2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Dinan spring orientation?
      03-19-2016, 01:25 PM   #1
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Anybody know the spring orientation for the front Dinan springs? Is the printed text supposed to be upright or upside down?
FBO M235i r
F80 M3
      03-19-2016, 02:27 PM   #2
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Upright.
      03-19-2016, 02:31 PM   #3
tenfour
Drives: at the speed limit
This came with my springs from dinan.
-roger
Current: '15 F22 EB 228i | M Sport | 6MT | Dinan | Rotiform | 35% tint | CF side mirrors
Gone: '11 B8 A4 | '08 Infiniti G37 Coupe 6MT | '04 E46 M3 6MT
      03-20-2016, 01:12 AM   #4
ocN55
ocN55's Avatar
Originally Posted by Dinan_Engineering View Post
Upright.
Could you explain the photo below? Are these the alignment specs that I should request when I get my alignment?
Originally Posted by tenfour View Post
FBO M235i r
F80 M3
      03-20-2016, 01:49 AM   #5
Dinan_Engineering
Drives: Any BMW
Those are indeed the specs you would want on alignment with the Dinan springs for the M235i. That sheet should have come with the set if they were purchased new so I assume this was a used set? Regardless, that same sheet can be found on our website by going to "Technical Docs" along the top navigation and then delving into the appropriate alignment specs section.
      03-20-2016, 01:55 AM   #6
ocN55
ocN55's Avatar
I have the sheet, they came with my order. I just wasn't sure what to make of it.
So my front camber is going to be 1.07 degrees give or take 0.42 degrees? Am I interpreting this correctly? Because that seems like quite a range of camber. Genuinely curious.
FBO M235i r
F80 M3
      03-20-2016, 02:15 AM   #7
Dinan_Engineering
Drives: Any BMW
On alignment the shop should be targeting -1.07 degrees of camber as that would be the perfect center of acceptable limits. +/- .42 of that number would also fall in to that accepted "green" zone on the alignment rack. The vast majority of Dinan alignments have a variable range of +/-.4 to .5 of camber leeway. In incredibly general terms on a road going car you want to maintain a degree or 2 of negative camber to improve road handling.
      03-20-2016, 02:19 AM   #8
ocN55
ocN55's Avatar
I mean I'd love to have 1.07 + .4 degrees of camber for these springs alone, but what determines the actual camber spec of the car? Because on the M235i there is no front camber adjustment.
FBO M235i r
F80 M3
      03-21-2016, 09:55 AM   #9
Dinan_Engineering
Drives: Any BMW
With McPherson struts the act of lowering the car changes the camber of the car. The more you lower it the more negative camber is achieved. The variability +/-'s are just the production tolerances specced out from BMW itself.
2addicts
