2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Can't enable folding mirrors on F23 via coding
      05-18-2015, 10:42 AM   #1
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Has anyone here with a US/Canadian Spec'd F23 been able to code their mirrors to fold with the key fob? I have the button on the door switch and I am able to get them to fold from the inside.
I've tried the following which has worked when I coded someone else's F33 4 series cabriolet but these settings will not work on my car.
KOMFORTSCHLIESSUNG_FB Aktiv
KOMFORTSCHLIESSUNG_PA Aktiv
ASP_BEIKLAPPEN_BEI_KONFORTSCHLIESSEN Akitv
ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN Aktiv
Someone from Germany on this forum who also had an F23 was also kind enough to send me his FEM_BODY *.ncd file and his had the following parameters for 3053 PW Master and 3110 External Mirror Master
KOMFORTSCHLIESSUNG_FB Nicht_Aktiv
KOMFORTSCHLIESSUNG_PA Nicht_Aktiv
EINSTIEGSHLFE_AKTIV Aktiv
He also had the following parameters that were different to mine on his ncd file and I went ahead and made these changes and still it is not working.
HW_OPTION_BODY_CA_COMFORTENTRY Left: nicht aktiv = 00 Right: aktiv = 01
HW_OPTION_BODY_WW_SRA Left: nicht_aktiv = 00 Right: aktiv = 01
ComAdapterPdu_292_Steuerung_Fernlicht-Assistent Left: inaktiv = 00 Right: aktiv = 01
ComAdapterPdu_437_Status_Kamera_Kalibrierung Left: inaktiv = 00 Right: aktiv = 01
CEM_ACTIVE Left: nicht_aktiv = 00 Right: aktiv = 01
CEM_IDG_ACTIVE_ON_CLSY_ULOCK Left: nicht_aktiv = 00 Right: aktiv = 01
CEM_IDG_ACTIVE_ON_DOOR_OPEN Left: nicht_aktiv = 00 Right: aktiv = 01
CEM_IDG_ACTIVE_ON_IDG_BUTTON Left: nicht_aktiv = 00 Right: aktiv = 01
CEM_CTR_TO_ULOCK_HK Left: nicht_aktiv = 00 Right: aktiv = 01
CEM_ENABLE_TAGE_PASSENGER Left: nicht_aktiv = 00 Right: aktiv = 01
CEM_TRUNK_REV_ON_CLOSE_LID Left: nicht_aktiv = 00 Right: aktiv = 01
CEM_TRUNK_INDICATE Left: nicht_aktiv = 00 Right: aktiv = 01
CAM_SEARCH_TRUNK_DOUBLE Left: nicht_aktiv = 00 Right: aktiv = 01
CAH_CAR_TYPE Left: car_type_6e = 6E Right: car_type_6a = 6A
CLM_MSA_OFF_AT_SECURE Left: nicht_aktiv = 00 Right: aktiv = 01
CLM_HORN_AT_SECURE Left: nicht_aktiv = 00 Right: aktiv = 01
CLM_CCM_COOLANT_TEMP Left: aktiv = 01 Right: nicht_aktiv = 00
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      05-19-2015, 12:59 PM   #2
bradM235
bradM235's Avatar
22
Drives: 2014 M235i Estoril Blue
2014 BMW M235i  [0.00]
F22 Canadian Spec Car.
Mirrors fold in and with the fob and with the door handle BUT you have to hold it for at least 300ms.
Somewhere, that I cannot locate, I remember something about reducing the default timeout to that 300ms value but I can't find that in the cheatsheet.
Here it is:
http://www.2addicts.com/forums/showp...&postcount=143
      06-16-2015, 03:06 PM   #3
steve@codemybimmer
Hong Kong
665
I just tried on a 2015 F33 428i xDrive Cabriolet today and it took had the same problem. I think it's something specific to MY2015 convertibles.
      07-05-2015, 12:42 AM   #4
steve@codemybimmer
Hong Kong
665
Some progress. I disabled the FH_Cabrio_verdeck_modul parameter and changed the KOMFORT SCHLIESSEN parameters to Aktiv and my mirrors now fold with the key fob. The top however will now not open or close. It looks like something else is controlling the PwMaster but I'm not sure what it is. I also checked REM and CVM and I couldn't find anything that might be related to it.
At least now when it gets cold and I no longer want to put the top down, I can opt for folding mirrors instead.
3053 PwMaster 0E
FH_CABRIO_VERDECK_MODUL Nicht_Aktiv
KOMFORT_SCHLIESSEN_FB Aktiv
KOMFORT_SCLIESSEN_PA Aktiv
3110 PfExternalMirrorMaster 10
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN Aktiv
I also saw this note for the KOMFORT_SCHLIESSEN options saying that these options are disabled on convertibles as of 07/14 production.
1.4.14: Für Cabrios ab Baustand 14-07 aufgrund Entscheid Behler/Guetlein deaktiviert
2addicts
