 AM   #11
BEM-S4
BEM-S4's Avatar
Bryan,
If memory serves that's a $4k add-on.
2022 Macan S
      10-16-2017, 02:45 PM   #12
IK6SPEED
Drives: BMW M3 / AH3
The brackets need to be welded on, I will be doing that in a few weeks, but it looks like an easy and inexpensive mod, you will also need the convertible or M2 front crosslink.
      10-16-2017, 07:22 PM   #13
zipphreak
Drives: m235xi
For the M2 style you need two sets of brackets, Strut tower and side fender. Strut tower one is definitely welded from factory, the other one there are a couple holes here, but not sure if you need to weld it.
See parts 5 and 6 attached.
      10-22-2017, 09:29 PM   #14
IK6SPEED
Both are welded on actually if you dont want to weld them another way you can possibly attach them is using BMWs rivet bonding repair method, they use this even when replacing front frame rails or wheelhouse sections. Our f30s actually already have some front upper apron sections that are attached with this glue, its very strong and becomes rock hard, if you dont want to weld your new car you can use the bonding method but the adhesive is not cheap and you need special BMW rivets (although maybe you can get away with regular steel rivets as well as its just a reinforcement plate)
      01-15-2019, 08:04 AM   #15
williesm
Drives: m235i
Anyone have any luck welding these on?
2addicts
