2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Dinan Springs Just Installed - Creaking/Squeaking
      11-18-2015, 12:19 PM   #1
M2TROLL
WRX Betrayer
Drives: M235ix Estoril Blue Coral Red
Just had my dinan springs put on this past Saturday along with the supp handling kit. Drove it a good 100 miles so far and still getting a good bit of creaking sounds when turning the wheel....question is how much creaking noise is normal and how long should it last?
Set to get wheel alignment this upcoming Saturday.
      11-18-2015, 03:17 PM   #2
akuan99
Drives: 2015 228i M-Sport Track 6MT
Were springs installed by Dinan certified installer?
Check this thread http://www.2addicts.com/forums/showthread.php?t=1164914
      11-18-2015, 11:16 PM   #3
s1uma1
Drives: 2015 M235i
I have absolutely no noise with my Dinan springs and kit...
      11-25-2015, 11:27 AM   #4
A Frankfurt
Drives: German
I have installed many Dinan kits and have not have the sound you are describing. Maybe something is positioned in a way that the noise is being created ? I would recommend getting it looked at again to see exactly where the noise is coming from.
      12-29-2015, 07:59 PM   #5
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Check the bearing in the upper mount. The plastic bearing doesn't hold up very well to load and debris from the road.
      12-30-2015, 01:41 PM   #6
M2TROLL
WRX Betrayer
Turned out to be the guard tube that was left out during the install since they came with new dust tubes. MAKE SURE THE SHOP PUTS THE STOCK GUARD TUBE BACK ON WHEN THEY DO THE INSTALL! The spring was not perching correctly without it thus causing it to "shift", squeak, and creak about when turning.
2addicts
