02-28-2016, 11:13 PM | #111 | |
Rep 241
I am not an expert on sound nor have I driven the M2. Just adding some comparative numbers out there. |
03-02-2016, 06:24 PM | #112 | |
Rep 233
As for those that noted that the M3 is as loud, you are certainly correct according to some reports but not according to others. Maybe we'll see some differing measurements on the M2 as well. |
03-02-2016, 08:15 PM | #113 |
Rep 233
They typical real world reference for 70db is a noisy restaurant. Just test drove a 340 a week ago. It was certainly quieter than 70db cruising at 70mph. Maybe the C&D numbers will be overly pessimistic for the M2 as well.
As for 3db being hardly noticeable, maybe that's true in the real world at high sound levels. Certainly not the case in a closed environment running noise generators. In that setting 3db was very noticeable. I think it would be in a car as well. Look at different models that run at 67db that we think of as luxo-cruisers compared to hot hatches running at 70db. At 72db you are now in the realm of old GT500's and Camaro ZL1's. Cool cars for what they are.. but not commuters. Last edited by Spook410; 03-02-2016 at 08:21 PM.. |
12-18-2016, 09:51 AM | #114 |
Rep 1,124
What's the difference in the level of noise with the active sound coded out?
03-28-2018, 07:18 AM | #115 | |
Rep 234
Drives: 325i Manual, M2 LBB DCT
03-28-2018, 08:04 AM | #116 |
Rep 229
Search the forum for the m2 teardown and racer rebuild. I believe he found almost no material
18 M2 lbb manual exec (Euro Delivery) and PDC
11 e92 335i xdrive BSM/PE (Sold) 09 335i xdrive Monaco Blue (Traded) 02 330xi (Sold) |
03-28-2018, 12:41 PM | #117 |
Rep 234
03-28-2018, 02:39 PM | #118 |
Rep 780
I'm about to add insulation ($450 worth) to my M2. I am losing my hearing so have trouble hearing my wife. Will take some readings at 70mph before (with ASD) and after with insulation and without ASD.
Give me a couple of weeks..
03-28-2018, 02:48 PM | #119 |
Rep 4,551
Drives: 2015 328d xDrive
03-28-2018, 03:13 PM | #120 |
Rep 234
I would be very interested to read more about your project. It would be interesting if you can take a reading without asd and no extra insulation too.
03-28-2018, 03:44 PM | #121 |
Rep 780
I only have a Decible X on my phone. Will try.
03-28-2018, 07:45 PM | #122 |
Rep 234
03-28-2018, 07:58 PM | #123 | |
Rep 780
51487221993 Sound insulation, engine compartment. 51489119216 Clip for above x 18 .................................................. ... .................................................. ... 51487296055 SOUND INSULATION TRUNK LEFT 51471911992 Fixing plug x12 D = 8MM 51487296056 SOUND INSULATION TRUNK RIGHT .................................................. ...... 51487319479 SOUND INSULATION, DOOR, FRONT LEFT 51487319480 SOUND INSULATION, DOOR, FRONT right .................................................. ........ 51487334357 SOUND INSULATING WHEEL HOUSING REAR LEFT 51487334358 SOUND INSULATING WHEEL HOUSING RIGHT LEFT .................................................. ......... Door and front wheel noise 51487300693 Sealing side panel, left 51487300694 Sealing side panel right
03-29-2018, 06:31 PM | #125 |
Rep 234
I already have asd off, 51487221993 and 05 on the schema but there is still lots of road noise.
real oem shows that door insulation 51487319479, 51487319480 is already on the car. http://www.realoem.com/bmw/enUS/part...&q=51487319479 |
03-29-2018, 07:10 PM | #126 | |
Rep 6,635
03-30-2018, 12:38 AM | #127 |
Rep 234
Ok there might be some mix up with the part numbers what i am saying is that what is shown on the diagram above as 05 is not on the car and 12 is. Am i wrong?
04-03-2018, 02:52 PM | #128 |
Rep 780
Give me a week have all the parts.
Ill do a write up.
voyagergab633.00 vanrijn0.00 |
04-03-2018, 07:45 PM | #130 |
Rep 780
OK for starters the insulation that they removed for the rear of the car does not weigh much. As you can see in the pics here there is basically none.
The worst noise maker looks to be the lack of part # 41007294289 and 41007294290. The big hole you see above the rear seats has a cover (light weight) in the F22. Without the cover noise from the rear wheels travels right into the cabin unstopped. I will cover the hole with Dynamat as the part are only available from Germany. I also applies some rubber base foam to outside body. It is pretty thin right there. Right of the bat - I don't buy the weight saving aspect....and the lack of the cover so the driver can hear the wheel spinning....guess some of you like that noise - not me. Give me exhaust and engine every time! Measured the sound in the cabin before I did any of this 82db at 70mph 82db At 70mph with the ASD bypassed. With the back open like this 92db at 70mph! ...and it sounds like the exhaust sound is in the car! Stand by for more updates.
14
Poochie9104.50 voyagergab633.00 Phil-on-Cars27.00 bmwv107.50 AndrewC198910931.00 Volki_M216.50 vanrijn0.00 GasBurnlife(landapanda)576.00 jessetaylor1171.00 hlm2c289.50 admranger2984.50 MASHCT624.00 Drifter2090909.50 |
04-03-2018, 08:35 PM | #131 |
Luxury at the redline :)
9105
Rep 7,563
They removed all that 'weight,' I am sure it must of saved a whopping 2 pounds.... Weight Reduction to BMW = Cost Cutting. That's why they also removed the blue stitching on the knee pad, you know, weight reduction. A daily car doesn't need to be obnoxiously loud to be fun and enjoyable.
Now if this was a Murcielago, that would be another story... Last edited by Poochie; 04-03-2018 at 08:55 PM.. |
MASHCT624.00 |
04-03-2018, 08:40 PM | #132 |
Rep 675
Drives: 2010 128i, manual, sport pkg
Cool pics of a M2 race car build!!! Then I read the rest, how depressing
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZIII square on et 40 with rolled rear fenders.
