2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Brake Dust
      04-16-2015, 05:54 PM   #1
M_Proper
Drives: 2015 M235i
Brake Dust
What do you all do about it? I mean my God these brakes are the WORST for producing dust.
What are my options other than living with it or getting a recurring membership to my local Mike's Car Wash?
      04-16-2015, 05:56 PM   #2
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Don't use the brakes.
I turn off traction control and spin-out into all of my parking spaces
Appreciate 5
      04-16-2015, 06:04 PM   #3
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Poorboys World Wheel Cleaner is the answer my friend... Spray on spray off, and it helps if your wheels are sealed.
      04-16-2015, 06:04 PM   #4
recycledAlva
Drives: MY17 BSM M2
2017 BMW M2  [0.00]
Get wheels that match the color of the brake dust so it's less noticeable
      04-16-2015, 06:20 PM   #5
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Get some ceramic pads, if you don't want to deal with it. I think Akebono makes them now? Otherwise, wear it as a badge of honor -- good pads dust.
      04-16-2015, 08:07 PM   #6
mfourn20
mfourn20's Avatar
52
Drives: 228i M Sport
I was using an armour all spray. It worked alright. Is the only product of theirs I've used. I'm about to put the summer wheels/tires on and I'm trying out chemical guys wheel sealant this time around. It went on really easily, and had all good reviews.
      04-16-2015, 08:10 PM   #7
nike001
Drives: 2018 718 Cayman
Sonax wheel cleaner is the answer to all brake dust.
I use the BMW wheel gel every wash, Sonax every few washes, and Iron-X maybe once every 1-2 months. I usually add a degreaser every few washes after I clean the wheels with one of the above cleaners; I've found using a degreaser really brightens up the wheel that extra step.
      04-16-2015, 08:21 PM   #8
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
Highly recommend Sonax Wheel Cleaner Full Effect.
///Sursum Ab Ordine
      04-16-2015, 09:48 PM   #9
mike@tpc
Drives: white M235i
ceramic pads if you are just street driving and not tracking. Best mod ever for brake dust. Either akebono or centric posi quiet.
      04-16-2015, 10:08 PM   #10
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Will the Akebono's not stand up to track abuse?
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      04-16-2015, 10:35 PM   #11
mike@tpc
Drives: white M235i
no ceramic pads will if you are braking the way you should be on the track.
      04-26-2015, 05:15 PM   #12
webbit
webbit's Avatar
63
Drives: 2015 M235i
Found these online, has anyone used these yet
POWERSTOP - Z16 EVOLUTION CERAMIC BRAKE PADS
2013 BMW 125i M Sport
2015 M235i EB
      04-27-2015, 03:48 AM   #13
swagon
swagon's Avatar
Drives: F80 6MT
This might do the job. I have not bought it but I'm planning to do so. Can't find anything that repels brake dust (my PB Wheel Sealant is a PITA to work with).
      04-27-2015, 08:33 PM   #14
horsepower_and_hounds
Drives: BMW
I ran the POWERSTOP - Z16 EVOLUTION CERAMIC BRAKE PADS on my 1 series and they were very low dust and usually washed off easily. The problem with the 2 series is I can't find anybody making carbon ceramic for front & rear yet. They all only supply the front.
      04-27-2015, 11:18 PM   #15
mike@tpc
Drives: white M235i
Centric PosiQuiet available front and rear
http://store.zeckhausen.com/catalog/...6044_6045_6049
      04-28-2015, 05:26 AM   #16
Drives: BMW
1051609 ceramic for front only...the others are semi-metalic. I called them and they do not make them as of yet for the rear...the front are almost the same as the 3 series and that is why they are already available. They claim the semi-met are much lower dust then the stock BMW pads though
      04-28-2015, 09:37 AM   #17
mike@tpc
Drives: white M235i
I'm going with the semi metallic. I just did one track day with the car and now I have 800 miles left on the rear pads according to the computer, so I'm just going to switch them all out to cut down on dust. I don't plan on tracking it anymore, but if I do, I'll get some carbotechs.
If you look at the info button on rock auto, according to centric, the metallics are rated 9/10 for dust resistance and the ceramics are 8/10
      05-15-2015, 08:05 PM   #18
todd hollander
Drives: X3 30i
Cool Carbon Pads, M235i
I bough these and have put on about 200 miles so far. They have a much kinder initial bite and seem to have very low dust. I bought them from ECS Tuning. It was super easy to do and I am very pleased so far. I will give an update in a few weeks.
      05-15-2015, 08:10 PM   #19
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
How do you compress the pistons? specially on the back.. any issue with the hand brake ?
      05-16-2015, 09:13 PM   #20
todd hollander
Drives: X3 30i
From years of changing out pads at the track, I've found that I just press on the old pads while they are still in the calipers to compress the pistons. This time I just used my hands to push on the pads to compress the pistons and free up the pads. Sometimes you need a flat bladed screwdriver to gently push on the pads against he rotors.
      05-16-2015, 10:26 PM   #21
pikcachu
pikcachu's Avatar
1403
i see... but how do you push if the back of the pad is against the rotor and the other against the pistons ? press from top and bottom ?
      05-17-2015, 12:29 AM   #22
webbit
webbit's Avatar
63
Drives: 2015 M235i
You get a pair of these
2015 M235i EB
2addicts
