E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > blackline taillights
Reply
      01-30-2006, 10:21 PM   #1
england1987
Drives: Z4 M coupe
2006 Z4 M Coupe  [7.50]
I went to my dealer today. I asked about the blackline taillights. The service and parts department didn't know about them the other day. They said that the blackline taillights have not been approved by the DOT. They said that they could not pass the vehicle for its state inspection if it has the blackline lights.
Is this true? Are they legal?
i searched first, but I couldn't find an answer.
      01-31-2006, 12:16 AM   #2
akhbhaat
Drives: ///M318ti Type-R Turbo S
This is how it was with the clears on E46 cars. Only the coupes were available with them directly from the factory, because they had red reflectors mounted within the rear bumper and small square amber reflectors mounted on the front, just below the headlights.
There's some sort of obscure (though hardly obscure in effect) DOT regulation which specifies an amber reflector at each of the front corners (look at EVERY SINGLE CAR sold in the US today - and if they're in stock trim, they will have amber reflectors at the corners, usually integrated into the headlight assembly or on the front bumper), and two red or amber reflectors at the rear. Installing clears (front or back) essentially removes these reflectors and constitutes an illegal modification.
I really don't see the point. The amber colored reflectors really don't increase the visibility of the car in any meaningful way. Just another example of pointless government regulation.
Needless to say, you can easily retrofit them, and I've not once encountered a cop or anybody else who even realized that the clears on my E46 were technically illegal.
      01-31-2006, 03:08 AM   #3
shragon
shragon's Avatar
Drives: BMW
if you look at longtran's pic of the blacklines, you'll see there is a reflector in place on the side, just like the stock tails. depending on state, i guess you could have problems if DOT is not stamped on it.
      01-31-2006, 03:41 AM   #4
Paul330d
Torque junky
Paul330d's Avatar
France
115
Drives: Remapped e90 330d
2006 330d  [0.00]
2005 Fiat Panda 4x4  [0.00]
England1987, why not leave this post for 12 months or so and then bump it by adding a pointless comment like "HAHAHA"? I'm sure members will be delighted to help you out then.
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
      01-31-2006, 08:49 AM   #5
england1987
Drives: Z4 M coupe
Thanks, I'll be sure to put a note on it stating that you wanted me to. by the way, how is france?
      01-31-2006, 02:00 PM   #6
itznin
itznin's Avatar
26
Drives: 2013 F30
      01-31-2006, 02:13 PM   #7
James Bond
Sheer Driving & Biking Pleasure
James Bond's Avatar
Germany
19
Drives: 318ti compact E36
With the black-lines looks the new 3er-BMW still more sportive!
But I really don´t know - if it´s given for the touring, too!??
"...we´re from Bavaria, it´s near Germany..."
Greets, Flo Mountainbike: CUBE Stereo
EX-CAR´S: Ford Fiesta 1.1 | Nissan Primera 1.6 SLX | 318ti-E46 | 320dT-E46-FL | 120d E87-Pre-FL | Skoda O² Combi 2.0TDI Elegance | 325CiA E46-Pre-FL | Ford Focus I Turnier Sport TDCi
      01-31-2006, 02:53 PM   #8
akhbhaat
Seeing as that's the case, I don't see why they're not DOT approved. Maybe they will be.
      01-31-2006, 03:44 PM   #9
thd13
thd13's Avatar
46
Drives: A07 330i
2006 330i  [0.00]
They are DOT approved. It has DOT imprinted on the plastic. Not noticable in any pictures, but if you look closely in person, it says so.
My other ride is your mom.
      01-31-2006, 03:48 PM   #10
shragon
shragon's Avatar
Drives: BMW
well, there you go folks.
also proves to show that some dealers don't know s**t.
      01-31-2006, 04:08 PM   #11
ChrisPA
Drives: 2009 A5
Originally Posted by akhbhaat
There's some sort of obscure (though hardly obscure in effect) DOT regulation which specifies an amber reflector at each of the front corners ...
I agree that there are many many pointless regulations, but I don't see this one as particularly egregious - at the very least, its easy to meet the requirement. I'd imagine its for times when the car lights are OFF, so there is some kind of reflection coming from the corners of a car, say, off to the side of the road, maybe broken down. In the dark, particularly foggy times, I've noticed these reflectors pretty clearly on parked cars... Not sure that I wouldn't have seen the car without them, but it did help...
      01-31-2006, 04:12 PM   #12
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
moot point!
They are legal... corroborated by the fact that they are sold by BMW dealerships in NA.
"Teach the ignorant. Ignore the stupid."
      01-31-2006, 05:19 PM   #13
akhbhaat
Assuming the reflectors do have a valid purpose (and I do see your point), why specify amber as opposed to white (which looks far better)? I have no trouble seeing the white reflectors used over lane markings on highways.
      01-31-2006, 08:23 PM   #14
ChrisPA
Drives: 2009 A5
you have me there! i can see no good reason why they insist on amber, so i'd guess it's just to make it simpler on them - not necessarily safer or better, but just simpler for them to test/standardize. doh!
      02-01-2006, 12:50 AM   #15
shragon
shragon's Avatar
Drives: BMW
i guess because it's been amber for so long, the govt is too lazy to change it. in my mind, i think it should be tweaked to make the requirement either a clear/white or amber reflector up front.
Reply
e90post
