2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Destroyed my rear Lca bushings
      06-16-2015, 06:57 PM   #1
Pparana
Drives: 2015 m235i
Well, 3300 street miles, 18 track days, 2300 track miles the rear of my car started to squirm coming off throttle, inspected the rear bushings and there all pretty worse for the wear, the Lca inner and outer bushings are shot.
Anyone know of any Derlin options or cross compatibility?
      06-16-2015, 08:22 PM   #2
rwalker
Drives: the wheels off
pictures?
      06-16-2015, 08:35 PM   #3
Pparana
Drives: 2015 m235i
I'll try to snap some tommorow, but it is hard to see, of course when I pull them out I can take some.
      08-14-2015, 03:35 PM   #4
rwalker
ping on this
      08-15-2015, 09:04 AM   #5
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I thought Dinan made some spherical bearing replacements.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      08-15-2015, 09:53 AM   #6
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
would the M4 LCA fit in the rear like the front ones ?
      08-15-2015, 02:37 PM   #7
i8ur911
Drives: F22 228i MSport
Still no pics.....????
      08-16-2015, 09:49 PM   #8
Pparana
Drives: 2015 m235i
Sorry for the delay, been slammed at work. These are rears, so no m3 parts or Dinan kit.
I replaced with some aftermarket ones and also replaced most of the rear suspension with adjustable links with heim joints.
so far rear end feels as good as my 13 911 now.
      08-16-2015, 10:20 PM   #9
pikcachu
pikcachu's Avatar
1403
what did you replaced it with?
      08-20-2015, 09:45 PM   #10
i8ur911
Holy cow! I'll be checking these now too 😔
      12-15-2015, 11:42 AM   #11
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Do we know if f8x series OE bushes fit into f2x series LCAs and TS as possible way to resolve this problem ?
      12-15-2015, 12:45 PM   #12
rwalker
+1, which aftermarket bushings?
      12-15-2015, 03:15 PM   #13
Pparana
Drives: 2015 m235i
I replaced part # 3 on the diagram with FCM, ironically they are the cheapest and pretty much just solid rubber, which is what I want.
Part #13,11,17 were replaced with Megan racing parts, with spherical bearings. This removed all the flex in the suspension and is much much improved. When you see how much flex is in those stock pieces you would laugh.
I know many people are talking about the sub frame bushings, however the arms are still soft. The only other rear upgrade I would consider it the diff bushings, maybe next spring or summer. Car is stiff, but not uncomfortable, can handle semi slick tires now and really I would not want much stiffer for a dual use car.
Best way to describe is you def. know where the rear end is, and the traction feel is far better to read.
hoppy6698127.00
DVC558.00
      12-17-2015, 08:07 AM   #14
jmwilson125
Drives: 2016 M235i
Forgive me if this is a boob question, but were the parts custom made or something they have in stock?
If it was custom I'm guessing its pricey
      12-20-2015, 09:20 PM   #15
SteveInfante
Part numbers? That would be helpful for those of us who are looking to do the same thing.
      12-21-2015, 10:22 AM   #16
LimeRockM235
LimeRockM235's Avatar
57
Drives: M235i Xdrive
or a link to the megan racing parts?
      12-22-2015, 03:19 AM   #17
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
According to MR website, they do 4 different arms for rear of F series
MRS-BM-0311
MRS-BM-0320
MRS-BM-0370
MRS-BM-0380
http://www.meganracing.com/products/...tid=24&x=0&y=0
Current '22 X3M LCI..
hoppy6698127.00
      08-15-2016, 08:20 PM   #18
nike001
Drives: 2018 718 Cayman
Curious as to why you're tracking an m235i instead of a '13 911
      08-18-2016, 11:47 PM   #19
Pparana
Drives: 2015 m235i
tracked the 991 for a few years, little dull. The modded 2r on proper tires is faster and much more of a handful. Consumables are about a 3rd of the cost.
If you go r comps on a 911, you end up with oil starvation pretty quick, engines are pricey on those.
991 has been retired from the stable, replaced with a f type.
      08-21-2016, 09:38 AM   #20
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
How are the Megan Racing parts holding up?
Also you mention that you replaced the part #3 bushing with "FCM" ... What's FCM?
Ahead of the curve for specF30
      08-22-2016, 10:08 PM   #21
Pparana
Drives: 2015 m235i
Good, the outer is now replaced with superpro poly, same part number as f30. Just finished swapping out the rear subframe and diff today to poly, should be. Better in general. Surprised at the amount of compliance in those bushings.
x233284.00
      08-29-2016, 10:43 PM   #22
rwalker
Which m235i convertible parts did you manage to cram on up front, or is that still a research project?
2addicts
