2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes DIY: Rear sway bar?
      08-19-2015, 01:22 PM   #1
Apezzone
Drives: 2015 BMW m235 xdrive
DIY: Rear sway bar?
Does anybody have a DIY for a rear sway bar for m235 or any instructions/tips/installation time??
Thanks guys
      08-19-2015, 01:29 PM   #2
alz0rz
What goes here?
alz0rz's Avatar
452
Drives: 2019 G30 M550i
The installation time has been quoted as 6+ hours because you have to drop the rear sub-frame to get at the sway bar. That time is also probably with the correct facilities (i.e. lift), I'd imagine it would otherwise be worse.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      08-20-2015, 09:36 PM   #3
i8ur911
Drives: F22 228i MSport
It can be done in less than 6 hours for sure. You'll need a trans jack preferably and a lift. You can lower the rear subframe just enough to get the old bar out and new one in.
You're still looking at 3-ish hours though.
      08-21-2015, 01:05 PM   #4
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
It's harder than you think. If you are in the business of being careful, it takes 5-6 hours for a good independent shop that doesn't do this on a regular basis. The front sway is even harder, as you need to basically un-mount the engine, put it on a lift, drop the subframe, then do the sway bar install.
Not recommended unless you track the car. It's too much of a pain in the ass.
      08-21-2015, 02:04 PM   #5
Pparana
Drives: 2015 m235i
As someone who did it himself, I can say I am glad my neighbors shop has a lift. I have a small "Track Jack" Jack system. I could have maybe done it with that but would have been a mess.
So, If you are comfortable messing around with sub frame, drive train, drive shaft, exhaust, suspension than yes. Without a lift, you have to do all that in 24" or so of space.
Oh by the way, front is twice as hard.
      01-17-2016, 12:31 AM   #6
Straight6Driver
Drives: F30 335i
Is the rear sway bar worth upgrading by itself for those who track regularly? I'll be installing a LSD to the car, should I be looking at changing the sway bar as well?
2addicts
