2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes my setup
      01-09-2016, 02:41 PM   #1
rwalker
Drives: the wheels off
my setup
Figured I'd share my custom alignment and other car setup.
Car: 2014 M235i
Wheels: square 18x8.5et47 M441s (5mm spacers in front, effective et42)
Tires: 255/35r18 Michelin Pilot Super Sports
Suspension: GC camber plates + F8x LCAs
other: rolled front fenders (stock external profile, flattened inner lip)
I'm really happy with this setup for autocross, track days, and daily drives. Turns in like a beast! Minimal toe up front keeps tire wear manageable, and with the square setup I can rotate front to back.
      01-10-2016, 09:57 AM   #2
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Thanks for sharing this. I'm sure that it DOES turn in nicely. Especially with that much camber up front.
What issues if any do you have with the position of the wheels in reference to center of the wheel well with the different LCA's? I have read in here that it shifts the wheel center around a bit. Have you had any issues with the GC camber plates as well?
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      01-10-2016, 12:42 PM   #3
rwalker
The LCAs move the wheel forward in the fender about half an inch. This causes a decrease in wheel clearance, not just in the front, but also at the top, because LCAs move both the bottom and top of the wheel outwards.
I was an early adopter of the GC plates, and start to finish it took almost exactly one year to get them to something workable. GC stood behind the product to the extreme, though. I've got 2 track days and several autocrosses, as well as about 5k DD miles on them now. The only thing bothering me now is clunking at lower speeds on rough roads (an issue from the start).
I have not had the problem of axial bearing separation that another member has had.
While I was working with GC, I also tried TCKline and KMAC plates, neither of which worked out for me.
      01-29-2016, 09:46 PM   #4
Pparana
Drives: 2015 m235i
That's pretty close to my specs, I run zero toe up front and 2.7 degrees in the rear, I also have 9.8 degrees of castor. Everything else is the same.
      01-29-2016, 09:52 PM   #5
Cloud IX
Drives: Quickest Stock Turbo F8X
If you don't mind, why didn't the TCKline ones work out for you?
Quickest Stock Turbo F8x In The World
      01-29-2016, 10:04 PM   #6
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
holy camber Batman
      01-29-2016, 11:22 PM   #7
rwalker
2 main things:
  • the lack of continuous adjustability: there were only a couple of mounting configurations that actually worked, and none of them were right for me
  • interference: with my camber and LCAs, the strut shank shoulder was hitting the retaining clip on the bottom of the spherical bearing, causing a lot of noise (and visible wear to the clip)
There were other little niggles, e.g. the supplied mounting bolts were in the way of sliding the bearing/perch, necessitating my sourcing my own hardware.
I understand the TCK design has evolved since I tried it on my car, but I don't know if these issues have been addressed.
To be fair, it took GC and me almost exactly one year from when I first installed the plates to getting them basically sorted. There are still noises bugging me that I hope the Vorshlag plates will address. Will update once I'm able to source a set.
      03-27-2017, 01:19 PM   #8
TYC
TYC's Avatar
24
Drives: 2015 M235i TE
I've read that Dinan has solved the bearing noise issues with the camber plates. Is this confirmed that they are less noisy ?
@theyoungcarmody
2015 m235i track edition
PTF / Bm3 n55 dev car / brand ambassador
Cscs time attack - street rwd
Who says a race car can’t also be a show car?!?!
      03-27-2017, 01:29 PM   #9
rwalker
I have not personally confirmed
      03-27-2017, 02:25 PM   #10
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
they still make noise but with a loud exhaust its hard to notice.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      04-01-2017, 03:40 PM   #11
Ace604
11
Drives: 2019 M2C
Are you on stock springs/struts?
Tags
alignment, camber, lcas, square setup, track
2addicts
